        1st March February 2012
	    Latest post 02-21-2012 9:17 AM by Krona . 16 replies.
								    |  02-19-2012 9:20 AM |  |
									                 Krona
 Joined on 07-11-2009SwedenPosts 72 |
										    My attyca 1 is in need of renovation. The bench has a scratched edge. Has anyone tried to restoring an attyca bench with a scratched edge? Do you have any good ideas to restore the edge? I'm thinking of putting an angled sheet of brushed aluminum or stainless steel.
 Beosystem 5500, Beovox M75, Beovox CX100 White, MCP5500, Beo4, Beolink 1000, Attyca 1 and Beocom 4. |  |
									                 Krona
										    Hi Blackrix, Thank you for your responding. Yes, that's probably a good idea. How about my suggestion? Beosystem 5500, Beovox M75, Beovox CX100 White, MCP5500, Beo4, Beolink 1000, Attyca 1 and Beocom 4. |  |
									                 Søren Mexico
 Joined on 09-13-2007Mexico cityPosts 1,621 |
										     Krona:
 To get a Aluminu angle look good, you will have to get it level to the surface, that means, machine the surface down where you want to place it, if you dont have the tools for it, imposible, if you have them, difficault. One mis and you will have to do the whole front/edge. Best and easiest is filler, sand, mask of, spray paint, sand very fine, spray paint, and one time more if wanted. Instead of filler, you can mix wood glue with 50 % wood dust (fine saw dust) it will give a harder edge. The key to the finish is sanding, sanding, sanding, finer, finer, finer   Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!! |  |
									                 Krona
										    There were many good suggestions. You seem to be on the same track. Now I have many good suggestions to consider. The bench will be renovated this summer and then the bench will have a different color. It will be painted in black. Thanks  Beosystem 5500, Beovox M75, Beovox CX100 White, MCP5500, Beo4, Beolink 1000, Attyca 1 and Beocom 4. |  |
									                 Leslie
 Joined on 05-07-2009NetherlandsPosts 2,201 |
										    Other option is using L shaped aluminium. Have been using that on my F1000's. Protects the edges and save you lots of work! Two types...
 B&O item 1, B&O item 2, B&O item 3,...................B&O item 735 Beovirus? What's that? |  |
									                 Krona
										    That looks very good. It is a good solution. I thought about putting transparent plastic on the edge. Johnny  Beosystem 5500, Beovox M75, Beovox CX100 White, MCP5500, Beo4, Beolink 1000, Attyca 1 and Beocom 4. |  |
									                 Søren Mexico
										     Krona:
 Just dont tell Graham about it, you are manipulating original B&O items . If an aluminum edge, in my opinion it has to be flush with the surface and not upon the surface, its a dirt catcher. Transparent plastic is very diff. to paint. Johnny please save yourself some trouble, filler or glue or plastic padding, sand to smooth, paint, sand, paint. There are no short cuts that works   Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!! |  |
									                 Leslie
										     Søren Mexico:If an aluminum edge, in my opinion it has to be flush with the surface and not upon the surface, its a dirt catcher.
 Dirt catcher? Hmmmm, aren't B&O vintage stuff all dirt catchers. My F1000 looks brilliant with these aluminium edges, much better then the original! B&O item 1, B&O item 2, B&O item 3,...................B&O item 735 Beovirus? What's that? |  |
									                 Krona
										    Sören, I really like your avatar.    Beosystem 5500, Beovox M75, Beovox CX100 White, MCP5500, Beo4, Beolink 1000, Attyca 1 and Beocom 4. |  |
			     Page 1 of 1 (17 items)  |
