Hi Peter and anyone else listening.
I just installed a Beosystem 7000 (my first B&O system) that I sourced locally. There was a white unit (6500) at Lifestyle in the UK, however the price difference for a white unit as well as shipping charges to Switzerland was a bit to high for me.
I think that I may have a problem; the unit was supplied with a Beolink 1000 and so far I have not been able to program radio stations or even search for them. All I can do is tune in the ones that were set up in the shop.
I don't have an instruction manual,but I should receive one in a few days (weeks). I managed to download the 6500 user guide from B&O however it only mentions the Beolink 7000 (pricey)
Also the RDS does not seem to be working.
What also concerns me is the date on the back of the units (1987) I thought that the 7000 series was manufactured only after '92.
If you or anyone can help, it would be much appreciated
By the way, other than listening is there any way to really tell if the speakers are hooked up correctly (+-)
my Beovox 5000 only had bare wires and no colors to indicate + and -
Andrew
