Latest post 07-28-2011 12:48 PM by f5434964. 9 replies.
Page 1 of 1 (10 items)
  • 07-27-2011 7:49 PM
    DIFFERENCE BETWEEN MK1, MK2 & MK3 BEOSOUND 9000 !!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Is there anyone out there that could tell me how i can tell apart a MK1 from a MK2 and MK3 on BEOSOUND 9000 (6 cd) either physically or functionally or maybe year of manufacture - what are the differences ?????????????????????????????
    HELPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP.
  • 07-28-2011 12:20 AM In reply to
    Re: DIFFERENCE BETWEEN MK1, MK2 & MK3 BEOSOUND 9000 !!!!!!!!!!!!!!!!!!!!!!!!!!!!
    physicaly only 1 difference between them
    there is on/off red button at the bottom of mrk-1
    as my knowledge
  • 07-28-2011 2:19 AM In reply to
    The MK I model is upgradeable for N-Music
    The MK II model is upgradeable also
    The MK III has a different CD mechanism and PIN code security. The glass plate has also undergone several updates as the earlier ones tended to come loose.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 07-28-2011 2:39 AM In reply to
    jimbojimbo3:
    From the type number printed on the label under the keyboard!
    Mk1 is 252*
    Mk2 is 256*
    Mk3 is 257*
    where * depends on the country of use and is 2 for UK models.
    Regards Graham
  • 07-28-2011 9:33 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    iiiRshad Khan:
    as my knowledge
    The mark 1 certainley had the red on/off button. At some point in production this was removed. It was re-introduced last year to comply with legislation regarding power consumption, so mark 3's have this button now.
    Opman
  • 07-28-2011 9:42 AM In reply to
    Not all MK3 have the pincode.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 07-28-2011 9:46 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Your keyboard needs to be exchanged.... CAPS, ?, ! and P don't seem to work anymore.
    Smile
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 07-28-2011 12:29 PM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Search this forum, you Will find the answer.
  • 07-28-2011 12:37 PM In reply to
    ROTFL, you make me laugh hard :)
  • 07-28-2011 12:48 PM In reply to
    have a look
    http://www.beoworld.org/prod_details.asp?pid=954
    regards elmar
