1st March February 2012
Latest post 09-28-2011 12:02 PM by deaddruid. 11 replies.
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
Bang & Olufsen have an IR-Y adaptor part number 7229212. The two jack sockets are colour coded, one is chrome the other is gold. This enables you to differentiate between STB (V.AUX) and STB (SAT).
The Bang & Olufsen emitter cables are a standard length but I'm sure that you could source other lengths from Xantech possibly?
Hope that helps.
Opman
deaddruid
- Joined on 05-24-2007
- Malvern, Worcestershire
- Posts 247
Oh! I didn't realise that the outputs were different. I'd assumed that the two emitters simply went in parallel, so I would need (for example) to avoid having two Humax boxes, but instead have a Topfield and a Humax, to avoid the control signals getting mixed up. If the splitter provides different signals to each emitter, that problem goes away.
Do you have any experience of using non-B&O IR blasters? I've noticed that a few people make them, but have little idea of what is compatible with what.
Mark
Opman
- Cheshire, UK
- Posts 323
deaddruid:
You can have two boxes that are the same, you just need to remeber which is configured to V.AUX and which is SAT/DTV etc.
The splitter is simply a jack plug adaptor with two sockets on the back.
Opman
deaddruid
- Posts 247
Surely not! If the same signals go to each box, then I need to ensure that they have different command sets, to avoid them responding to the same commands. Otherwise, when I tell one to record channel 2, the other will also record channel 2.
Mark
deaddruid
- Posts 247
I think that the confusion here is over the Y adaptor. Does the STB-C output have a "mono" jack socket (two connections) or a "stereo" socket (three connections). If the former, then both boxes will get the same signals. If the latter, then they can have separate data.
I had thought the Avant output was of the former type. Is it actually of the latter?
Mark
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
I see what you mean, I didn't think of that and have no first hand experience.
I checked one Avant service manual at random, and it specifically mentions a stereo jack, and the wiring diagrams show two separate signals, so I'd put my money on that it will work. You should be able to confirm that in practice even with just a single STB and no splitter; it should only respond to either SAT or V.AUX even if you configure the same STB type on both.
deaddruid
- Posts 247
Good point. I'll give it a try tonight.
Mark
Opman
- Cheshire, UK
- Posts 323
I can testify that this works as long as your Avant is a 32" version. The 28" chassis doesn't allow two STB to be connected.
Opman
PS can anybody tell me what size pictures I should be uploading?
tournedos
- Finland
- Posts 5,808
Opman: PS can anybody tell me what size pictures I should be uploading?
There's
no hard limit I guess, but if you keep the width to some 720 pixels or
below, the dreadful horizontal scrollbar won't be needed.
Thanks for the exact answer to the problem - I think it was indeed a 32" RF manual I found on the site
deaddruid
- Posts 247
It's a 32" RF VCR, so this all looks good. Thank you all for being so helpful.
Mark
Page 1 of 1 (12 items)
