1st March February 2012
Latest post 08-30-2007 5:17 AM by Coolskin. 101 replies.
francis
- Joined on 04-16-2007
- Münster, Germany
- Posts 108
Luis, might be I'm thinking in the wrong direction: I have a Mac Mini connected via DVI with my BV. If I want to display Itunes, I use the screen in the PC mode. Pressing any of the buttons you have mentioned would switch the BV to the Tv (pal) mode and no longer display the computer signal??? francis
|BV 7-32|BL 7-1|Ouverture|BL Penta|BL 6000|BL 2000|Beocom 6000|Beotalk 1200|MX 4000|Beoport|Beo4|Beo5|A8|A9|
Ehlerz
- Joined on 04-17-2007
- DK
- Posts 510
I would like to get an update on this beoport matter. I have never been able to figure out how this setup is done. In my opinion the B&O usermanuals are dreadfull, regardless of product. Well, what i need to know is this: I have a BV 7 in my livingroom, connectet through ML to my BS3000 in my living room. In my bedroom i have an Imac, not connected to anything YET. SO, if I buy beoport and set this up in my bedroom what will i need to get it working? Sofar i have figured this out(at least i think i have) 1: I set up the beoport box in my bedroom, connnected to my Imac through USB and an soundcable. 2: I have no B&O equipment installed in my bedroom so do not need speakers there to be connected directly to beoport. How do I get the sound from beoport to ML system in my livingroom, through ML?? 3: Further, when everything is connected propperly, can i then control beoport througt the IR eye in my BV 7? Found an old PC2 manual but cant seem to figure it out?? Can anyone please help me understand?
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
Luigi
- Figueres (Spain)
- Posts 3,013
francis: Luis, might be I'm thinking in the wrong direction: I have a Mac Mini connected via DVI with my BV. If I want to display Itunes, I use the screen in the PC mode. Pressing any of the buttons you have mentioned would switch the BV to the Tv (pal) mode and no longer display the computer signal??? francis
I think you can use the Apple DVI to video adapter: http://store.apple.com/1-800-MY-APPLE/WebObjects/AppleStore.woa/wa/RSLID?mco=16193109&nplm=M9267G%2FA So, if you want display mac on BV7 press PC. For a link beovision press v.tape. I suppose it will work fine. But I don't know. I don't own a BV7.
Luigi
- Figueres (Spain)
- Posts 3,013
Hi Ehlerz 1) Exactly. 2) Yes, You need a long ML cable. 3) Yes, you can control beoport througt the IR of BV7 (video option 2) but if you add the IR eye you can control the beoport in your bedroom. Only the IR-eye connected to beoport accept the pc command. So, you will control the Frontrow on your iMac.
Coolskin
- Holland
- Posts 505
odlund: Hello BeoWorld Users!
I'm happy to announce that a new version of BM-Link is released.
The main new feature is the ability to control Front Row if you have an IR Eye connected directly to the BeoPort box.
Some bug fixes, and enhancements to N.RADIO are also included.
Anders
For me the update didn't work, sorry. I have a Mac Mini first edition, a non-intel machine so to speek.
I tried: Install 1.5 Uninstall 1.5 Install 1.5 and firmware update 1.31 Uninstall 1.5 Install 1.0 (firmware 1.31 still active!!)
The problem was I wasn't able to switch N.Radio channels after the second trie. The N.Radio station kept on playing. It froze I think. The BS3200 accepted my command and displayed it, but iTunes didn't react. Then I tried to get in the system preferences. When selecting BM-Link the computer kept on waiting.
As you could read I use an old Mac Mini. So no front row for me at the moment. BM-Link version 1.0 is perfect for me. So no problem.
beoberlin
- Berlin
- Posts 163
Coolskin: As you could read I use an old Mac Mini. So no front row for me at the moment.
...not exactly. Do you know the "frontrow enabler" by andrew escobar? Works perfectly, at least on my PB 17" under 10.4.9. Give it a try:
http://andrewescobar.com/frontrow
Regards, beoberlin
Coolskin
- Holland
- Posts 505
beoberlin: Coolskin: As you could read I use an old Mac Mini. So no front row for me at the moment.
Regards, beoberlin
Thanks for the tip.
Tried it just moments ago on my (internet computer) the PowerBook G4. Just does the trick.
Next steps are; - install it on the Mac Mini - buy an IR eye. - reinstall BM-Link 1.5 again...
Luigi
- Figueres (Spain)
- Posts 3,013
http://web.mac.com/luiscornejo/iWeb/luigi/Video%20Frontrow.html
I'm sorry. It's in spanish.
jchasey
- Hampshire, UK
- Posts 11
I've also just upgraded to 1.5. Similarly used the enabler to put FrontRow on my non-intel MacMini, which works a treat. No remote control of FrontRow yet, since I've not yet plugged the IR into the BeoPort. I currently have an eye going into my BeoSystem 3, so assume I can just use a 3.5mm splitter to send the signal to the BeoPort too? (Can't try at the moment since I'm at work). My other issue with a non-intel MacMini is that there is no digital out, so will be trying the M-Audio Transit USB add-on which gives audio out to the Mac, so it can then go into the BS3.
Coolskin
- Holland
- Posts 505
Regards, beoberlin
Just tried it on the Mac Mini and it is o.k.!!
Last year I bought an IR sensor from Lintronic for remote control of the window screens. Unplugged this IR sensor for testing and plugged it in the BeoPort. And what do you know... it works perfectly.
Coolskin
- Holland
- Posts 505
Luigi: Do you know if it is possible connect 2 IR-eye together in the same connection of beoport?
