1st March February 2012
Latest post 02-14-2012 6:57 AM by Step1. 21 replies.
08-13-2007 1:25 AM
Frank Rizzo
![](/utility/anonymous.gif)
![Top 100 Contributor Top 100 Contributor](/Themes/beotheme1/images/rankicons/rankTop100.gif)
- Joined on 05-15-2007
- Posts 599
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Three questions please.... 1) What problems arise? Are any of the speakers with foam surround?? 2) How do they sound in comparison to some of the powered speakers? say connected to the Beocenter 9500 3) Most importantly, has anyone "re-furbed" a set of these.....what tips to make them look new???? Thanks..
joeyboygolf
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.69/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
1. Yes, they do suffer from foam rot. 2. They sound excellent when driven by the correct amplifier. The 9500 is not really powerfull enough to show them at their best. It will loose control, in particular of the bass when driven hard. Much better with 5500/6500/7000. Just my opinion, others will not agree. 3. Difficult to refurb as new because the cloth on the frets is unavailable. Some have re-covered with similar cloth but it is not to my personal taste. Unless B&O is perfect and looks original then I'm not really interested.
PD
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.48/avatar.jpg)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
- Joined on 03-27-2007
- Eastbourne, England
- Posts 210
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
I've got mine hooked up to my BM6500 & they run fantastically. Hmmm, anyone know where I can get a new band for one? It's snapped & sort of flapping in the breeze created by the cones moving an immense amount from gorgeously loud & clear sound.
PD
"The difference betwixt erotic & kinky is that betwixt using a feather & using a chicken..."
Medogsfat
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.35/avatar.jpg)
![Top 10 Contributor Top 10 Contributor](/Themes/beotheme1/images/rankicons/rankTop10.gif)
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
PD: I've got mine hooked up to my BM6500 & they run fantastically. Hmmm, anyone know where I can get a new band for one? It's snapped & sort of flapping in the breeze created by the cones moving an immense amount from gorgeously loud & clear sound.
Originals not available any more. This ebay seller does replacements but I've no idea how close they are to the originals. (I'm not connected in any way to this seller BTW and have no vested interest). Chris..
beoperson
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.39.56/avatar.jpg)
![Top 200 Contributor Top 200 Contributor](/Themes/beotheme1/images/rankicons/rankTop200.gif)
- Joined on 06-15-2007
- New-York USA
- Posts 288
I've owned RL140 and used them with BeoSystem 7000. Excellent match in my opinion. I love RL speaker design and looks. White RL 140 with white BeoSystem 7000 would be something special to own.
David the BeoPerson
PD
- Posts 210
beoperson:I've owned RL140 and used them with BeoSystem 7000. Excellent match in my opinion. I love RL speaker design and looks. White RL 140 with white BeoSystem 7000 would be something special to own.
![homer drool homer drool](http://www.caledoniacalling.com/uploaded_images/homer_drool-740916.gif)
Chris - Thanks. ![Smile](http://forum.beoworld.org/emoticons/01.gif)
PD
Frank Rizzo
- Posts 599
Hi Graham...So on the "foam rot"..... 1) which of the drivers suffer from this??? 2) Are the foam surrounds available?? if so where and how much... Thanks,...Keith
joeyboygolf
- Posts 3,252
The honest answer is I don't know! I've only had contact with one pair that had rot and the guy sent them to Recone in Huddersfield UK to be fixed. I assume it was the bass drivers.
Fatandre
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 10-26-2009
- Posts 17
I am thinking about getting this amp. How do you think they would sound with it?
http://www.radiomuseum.org/r/marantz_pm_710_dc.html
jam57
- Joined on 02-02-2010
- Denver CO
- Posts 27
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
Hello, replacement straps are available from Iconic AV. There is no lettering as on the originals but these will work.
John
Step1
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.88.68/avatar.jpg)
![Top 75 Contributor Top 75 Contributor](/Themes/beotheme1/images/rankicons/rankTop75.gif)
- Joined on 07-06-2008
- Manchester
- Posts 961
Beowulf:
I had my driver surounds replaced by Recone Labs as mentioned above,all four cones came to about£250, they did a wonderful job returning them with rubber surrounds. ![Cool](http://forum.beoworld.org/emoticons/11.gif)
Seems like a lot of money did they replace the coil and spider etc...? I do know they have (had?) a good reputation though!
Bentleyman
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.08.39/avatar.jpg)
![Top 150 Contributor Top 150 Contributor](/Themes/beotheme1/images/rankicons/rankTop150.gif)
- Joined on 12-29-2008
- Rochdale
- Posts 367
Iconic AV's replacement straps are very good in my opinion.
I received a pair of straps from them for some RL60.2's and they are as good as originals, except for there being no print on the straps.
![Yes - thumbs up](http://forum.beoworld.org/emoticons/21.gif)
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
dmacri
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.82.18/avatar.jpg)
- Joined on 05-03-2008
- Posts 63
Only the woofers suffer from foam rot. The midrange has a rubber surround. The I was able to refoam my pair without issue. Rather inexpensic
BeoSystem 5000 (BM 5000, BG 5005, BC 5000, CD50), BeoCenter 3500, BeoCenter 2500, BeoLab 2500, BeoVox S-45, S-45.2, RL-140, CX-100, CX-50, C-75, 3 MCL82 link rooms, A8, 4001 relay and ambio
Page 1 of 1 (22 items)
