1st March February 2012
Latest post 10-19-2011 4:15 PM by Larskoelle. 61 replies.
Raeuber
- Joined on 12-02-2007
- Posts 986
Re: Isn't it time for a "new" Beolab 5?
White BL 5 looks fine, but it doesn't fit with my living room. Aluminium instead of the dominating black could be a solution for me (and my one and only lovely wife), but production would be very difficult. /Räuber
Maab
- Joined on 09-03-2011
- Posts 70
Thanks for all the replies. I do have millions of questions thou. I'll try to limit to a few more if I may. The web site states that this speaker could be positioned near a corner. In my case one of them would -2 to 3 feet. Does anyone have had such experience to share?
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Mine are only about 40-50cm from the walls, works just fine due to the calibration. Sure they sound better when they get a bit of air around them.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
bayerische:
beocool:
Raeuber:Hi bayerische,
it not only depends on the neighboors, but also on wife, my wife also hates the look of Beolab 5, so I'm not allowed to buy them (without changing wife).
/Räuber
That's probably why I'm single.
Can't say my wife loves mine, but mine are white, and that always helps....
Mine are black. Now I know what I've been doing wrong
beocool
- the Netherlands
- Posts 5,514
bayerische:
About the same over here and I have the sam observation.
Mr10Percent
- Joined on 04-16-2007
- In Transit
- Posts 441
Sound just fine close to the wall.
Sound ok in small rooms too and dont fill too much space either.
Maab
- Posts 70
You have been very helpful. Thank you for taking the time to share your knowledge. Please, this is my last question, and perhaps its what worries me the most: I am not sure about the connection options fir a non B&O pre-pro. I have a Denon a1hdci processor and this device does not have digital outs, as far as I know. My understanding is that the BL5 accepts incoming sound throughout analog RCA cable. If that's correct, what are the compromises by doing this? Are the speakers performing the room correction still after the analog inputs (> D/A)? thanks again.
Maab
- Posts 70
Please disregard my last post. I am now reading the BL5 users manual I found online. However, I am sorry to say that unfortunately I will not buy the B&O speakers at this time because of the "need" to use a separate remote control. If it was just me in the apartment i would have maybe dealt with it, but I can't complicate things that should be as normal as pushing just one button on one remote to power the whole system. Oh well...
Stephan
- Joined on 12-20-2008
- Germany
- Posts 242
To answer your question: The only upgrade of the Beolab 5 is adding ANOTHER Pair of Beolab 5's :-)
The 5's are perfect the way they are in every aspect and B&O have to concentrate on the other end of their product portfolio
The current portfolio needs more entry level products to get new customers not a Beolab X which is above the 5's or below the 5's... In terms of speakers the B&O portfolio is very well positioned from updated classics (6002 / 8002) to smaller space saving solutions ( 4000 / 4 / 3 ) to above midrange (9) and finally the flagships (5s) also add 2 differen subwoofers, in-wall speakers and center speakers.
Anyway if B&O will develop someting to replace or to be above the 5's with the same radical approach for a reasonable price (not talking cheap here...) I'm in!
Stephan
f5434964
- Joined on 07-21-2010
- Posts 198
because of the many possibilties doing the "set up" of the BL5s - is there a chance doing this on my own or do I always need an expert helping me?
Maab
- Posts 70
Yes, Why not another Beolab 5? Perhaps with an hdmi connection? It would make life easier. I don't want to use their remote control for volume control either (by the way, my understanding is that even with analog connection it would apply) and another for changing a non-beo tv channels. That doesn't simplify things for me.
bayerische
- Helsinki, Finland
- Posts 3,593
Honestly, I think you got a little "fuzzy" about the Beolab 5's suddenly...
I'm guessing you have a bunch of different branded equipment, since I can't recall Denon making a TV set. Why not just get a universal remote? The higher end ones can handle the different frequency of B&O remotes, or you get a Beo6, have Keith program it for you, and voila! you have a B&O remote that turn heads, and can control all your equipment.
-Andreas
Beology
- Joined on 04-29-2007
- Posts 42
Hi Andreas,
Im getting some lab5s once my renovation is done. Does the Beo6 need some modification/go between to control other equipment? I have a Pioneer quipment, B and O and Foxtel (australian pay tv) and would love a universal B &O remote. Whos Keith?
Thanks for any insights Andreas.
JR
stefan
- 200 miles from Struer
- Posts 1,733
There is no need for a new Beolab 5.