I was thinking the other way around. Find a way to connect Lintronic AND Beoport to 1 IR-eye. Must find out next coming days...
BeoPort uses other BEO4 keystrokes than the Lintronic box (connected to the window screens).
I'll try to get a cable connector with 2 female connections. If the IR cable is compatible with a headphone jacket, then it will be easy to connect. A headphone splitter is the only thing missing.
Luigi
- Figueres (Spain)
- Posts 3,013
According the service technician, this trick will not always work. Sometimes the beoport would hang. They don't recommend the use of headphone splitter. The beoport can be damaged.
rippi
- Posts 12
Coolskin: odlund: Hello BeoWorld Users!
Anders
Hello Coolskin, did you make it work somehow ? I experienced the same problems and downgraded. Regards Harald
marcus
- Adelaide, South Australia
- Posts 50
Thank you so much for the tip about "frontrow enabler". I've just transformed my G4 iMac into a media centre! Well, an audio centre anyway. (No Beovision. Yet.) I did not need an IR eye for Beoport because it's connected to a Beosound 4 in the same room that acts as an Audio Master. This might change if/when I add a Beovision to the equation. I'm very happy, and frankly amazed that it works. Regards Marcus
marcus
- Posts 50
marcus: I did not need an IR eye for Beoport because it's connected to a Beosound 4 in the same room that acts as an Audio Master. This might change if/when I add a Beovision to the equation. Spoke too soon. While I can change tracks and albums, I can't change applications (music - photos - video etc). Looks like an IR eye is on my shopping list now!
Coolskin
- Holland
- Posts 505
After some trials I downgraded to 1.0 Now it is again 1.5 and tested it with a Lintronic IR sensor. This combination works fine (so far). I disconnected the IR sensor again and till now there are no problems with the BM-Link software. But if I do entounter problems, I will post it here.
Christophe75
- Paris
- Posts 20
Coolskin: After some trials I downgraded to 1.0 Now it is again 1.5 and tested it with a Lintronic IR sensor. This combination works fine (so far). I disconnected the IR sensor again and till now there are no problems with the BM-Link software. But if I do entounter problems, I will post it here.
Thanks for sharing your experience, Coolskin. I'm in exactly the same position as you are (old MacMini, old PC2, ML system) and holding my breath and wondering whether I should upgrade to 1.5 now or not. Keep us posted! Christophe
Coolskin
- Holland
- Posts 505
Christophe75: Coolskin: After some trials I downgraded to 1.0 Now it is again 1.5 and tested it with a Lintronic IR sensor. This combination works fine (so far). I disconnected the IR sensor again and till now there are no problems with the BM-Link software. But if I do entounter problems, I will post it here.
Sorry to say the Mac Mini froze today. When I try to get in the System Preferences and select BM-Link there is no response. Only shutdown + resart solved the problem. Still BM-Link 1.5 without IR sensor active. I'll see what happens next couple of days.
marcus
- Posts 50
Hi Luis, I have watched the videos on your Web site (nice apartment btw!) and notice that you are controlling Front Row on your MacBook using the Beo4. I am trying to do the same thing but cannot get it to work properly. Can you please explain exactly how your system is set up, how you have configured your Beo4 and what options you have set in BM-Link 1.5. I am running a G4 iMac with Front Row (using Front Row Enabler). A Beoport is connected to the Mac via USB and earphone cable (from sound-out on the Mac). ML cable links the Beoport to a Beosound 4 in the same room and Beolab 3 speakers are attached to it. Currently I select either N.Music or N.Radio on the Beo4 with iTunes running on the Mac and I hear music. I would like to be able to control Front Row using the Beo4. I bought an IR-eye from B&O today and have plugged it in to the Beoport. (It plugs into the 7-pin Remote socket, not the IR socket - is this correct??) What mode should the Beo4 be in to control the IR-eye? I have the latest Beo4 (came with the Beosound 4 and has V.MEM and A.MEM buttons). I've tried a few options but nothing much seems to happen. The documentation is next to useless so I thought I would ask an expert! Please note that I do not have a Beovision TV and am trying to control Front Row using only the Beo4 and Beoport attached to an iMac. Many thanks Marcus
Luigi
- Figueres (Spain)
- Posts 3,013
Hi Marcus. My set up:
Luigi
- Figueres (Spain)
- Posts 3,013
I can control Front Row throught the IR-eye connected to beoport. I have a long cable (green (photo)) for stereo-audio and video. This cable connect the computer (PC, mac) to the BV3. When I press V.tape (for exemple) I can see the computer to the BV3, then pressing A-N.music/ A-N.radio can control without turning off the BV3. You can select coverflow fullscreen on mac and control in other place throught ML, watching the covers on TV. Thanks to modulator of BV3 I can watch the same image from BV3 to BV1. If you want control FrontRow with Beo4 you need the IR-eye connected to beoport. This cable has a minijack 3.5mm connector. I never saw a IR-eye with 7pin connector.You must connect the IR-eye into the IR socket of beoport. Good Luck.
marcus
- Posts 50
Luigi: If you want control FrontRow with Beo4 you need the IR-eye connected to beoport. This cable has a minijack 3.5mm connector. I never saw a IR-eye with 7pin connector.You must connect the IR-eye into the IR socket of beoport. Good Luck.
Thank you for your very detailed reply.
My dealer sold me an "IR Kit Wireless 1" that plugs into the Powerlink socket of the Beoport. The Link-Eye has a timer and play button and what look like two volume controls. It sounds like that this is not the correct piece of equipment. I shall return it tomorrow and try to get the correct item that plugs into the IR socket of the Beoport using a 3.5mm minijack. (No wonder nothing works!) I think I will need luck with all this. Thanks for your good wishes.
