1st March February 2012
Latest post 05-02-2011 9:30 AM by Leslie. 46 replies.
Leslie
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.24.24/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
tournedos:The physical size will have as much to do with the voltage rating as the capacitance. Those original SMD cans in the pictures will be good for either 0.22 uF / 63 V or 22 uF / 6.3V - hard to tell from the pictures where a decimal point is and where one isn't...
Exactly as what my colleague here at work told me, thanks for the explanation Mika!
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Die_Bogener
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.22.59/avatar.jpg)
![Top 75 Contributor Top 75 Contributor](/Themes/beotheme1/images/rankicons/rankTop75.gif)
- Joined on 04-16-2007
- Bogen, Germany
- Posts 1,010
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
I was also not sure, wether they are 22uF or 220nf... so i decided to unsolder the next working BL7000 and to measure it.
They are 220nf.
But there is no real problem with it, they work also with 22uf. But 220nf is easy to replace by a 220nF MKS styrol SMD cap, bipolar. Looks much better and no problem with the metal shield, they are much smaller than the elctrolyth caps.
Leslie
- Netherlands
- Posts 2,201
Okay, received Gary's (Beofile7) BL7000 today by post.
Hopefully I can fix the " No contact" issue![Erm](http://forum.beoworld.org/emoticons/38.gif)
Did it before with 4 others.
Please have mercy with critical comments cause I'm not an electronic nerd![Embarrassed](http://forum.beoworld.org/emoticons/10.gif)
This is the story:
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary1.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary2.JPG) ![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary3.JPG) ![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary4.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary5.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary6.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary7.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary8.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary9.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary10.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary11.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary12.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary13.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary14.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary15.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary16.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary17.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary18.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary19.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary20.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary21.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary22.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary23.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary24.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary25.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary26.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary27.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary28.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary29.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary30.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary31.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary32.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary33.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary34.JPG)
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.01.24.24/Gary35.JPG)
Step1
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.88.68/avatar.jpg)
- Joined on 07-06-2008
- Manchester
- Posts 961
Some nice work there Leslie. SO I take it the BL7000 does not like the tantalum substitutes...?
Anyway, thought I would just mention one thing - good you are wrapping up these things to protect but just a caution those pink anti-stat bags do not protect against static believe it or not, they only guarentee not to generate any! Just thought I would mention just in case!
I can only hope to get my hands on one of these remotes along with an all black BS7000 and BL5's someday Am I pushing my luck, I guess I am loL!
Leslie
- Netherlands
- Posts 2,201
Hi Olly,
Protection was ment for scratches![Smile](http://forum.beoworld.org/emoticons/01.gif)
I know this is ESD plastic but I've used it more for keeping the springs in place.
Leslie
- Netherlands
- Posts 2,201
Step1:I can only hope to get my hands on one of these remotes along with an all black BS7000 and BL5's someday ![Whistle](http://forum.beoworld.org/emoticons/16.gif) Am I pushing my luck, I guess I am loL!
Ahum![Whistle](http://forum.beoworld.org/emoticons/16.gif)
elephant
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.23.78/avatar.jpg)
- Melbourne, Australia
- Posts 2,215
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
OMG
MGO
GOM
Fantastique !!!
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
Beofile7
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.28.15/avatar.jpg)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 06-16-2009
- Posts 16
Leslie
You are a genius! I cannot thank you enough. You have truly made my day. I owe you big time.
Just to clarify? It was just one dead cap? Which one?
Gary.
Leslie
- Netherlands
- Posts 2,201
To be honest Gary, I don't know! [:'(]
As said before, I'm not an electronic nerd, just handy with a soldering iron....
Just put new ones in and usually the 22uF SMD's are gone.
Please give me you adress by PM and I'll send it back to you.
Don't thank me, it's just a pleasure seeing these Icons back to (2-way) work and it keeps me of the street![Big Smile](http://forum.beoworld.org/emoticons/02.gif)
Leslie
- Netherlands
- Posts 2,201
Send it over Spiros, just 1500 euro's for you , (per hour).
Leslie
- Netherlands
- Posts 2,201
No, starting from now![Big Smile](http://forum.beoworld.org/emoticons/02.gif)
Spiros
![](/utility/anonymous.gif)
- Joined on 09-03-2007
- Thessaloniki GREECE
- Posts 1,088
MoglesMac
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
- Joined on 04-25-2007
- Sweden
- Posts 109
OMG Leslie,
Thanks for this very cool photogenic how-to :D Love those internal hardware pictures :D
Jesper
Sweden
Leslie
- Netherlands
- Posts 2,201
Me myself Jesper, thanks!
Beofile7
- Posts 16
UPDATE:
I have received the BL7000 back from Leslie and it now works a treat.
2 way comms with BM 7000, BG7000, BGCD7000, BC7000, BV6000MkII, BC7000VHS, DVD1 all though Penta II's, fully restored. Ooo and LC2's.
I am a happy Easter bunny today!
Thanks again Leslie.
Gary.
Leslie
- Netherlands
- Posts 2,201
Good to hear Blackrix!
Have one that still does not respond 2-ways after recapping.
Maybe I should check the back-up cell.
Leslie
- Netherlands
- Posts 2,201
@Blackrix,
Maybe you could solve the other issue "we" have with the"keeps switching on and off" problem?
Blackrix
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.22.43/avatar.jpg)
- Joined on 04-20-2009
- Posts 975
@Leslie,
I have already replied on that one a while ago:
Blackrix:
Check the voltage of the back-up battery on the microprocessorboard.
No reply on that one yet!
Leslie
- Netherlands
- Posts 2,201
Beofile7:You have truly made my day. I owe you big time.
Gary, thank you very much for the "present" I got from you for fixing the BL7000. Much appreciated, you're a true BW member![Yes - thumbs up](http://forum.beoworld.org/emoticons/21.gif)
