1st March February 2012
Latest post 11-18-2011 7:44 PM by Todd. 406 replies.
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Re: RL60.2 Refurb Collaboration
Oh man, I'm really enjoying this kind of threads. This really turns me on as quoted by another member
Todd, excellent start with the master as your tutor
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Hey Leslie!
Soon, I think tomorrow, we will be changing the fret cloth!
Leslie
- Netherlands
- Posts 2,201
Looking forward! Is Todd gonna do the job
Leslie
- Netherlands
- Posts 2,201
Forgot to ask. Embossing of the logo is also part of the job?
Evan
- Ohio | USA
- Posts 2,601
Todd has done a lot of work so far, we are each doing one speaker. We only had a little bit of time yesterday, so I did have to step in and hurry things.
The logo is molded into the resin cabinet, yes? I was going to use spray adhesive to get the new cloth to stick.
Leslie
- Netherlands
- Posts 2,201
That's the way but don't put the cloth on to soon or else the glue comes through. Use a sort of rubberized roller after (e.g. what you use for wallpaper) to press it in.
What I did was stretching the cloth first horizontally (for the printed area only) and at the same time press it on the embossing. You need 4 hands to do this. After that use some good quality ds thin tape (or glue) to put on the surrounding of the cabinet and the 2 straps areas. The rest is clear I guess....
I hope I have made myself clear in my dutchenglishamerican Good luck and if you have better ideas please let me (us) know! Always willing to learn...
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Evan and Todd, pics please, Leslie gets turned even more on with detailed pics
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Søren Mexico
- Mexico city
- Posts 1,621
BTW did you change the resistors, and did you get the midrange OK.
Leslie
- Netherlands
- Posts 2,201
Søren Mexico:
Not to many please , btw I miss my Eugene, where is this person....
Evan
- Ohio | USA
- Posts 2,601
Leslie:
Me too! I appreciate the tips Leslie.
BTW, your English is just fine
Evan
- Ohio | USA
- Posts 2,601
Leslie:
Søren Mexico:
I have one pic to add from today.
I have also noticed Eugene's absence, I should go check on him!
Evan
- Ohio | USA
- Posts 2,601
Here is one of the speakers on my drafting table just after measurments. Todd has been at work today and I was too excited to wait for him! Plus, this is a problem that needs fixing ASAP, school starts in a few weeks.
I measured everything and found some interesting results;
Component
Factory Specification
Good Speaker
Bad Speaker
Tweeter
6 Ω
1.2 Ω
1.3 Ω
Mid-Woofer
8 Ω
3.6-3.7 Ω
8.1 Ω
Woofer
8 Ω
3.5-3.7 Ω
6.1 Ω
6R8 5% > X0
6.8 Ω
6.8 Ω
6.8-7.2 Ω
15R 10% > X7
15 Ω
14.7 Ω
~15.1 Ω
22 Ω ??
1.3 Ω
1.3 Ω
1R0 5%
1 Ω
0.8-0.9 Ω
0.9 Ω
I'm starting to think that the brighter upper-midrange is due to the driver having lower impedance. The resistors between both speakers are almost identical.
What can you all make of this?
Leslie
- Netherlands
- Posts 2,201
I don't think it's harmfull, it's a sort of isolation material made of glass wool and can be very itchy when the inside touches the skin.
Evan
- Ohio | USA
- Posts 2,601
Leslie:
Yes, fiberglass does itch. I'm suprised to hear it is fiberglass, I've never been able to smell fiberglass before.
EDIT: Just noticed that in the service manual, the material is defined as "rock wool"
Evan
- Ohio | USA
- Posts 2,601
Just made an interesting discovery, although I shouldn't be hugely suprised considering my above data, the speakers overall impedance is vastly different.
Factory Spec: 8 ohm Good Speaker: 3.7-3.8 ohm Bad Speaker: 7.8 ohm
Anyone want to start a brainstorm?
Evan
- Ohio | USA
- Posts 2,601
Søren Mexico:
Didn't change the resistors, don't really think I need to.
And in short, no. The midrange problem persists. I've been exercising the new caps and they came even closer together but still - one speaker is a little brighter (for the better) in the vocal department.
However the gap is not wide enough to keep them from being enjoyed. Last night my parents watched two episodes of 24 and were impressed. I've been listening to them play music during many of these posts in this thread.
Todd
- Joined on 09-01-2009
- Columbus Ohio
- Posts 136
Hey Evman, I'm Baaaack
I've been trying to catch-up on your. "not waiting on Todd too excited to wait busy little fingers at work. Nevertheless I'm
provoked in wanting too know what you or Leslie or Soren think what is causing the higher impedance in the bad speaker and is it relatively
simple to fix and in cost? BTWY do I have the understanding correct in my question....that the impedance being higer is a block so to speak to the bad speaker not being able to project equal levels of soud as the good one but as you say. that not withstanding it is still Terrificly
Enjoyable as your family R expieriencing
Evan
- Ohio | USA
- Posts 2,601
There he is!
Yes, fundamentally it seems there is a impedance issue. Looking at the numbers, I am suprised the first hand audible difference is so subtle! Your understanding is spot on.
I just took another measurement and the good speaker holds its 3.8ohms while the other has dropped to 7.3 ohms from 7.8. This time I measured at the spring terminals with the speakers disconnected from the amp. The previous measurement was done on the DIN connections on the corner. Still a BIG difference.
Todd
- Columbus Ohio
- Posts 136
O.K. 7.8 to 7.3 diff. Yesterday you seem to be ready to change the resistors but it seems after further meter testing you have come to the
conclusion that the diff between the 2 speakers as it relates to the resistor reading were not great enough so what was that reading? will you
re direct me in your answer by referring back to open speaker picture in the post just where the resistors are located? I cannot recall if they
r on the circuit pannel or placed in side the drivers! Why does Soren seem to think 10% of'em need to be changed as a standard?
TC
Evan
- Ohio | USA
- Posts 2,601
The last 2 measurements I have made are that of total impedance. The entire speaker's impeadance - the load ultimately felt by the amplifier.
Here are the actual resistors (circled in red), on the crossover board.
Evan
- Ohio | USA
- Posts 2,601
Regarding the solution..
Earlier when I was taking the more detailed measurements of the individual components. All but the inductors, probably a good idea to check them, but since these crossovers haven't been toasted by some disco central party host, they will probably check out fine.
I think the root problem is the actual impedance of the drivers - plain and simple.
Todd
- Columbus Ohio
- Posts 136
O.K. I'm understanding this a little better now. Thanks for the circling of the resistors.
love that' however I do have some follo-up questions but they will have to wait till I see ya tomorrow. I'm at Panera Bread and need too Take Off ! see ya later
TC
Søren Mexico
- Mexico city
- Posts 1,621
Leslie:
Rock wool, made from stone and wooled at very high temps used as termal insulation in houses mainly in northern Europe, has more less the same termal quotient as Glass wool, and is more itchy than Glass wool
