Latest post 05-02-2011 9:30 AM by Leslie. 46 replies.
Page 2 of 2 (47 items) < Previous 1 2
  • 03-21-2011 10:25 AM In reply to
    Re: Beolink 7000 recap?
    tournedos:
    The physical size will have as much to do with the voltage rating as the capacitance. Those original SMD cans in the pictures will be good for either 0.22 uF / 63 V or 22 uF / 6.3V - hard to tell from the pictures where a decimal point is and where one isn't...
    Exactly as what my colleague here at work told me, thanks for the explanation Mika!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 03-21-2011 1:14 PM In reply to
    I was also not sure, wether they are 22uF or 220nf... so i decided to unsolder the next working BL7000 and to measure it.
    They are 220nf.
    But there is no real problem with it, they work also with 22uf. But 220nf is easy to replace by a 220nF MKS styrol SMD cap, bipolar. Looks much better and no problem with the metal shield, they are much smaller than the elctrolyth caps.
  • 04-05-2011 3:22 PM In reply to
    Okay, received Gary's (Beofile7) BL7000 today by post.
    Hopefully I can fix the " No contact" issueErm
    Did it before with 4 others.
    Please have mercy with critical comments cause I'm not an electronic nerdEmbarrassed
    This is the story:
  • 04-05-2011 3:43 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Some nice work there Leslie. SO I take it the BL7000 does not like the tantalum substitutes...?
    Anyway, thought I would just mention one thing - good you are wrapping up these things to protect but just a caution those pink anti-stat bags do not protect against static believe it or not, they only guarentee not to generate any! Just thought I would mention just in case!
    I can only hope to get my hands on one of these remotes along with an all black BS7000 and BL5's someday Whistle Am I pushing my luck, I guess I am loL!
    Olly.
  • 04-05-2011 4:22 PM In reply to
    Hi Olly,
    Protection was ment for scratchesSmile
    I know this is ESD plastic but I've used it more for keeping the springs in place.
  • 04-05-2011 4:33 PM In reply to
    Step1:
    AhumWhistle
  • 04-06-2011 4:38 AM In reply to
    OMG
    MGO
    GOM
    Fantastique !!!
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 04-06-2011 5:24 AM In reply to
    Leslie
    You are a genius! I cannot thank you enough. You have truly made my day. I owe you big time.
    Just to clarify? It was just one dead cap? Which one?
    Gary.
  • 04-06-2011 8:13 AM In reply to
    To be honest Gary, I don't know!Embarrassed[:'(]
    As said before, I'm not an electronic nerd, just handy with a soldering iron....
    Just put new ones in and usually the 22uF SMD's are gone.
    Please give me you adress by PM and I'll send it back to you.
    Don't thank me, it's just a pleasure seeing these Icons back to (2-way) work and it keeps me of the streetBig Smile
  • 04-06-2011 9:54 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Mine is already traveling to you!!!!!!!!!!!!!!!!! Just joking!
    Best regards
    Spiros
  • 04-06-2011 10:07 AM In reply to
    Send it over Spiros, just 1500 euro's for youWhistle, (per hour).
  • 04-06-2011 10:09 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    And I guess that it counts by the time I take it to the post office!!!!!!!!!!!!!!?!!?!?!?!?!?!?!
    Best regards
    Spiros
  • 04-06-2011 10:11 AM In reply to
    No, starting from nowBig Smile
  • 04-06-2011 10:16 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    LOL!!!!!!!!!!!!!!!!!!
    Best regards
    Spiros
  • 04-09-2011 12:11 PM In reply to
    OMG Leslie,
    Thanks for this very cool photogenic how-to :D Love those internal hardware pictures :D
    Jesper
    Sweden
  • 04-09-2011 2:38 PM In reply to
    Me myself Jesper, thanks!
  • 04-24-2011 8:55 AM In reply to
    UPDATE:
    I have received the BL7000 back from Leslie and it now works a treat.
    2 way comms with BM 7000, BG7000, BGCD7000, BC7000, BV6000MkII, BC7000VHS, DVD1 all though Penta II's, fully restored. Ooo and LC2's.
    I am a happy Easter bunny today!
    Thanks again Leslie.
    Gary.
  • 04-24-2011 2:50 PM In reply to
    Just to add something to the topic. I just recapped a BeoLink 7000, and still no 2-way. After that I checked the the back-up cell which is placed on the microprocessorboard and it had a lower voltage that it should be. After replacing the back-up cell it is working again! So is is not always just the capacitors which are only causing the problems.
  • 04-24-2011 2:58 PM In reply to
    Good to hear Blackrix!
    Have one that still does not respond 2-ways after recapping.
    Maybe I should check the back-up cell.
  • 04-24-2011 3:06 PM In reply to
    @Blackrix,
    Maybe you could solve the other issue "we" have with the"keeps switching on and off" problem?
  • 04-25-2011 6:13 AM In reply to
    @Leslie,
    I have already replied on that one a while ago:
    Blackrix:
    Check the voltage of the back-up battery on the microprocessorboard.
    No reply on that one yet!
  • 05-02-2011 9:30 AM In reply to
    Beofile7:
    Gary, thank you very much for the "present" I got from you for fixing the BL7000. Much appreciated, you're a true BW memberYes -  thumbs up
