bangand0lufsen:
i was hoping i could use them for wall mounting didnt know if the would hold lol and thanks for the welcome my bro is a big time member said if there was anyone who might know it was you guys guess ill try holding it up by those 4 points
The 4 M5 threaded holes on the speaker back plate is just for an incline adjusting screw, to hang them on the wall you will need this.
The upper plate is the one that hooks into the speaker, in the middle you see the swivel mount, thats optional, lowest is the wall plate, the plate with the hooks can be mounted directly on the wall plate, and the speakers will be mounted flat on the wall. The pic I stole from Leslie.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
