Latest post 02-14-2012 6:57 AM by Step1. 21 replies.
Page 1 of 1 (22 items)
  • 08-13-2007 1:25 AM
    Beovox RL 140's
    Three questions please....
    1) What problems arise? Are any of the speakers with foam surround??
    2) How do they sound in comparison to some of the powered speakers?  say connected to the Beocenter 9500
    3) Most importantly, has anyone "re-furbed" a set of these.....what tips to make them look new????
    Thanks..
  • 08-13-2007 2:43 AM In reply to
    Re: Beovox RL 140's
    1. Yes, they do suffer from foam rot.
    2. They sound excellent when driven by the correct amplifier. The 9500 is not really powerfull enough to show them at their best. It will loose control, in particular of the bass when driven hard. Much better with 5500/6500/7000. Just my opinion, others will not agree.
    3. Difficult to refurb as new because the cloth on the frets is unavailable. Some have re-covered with similar cloth but it is not to my personal taste. Unless B&O is perfect and looks original then I'm not really interested.
    Regards Graham
  • 08-13-2007 3:12 AM In reply to
    Re: Beovox RL 140's
    2. Agree with Graham. In common with the other big Beovox speakers, you need power to drive these multi driver units. One way would be to find some Beolab 200s. Have heard them drive a number of B&O speakers and they make a fantastic difference.
  • 08-13-2007 5:34 AM In reply to
    • PD
    • Top 500 Contributor
    • Joined on 03-27-2007
    • Eastbourne, England
    • Posts 210
    Re: Beovox RL 140's
    I've got mine hooked up to my BM6500 & they run fantastically.
    Hmmm, anyone know where I can get a new band for one? It's snapped & sort of flapping in the breeze created by the cones moving an immense amount from gorgeously loud & clear sound.
    PD "The difference betwixt erotic & kinky is that betwixt using a feather & using a chicken..."
  • 08-13-2007 7:04 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beovox RL 140's
    PD:
    Originals not available any more. This ebay seller does replacements but I've no idea how close they are to the originals.
    (I'm not connected in any way to this seller BTW and have no vested interest).
    Chris..
  • 08-13-2007 8:50 AM In reply to
    Re: Beovox RL 140's
    I've owned RL140 and used them with BeoSystem 7000. Excellent match in my opinion.
    I love RL speaker design and looks.  White RL 140 with white BeoSystem 7000 would be something special to own.
    David the BeoPerson
  • 08-13-2007 9:55 AM In reply to
    • PD
    • Posts 210
    Re: Beovox RL 140's
    beoperson:
    homer drool
    Chris - Thanks. Smile
  • 08-13-2007 10:28 AM In reply to
    Re: Beovox RL 140's
    Hi Graham...So on the "foam rot".....
    1) which of the drivers suffer from this???
     2) Are the foam surrounds available?? if so where and how much...
    Thanks,...Keith
  • 08-13-2007 12:58 PM In reply to
    Re: Beovox RL 140's
    The honest answer is I don't know!
    I've only had contact with one pair that had rot and the guy sent them to Recone in Huddersfield UK to be fixed.
    I assume it was the bass drivers.
    Regards Graham
  • 02-13-2012 5:34 AM In reply to
    Re: Beovox RL 140's
    I am thinking about getting this amp. How do you think they would sound with it?
    http://www.radiomuseum.org/r/marantz_pm_710_dc.html
  • 02-13-2012 11:16 AM In reply to
    • jam57
    • Not Ranked
    • Joined on 02-02-2010
    • Denver CO
    • Posts 27
    • Gold Member
    Re: Beovox RL 140's
    Hello, replacement straps are available from Iconic AV. There is no lettering as on the originals but these will work.
    John
  • 02-13-2012 2:12 PM In reply to
    • Beowulf
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    Re: Beovox RL 140's
    I had my driver surounds replaced by Recone Labs as mentioned above,all four cones came to about£250, they did a wonderful job returning them with rubber surrounds. Cool
    Beowulf
  • 02-13-2012 3:22 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: Beovox RL 140's
    Beowulf:
    Seems like a lot of money did they replace the coil and spider etc...? I do know they have (had?) a good reputation though!
    Olly.
  • 02-13-2012 4:01 PM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Re: Beovox RL 140's
    No just the rubber surrounds and testing
    Beowulf
  • 02-13-2012 4:10 PM In reply to
    Re: Beovox RL 140's
    Iconic AV's replacement straps are very good in my opinion.
    I received a pair of straps from them for some RL60.2's and they are as good as originals, except for there being no print on the straps.
    Yes -  thumbs up
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
  • 02-13-2012 7:57 PM In reply to
    Re: Beovox RL 140's
    Only the woofers suffer from foam rot. The midrange has a rubber surround. The I was able to refoam my pair without issue. Rather inexpensic
    BeoSystem 5000 (BM 5000, BG 5005, BC 5000, CD50), BeoCenter 3500, BeoCenter 2500, BeoLab 2500, BeoVox S-45, S-45.2, RL-140, CX-100, CX-50, C-75, 3 MCL82 link rooms, A8, 4001 relay and ambio
  • 02-14-2012 2:15 AM In reply to
    Re: Beovox RL 140's
    How much would a nirmal price for used ones be?
  • 02-14-2012 2:44 AM In reply to
    Re: Beovox RL 140's
    I've got a pair that you can have for nothing!!!
    All you have to do is come and collect them from Ely, Cambridgeshire, UK
    Regards Graham
  • 02-14-2012 3:04 AM In reply to
    Re: Beovox RL 140's
    I would so want to pick them up, but I am in Iceland :(
  • 02-14-2012 3:22 AM In reply to
    Re: Beovox RL 140's
    If everyone filled in their "location" in their profile we would all know that!!
    Regards Graham
  • 02-14-2012 5:06 AM In reply to
    • BenSA
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Re: Beovox RL 140's
    Here is a pic of one of my RL 140's that I recovered myself a while back. Hadn't put the straps on yet.
    Think I got the colour virtually identically as well as the texture of the material.
    Durban South Africa
  • 02-14-2012 6:57 AM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Re: Beovox RL 140's
    That is awsome where did you find the material? Also how did you do the letters - I am contemplating doing mine sometime soon and would be more than happy if it looked that good :)
    Olly.
