1st March February 2012
Latest post 02-21-2012 9:17 AM by Krona. 16 replies.
02-19-2012 9:20 AM
Krona
- Joined on 07-11-2009
- Sweden
- Posts 72
My attyca 1 is in need of renovation. The bench has a scratched edge. Has anyone tried to restoring an attyca bench with a scratched edge? Do you have any good ideas to restore the edge?
I'm thinking of putting an angled sheet of brushed aluminum or stainless steel.
Beosystem 5500, Beovox M75, Beovox CX100 White, MCP5500, Beo4, Beolink 1000, Attyca 1 and Beocom 4.
Krona
- Sweden
- Posts 72
Hi Blackrix,
Thank you for your responding.
Yes, that's probably a good idea. How about my suggestion?
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Krona:
Hi Blackrix,
To get a Aluminu angle look good, you will have to get it level to the surface, that means, machine the surface down where you want to place it, if you dont have the tools for it, imposible, if you have them, difficault. One mis and you will have to do the whole front/edge.
Best and easiest is filler, sand, mask of, spray paint, sand very fine, spray paint, and one time more if wanted.
Instead of filler, you can mix wood glue with 50 % wood dust (fine saw dust) it will give a harder edge.
The key to the finish is sanding, sanding, sanding, finer, finer, finer
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Krona
- Sweden
- Posts 72
There were many good suggestions. You seem to be on the same track. Now I have many good suggestions to consider. The bench will be renovated this summer and then the bench will have a different color. It will be painted in black.
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Other option is using L shaped aluminium. Have been using that on my F1000's. Protects the edges and save you lots of work!
Two types...
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Krona
- Sweden
- Posts 72
That looks very good. It is a good solution. I thought about putting transparent plastic on the edge.
Johnny
Søren Mexico
- Mexico city
- Posts 1,621
Krona:
Johnny
Just dont tell Graham about it, you are manipulating original B&O items . If an aluminum edge, in my opinion it has to be flush with the surface and not upon the surface, its a dirt catcher. Transparent plastic is very diff. to paint.
Johnny please save yourself some trouble, filler or glue or plastic padding, sand to smooth, paint, sand, paint. There are no short cuts that works
Leslie
- Netherlands
- Posts 2,201
Søren Mexico:If an aluminum edge, in my opinion it has to be flush with the surface and not upon the surface, its a dirt catcher.
Dirt catcher? Hmmmm, aren't B&O vintage stuff all dirt catchers. My F1000 looks brilliant with these aluminium edges, much better then the original!
Krona
- Sweden
- Posts 72
Sören,
I really like your avatar.
Page 1 of 1 (17 items)
