Finnally received the cubes in the post on Friday.
I connected them in the traditional way as for now I don't feel like lentgthening the wires,
Initially I was disapointed as there was almost no sound coming out of them, but after trying out some different pices of music, I really found that they could improve on the 5000's alone. (Time / Dark side of the moon)
Given that my dinning room is at 180° from where the speakers are, you can really notice the difference. Also at low volumes I find that I am no longer constantly turning up the treble.
The units are in "Ok" condition (given their age) however I plan on sanding them down and fixing all the chipped edges and then spray paint them back to as original as I can.
Does anyone know if the speaker grills can be just popped out or are they glued in position.
Any help on restoring would be apreciated.
Regards to all
Andrew
