Latest post 02-21-2012 9:17 AM by Krona. 16 replies.
Page 1 of 1 (17 items)
  • 02-19-2012 9:20 AM
    • Krona
    • Not Ranked
    • Joined on 07-11-2009
    • Sweden
    • Posts 72
    • Gold Member
    Attyca 1 project
    My attyca 1 is in need of renovation. The bench has a scratched edge. Has anyone tried to restoring an attyca bench with a scratched edge? Do you have any good ideas to restore the edge?
    I'm thinking of putting an angled sheet of brushed aluminum or stainless steel.
    Attyca 1 project
    Beosystem 5500, Beovox M75, Beovox CX100 White, MCP5500, Beo4, Beolink 1000, Attyca 1 and Beocom 4.
    Filed under: , , ,
  • 02-19-2012 11:31 AM In reply to
    Re: Attyca 1 project
    I think a filler, sanding and repainting might do the job.
  • 02-19-2012 11:37 AM In reply to
    • Krona
    • Not Ranked
    • Sweden
    • Posts 72
    • Gold Member
    Hi Blackrix,
    Thank you for your responding.
    Yes, that's probably a good idea. How about my suggestion?
  • 02-19-2012 12:05 PM In reply to
    Krona:
    Hi Blackrix,
    To get a Aluminu angle look good, you will have to get it level to the surface, that means, machine the surface down where you want to place it, if you dont have the tools for it, imposible, if you have them, difficault. One mis and you will have to do the whole front/edge.
    Best and easiest is filler, sand, mask of, spray paint, sand very fine, spray paint, and one time more if wanted.
    Instead of filler, you can mix wood glue with 50 % wood dust (fine saw dust) it will give a harder edge.
    The key to the finish is sanding, sanding, sanding, finer, finer, finer
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 02-19-2012 12:41 PM In reply to
    I think with an angled piece of stainless steel or aluminium it will be harder to get a nice fit than the use of a filler and sandpaper. If you take some time for it you will get a nice result. And if you go to a good store they can probably supply you with the right colour paint in a spraycan.
  • 02-19-2012 12:42 PM In reply to
    • michgal
    • Not Ranked
    • Joined on 12-27-2007
    • Eindhoven, Netherlands
    • Posts 60
    What about stripping of the old veneer from the sides and aplying a new white thick fineer, plus having a paint job!
  • 02-19-2012 3:26 PM In reply to
    That is a way to get it done, but I think that might be the hard way.
  • 02-20-2012 1:32 AM In reply to
    • Krona
    • Not Ranked
    • Sweden
    • Posts 72
    • Gold Member
    There were many good suggestions. You seem to be on the same track. Now I have many good suggestions to consider. The bench will be renovated this summer and then the bench will have a different color. It will be painted in black.
    Thanks Smile
  • 02-20-2012 2:52 AM In reply to
    • Paul
    • Top 500 Contributor
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    You can use a filler (epoxy) from the car industry, it will get very hard and you can sand it till the surface is smooth.  Normal filler will not hold.  When you use the colour black, it needs a real flat surface with out dents etc etc.  On black you will see every scratch/dent because of the light refelection.
    Do you have considered a metalic silver finish?
  • 02-20-2012 6:42 AM In reply to
    • Krona
    • Not Ranked
    • Sweden
    • Posts 72
    • Gold Member
    Thanks for the tip. Epoxy is probably a good choice. I will paint the bench, as a suggestion, in two colors. Black and dark gray. Silver Metallic's not my favorite color.
  • 02-20-2012 6:09 PM In reply to
    Other option is using L shaped aluminium. Have been using that on my F1000's. Protects the edges and save you lots of work!
    Two types...
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 02-21-2012 12:52 AM In reply to
    • Krona
    • Not Ranked
    • Sweden
    • Posts 72
    • Gold Member
    That looks very good. It is a good solution. I thought about putting transparent plastic on the edge.
    Johnny Smile
  • 02-21-2012 1:05 AM In reply to
    Krona:
    Johnny Smile
    Just dont tell Graham about it, you are manipulating original B&O itemsLaughing. If an aluminum edge, in my opinion it has to be flush with the surface and not upon the surface, its a dirt catcher. Transparent plastic is very diff. to paint.
    Johnny please save yourself some trouble, filler or glue or plastic padding, sand to smooth, paint, sand, paint. There are no short cuts that works
  • 02-21-2012 3:06 AM In reply to
    • Krona
    • Not Ranked
    • Sweden
    • Posts 72
    • Gold Member
    Whistle I think a black plastic strip would be the solution because the bench will be painted in two colors. Black and dark gray. Or a thin strip of wood that is glued with wood dowels.
  • 02-21-2012 6:27 AM In reply to
    Søren Mexico:
    Dirt catcher? Hmmmm, aren't B&O vintage stuff all dirt catchers. My F1000 looks brilliant with these aluminium edges, much better then the original!
  • 02-21-2012 8:26 AM In reply to
    • Krona
    • Not Ranked
    • Sweden
    • Posts 72
    • Gold Member
    Sören,
    I really like your avatar. Drinks
  • 02-21-2012 9:17 AM In reply to
    • Krona
    • Not Ranked
    • Sweden
    • Posts 72
    • Gold Member
    I've found a solution:
