Idag er beo 5 lanceret OFFICIELT
Masser af nye billeder og information er lagt frem på B&O´s Hjemmside. Jeg har ringet til min lokale B&O forretning og de oplyser at
prisen bliver danske kr 4195,- inklusiv den nødvendig bordlader, og kr 3595,- uden bordlader (hvis du har f.eks anskaffer dig flere Beo5 )
En demo model levereres til forretningen i slutningen af denne månede (d. 17) hvor den herefter kan bestilles..
Meget interesante tekniske data herunder
Beo 5 - Specifications
| DESIGNER | David Lewis |
| Battery capacity | |
| Standby | 12 days |
| Active time | typical 18 hours ( 3 hours continually) |
| Charging time | 5 hours |
| Memory | 100 logos, 100 icons, 24 zones |
| Fonts | 7 fonts (1 font in 7 colours) |
| IR operation | Beo4 IR protocol, Beo5 IR protocol, RC5, Bitstream, NEC and Raw |
| Hard keys | Yes, 17 + wheel |
| Soft keys | Yes, 17 |
| Warning for low battery | Yes |
| Operation in charger | No |
| Multiple languages | Yes, 8 |
| Wake-up touch | Yes |
| Table charger | With update functionality (for dealers and Technicians) |
| Cable length | 3.6 meter |
| 205g +/- 5g |
| Dimensions | |
| Width | 69.3 mm |
| Height | 115.8 mm |
| Depth | 32.3 mm |
| Operating temperature range | |
| Complying with all specs | 10 C to 50 C |
| Reduced performance is acceptable in range | 0 C to 10 C |
| IR range | 455 KHz and 2080 KHz |
| Power management | Mini DIN (4-pin) |
| Wake-up | Alu-ball touch, key-press, display pressing, wheel activation, placing in charger |
| Power down | Timeout - follows backlight |
| Power on | Centre key activation, placing in charger |
| Power off | Long press on centre key, low battery capacity (<10%) |
| Battery and charging | |
| Active time pr. charging | typical 18 hours (3 hours continually) |
| Standby time pr. charging |
| 12 days |
| < 5 hours from empty |
| 5,0V DC +/- 10% |
| | 400mA +/- 10% |
| Beo5 Charger Table - type number 8003080 |
| Access by service technician |
| Easy volume adjustment with the wheel | |
| Volume adjustment is carried out with the wheel | |
| Wheel functions | Volume up, volume down, mute |
| Backlight | |
| Colour | White |
| Intensity | Automatic adjusted to ambient light |
| Timeout | 2 step - dim and fadeout |
| | Factory set to 10 and 30 seconds, user adjustable |
| Display function | |
| Type | Delta-RGB, 320x240 pixels, normal black |
| Colour | 16.777.216 colours |
| Contrast ratio | 500 @ 25C (typ) |
| Function | Factory adjusted contrast |
| Visual signals | |
| In standby | None |
| Active | Display - "Battery low" |
| Sounds | |
| Wheel | turning |
| Display | touch - select & release |
