1st March February 2012
Latest post 07-28-2011 12:48 PM by f5434964. 9 replies.
07-27-2011 7:49 PM
jimbojimbo3
- Joined on 02-19-2011
- Posts 13
DIFFERENCE BETWEEN MK1, MK2 & MK3 BEOSOUND 9000 !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Is there anyone out there that could tell me how i can tell apart a MK1 from a MK2 and MK3 on BEOSOUND 9000 (6 cd) either physically or functionally or maybe year of manufacture - what are the differences ?????????????????????????????
HELPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP.
iiiRshad Khan
- Joined on 09-09-2008
- India
- Posts 20
Re: DIFFERENCE BETWEEN MK1, MK2 & MK3 BEOSOUND 9000 !!!!!!!!!!!!!!!!!!!!!!!!!!!!
physicaly only 1 difference between them
there is on/off red button at the bottom of mrk-1
as my knowledge
Heribert
- Joined on 08-06-2009
- Austria
- Posts 592
The MK I model is upgradeable for N-Music
The MK II model is upgradeable also
The MK III has a different CD mechanism and PIN code security. The
glass plate has also undergone several updates as the earlier ones
tended to come loose.
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
jimbojimbo3:
From the type number printed on the label under the keyboard!
Mk1 is 252*
Mk2 is 256*
Mk3 is 257*
where * depends on the country of use and is 2 for UK models.
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
iiiRshad Khan:
as my knowledge
The mark 1 certainley had the red on/off button. At some point in production this was removed. It was re-introduced last year to comply with legislation regarding power consumption, so mark 3's have this button now.
Opman
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Not all MK3 have the pincode.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Your keyboard needs to be exchanged.... CAPS, ?, ! and P don't seem to work anymore.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Search this forum, you Will find the answer.
Mindphaser
- Joined on 07-18-2011
- Italy
- Posts 15
ROTFL, you make me laugh hard :)
f5434964
- Joined on 07-21-2010
- Posts 198
have a look
http://www.beoworld.org/prod_details.asp?pid=954
regards elmar
Page 1 of 1 (10 items)
