Latest post 03-05-2011 7:54 PM by TripEnglish. 3 replies.
Page 1 of 1 (4 items)
  • 03-05-2011 7:43 AM
    Beosound 5 Encore: Will I still need a DAC?
    Dear all,
    I am just about to buy or give back a Cambridge DacMagic. Right now I have the following setup:
    iMac -> USB -> DACMagic -> Beoport with BL6000 and port into my ML Network.
    Also in the ML Network are:
    Mainroom: BV8-40; BS3200; BL3; ATV2
    Linkroom 1: BV8-32; ATV1  /  Linkroom 2: BL2000
    If I change now to BS5 Encore (instead of BS3200) then I will still use the iMac or the attached TimeCapsule as storage for music. But I guess I will not need any DAC anymore, because the Beoport becomes obsolete. Correct? Is there still any use for a DAC?
    I assume that B&O brings out the ML<->Beonet converters quickly and one of these is in front of each "old" B&O Product.
    Thanks for clearing this up a little.
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
    Filed under: ,
  • 03-05-2011 9:37 AM In reply to
    Re: Beosound 5 Encore: Will I still need a DAC?
    Nope. The DAC is in the BeoSound 5 Encore.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 03-05-2011 12:47 PM In reply to
    Hi Trip,
    Do you have info when the ML to Net converters will be available?
    Thanks, H.
  • 03-05-2011 7:54 PM In reply to
    A lot later than I'd like. The only estimate I've heard is fall, but a few other things have been pushed back a month or two already so I don't know if that date can be relied on.
