Latest post 02-05-2012 8:22 AM by Søren Mexico. 5 replies.
Page 1 of 1 (6 items)
  • 02-04-2012 3:41 AM
    Beovox RL 140
    i have a pair of bang and olufsen RL 140s and on the back plate that is metal has 4 screw holes that are empty i dont know what they are for  i want to wall mount them but cant find wall mounts for them, im wondering if i used a flat panel tv mount can i use these screw hole to attach them to it or are the used for something else that might not support the weight does anyone know what they are for and if they can be used for this any info will be great thankyou in advance.
    Taylor T
  • 02-04-2012 4:57 AM In reply to
    • Paul
    • Top 500 Contributor
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    Re: Beovox RL 140
    Hi and welcome to tis wonderfull forum.  You are right those 4 holes are for mounting a face plate for wall mount or one for seeling Also they can be used for the floorframe.
    You could use flatpanel mounts, but you can ask member Leslie here on the forum, maybe he can help you with original mounts.
  • 02-04-2012 5:03 AM In reply to
    Re: Beovox RL 140
    i was hoping i could use them for wall mounting didnt know if the would hold lol and thanks for the welcome my bro is a big time member said if there was anyone who might know it was you guys guess ill try holding it up by those 4 points
  • 02-04-2012 9:30 AM In reply to
    bangand0lufsen:
    The 4 M5 threaded holes on the speaker back plate is just for an incline adjusting screw, to hang them on the wall you will need this.
    The upper plate is the one that hooks into the speaker, in the middle you see the swivel mount, thats optional, lowest is the wall plate, the plate with the hooks can be mounted directly on the wall plate, and the speakers will be mounted flat on the wall. The pic I stole from Leslie.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 02-05-2012 5:05 AM In reply to
    Re: Beovox RL 140
    I wish i could find the org mounts sadly i do not have them was trying to make some kind of make shift mount maybe parts from a flatpanel tv mount was hoping the 4 empty screw holes on the back of the rl 140 would be able to hold and support the speaker but sounds like they might not be strong enough still racking my brain on it want to find away to do it before i move to the new apartment. got a wallmount that has hooks that mounts to a stud might be able to have it clip on it not sure if it will work. the fun of owning older speakers lol
  • 02-05-2012 8:22 AM In reply to
    Re: Beovox RL 140
    you will have to make 2 of these and fasten them to your wall mount