What should be improved? All my life I thought about speakers, listened to "new" speakers, wishing new speakers...since I got my BL5s about five years ago. BL5s are small - yes, as a 4way active speaker set with built in 2500 W amps and a 15 inch woofer, they are very small - They sound great, they are easy to set up - thanks to the calibration system and acoustic lenses.
Why not a "pro"-version of BL5 with balanced inputs and maybe external amps and a special woofer with 2x15 inch woofers to match different studio facilities and control rooms? I think Dave Moulton has some BL5s in his studio....
@Beology: Keith is Keith Saunders, expert of the Beo5/6
@Maab: HDMI connection transfers digital picture, audio and hdcp. BL5 just need digital audio - spdif.
Why not use a Beo4/5/6 for your equipmment? Just use an IR converter like the TT455 box from Lintronic. www.lintronic.dk
@Mr10Percent: a nice clean setup - congratulations! My BL5s are also close to the wall (about 50 cm). Sounds great...
Stefan
bayerische
- Helsinki, Finland
- Posts 3,593
Beology:
Hi Andreas,
JR
Yes, you'll need the XML files for the other makes, such as your Pioneer TV.
Keith is our tech guy here, and he offers the Beo5 remote control programming service that can be seen on a banner. I highly recommend him.
-Andreas
bayerische
- Helsinki, Finland
- Posts 3,593
Nice setup indeed 10%.
Pretty much like mine, except for the Beosound5.
But is that a forrest outside your window?
-Andreas
Mr10Percent
- In Transit
- Posts 441
bayerische:
Unfortunately I cant choose my neighbours!
The flat is very small. The lounge is only 5mx3m but everything seems to work size-wise with the BV10-46 and the BL5s (BL3 at the rears with cheaky Beolink cable going under the BV stand and the rug. Does not seem too for the room for me. Even the GF is happy!
10
Mr10Percent
- In Transit
- Posts 441
bayerische:
Thanks!
The flat is very small. The lounge is only 5mx3m but everything seems to work size-wise with the BV10-46 and the BL5s (BL3 at the rear on stands with the cheaky Powerlink cable going under the BV stand rug and sofa. Does not seem too much for the room for my liking. Even the GF is happy!
10
Maab
- Posts 70
Ok, I take that (old post) back. I just purchased a set of beolab 5!!!
rfc1
- Joined on 02-06-2008
- Posts 166
Nice one mate.
I will buy a pair next year after paying off my house extension......!!!
Sandy
Maab
- Posts 70
...already I can't wait to receive them.
Inevitable question, please: the dealer says that I don't need the beo4 remote, but I read elsewhere it's a necessity. Any thoughts?
I'm connecting the speakers to a processor via analog input, for now anyway
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
stefan:
According to my dealer, a speaker that sits above the BL5 was discussed at the recent dealer conference.
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
Maab: the dealer says that I don't need the beo4 remote, but I read elsewhere it's a necessity. Any thoughts?
If the BLB 5s are brand new, you'll need a Beo4 to enter the PIN-codes as a 1st step and to deactivate the PIN protection in a 2nd step. ATTENTION: ONLY ONE speaker should be connected to the mains while entering / deactivating the PIN.
If PIN is not deactivated and mains is interrupted for more than 1/2 hour you'll have to reenter the PINs again - impossible wo remote).
If connected via analog line input volume is controlled externally by the external preamp/processor and no Beo4 is required for daily use.
Only if connected digitally via SPDIF you'll need a remote for daily use (eg a Beo4) to control the volume.
Maab
- Posts 70
That's great! 5 hours after my BL5 purchase... If it's true, I wouldn't be surprised. Its not the end of the world, but ideally if these speakers where able to process dts, flac, DVDs or whatever it would be a further step above.
Steffen
- Joined on 06-24-2008
- Denmark
- Posts 281
Maab:I don't recall where I read it, but some people were bashing B&O for using "cheap "Vifa" drivers. But I didn't think they were reliable sources.
There are some people who just love to spread rumors about B&O -don't listen to them! Some just love to hate B&O, because they don't think that something that looks good can actually sound good. Some hi-fi 'fundamentalists' think that hi-fi equipment must be ugly
I have heard "hi-fi" people criticize BL5 -some have never even heard them!!! Some have heard them briefly in a store -maybe not under the right condition. The funny thing is, that these persons are very devoted to furnishing their entire livingroom after their own speakers -and say, that you can not judge the sound only by what you hear at the dealer...but they judge B&O that way  Talk about 'double standards' and bigotry...
