Dear all,
I am just about to buy or give back a Cambridge DacMagic. Right now I have the following setup:
iMac -> USB -> DACMagic -> Beoport with BL6000 and port into my ML Network.
Also in the ML Network are:
Mainroom: BV8-40; BS3200; BL3; ATV2
Linkroom 1: BV8-32; ATV1  /  Linkroom 2: BL2000
If I change now to BS5 Encore (instead of BS3200) then I will still use the iMac or the attached TimeCapsule as storage for music. But I guess I will not need any DAC anymore, because the Beoport becomes obsolete. Correct? Is there still any use for a DAC?
I assume that B&O brings out the ML<->Beonet converters quickly and one of these is in front of each "old" B&O Product.
Thanks for clearing this up a little.
Heribert
									    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
