Latest post 01-16-2012 5:12 PM by Chris. 40 replies.
Page 1 of 2 (41 items) 1 2 Next >
  • 01-27-2011 4:14 PM
    • Dobbs
    • Not Ranked
    • Joined on 05-01-2010
    • Belgium
    • Posts 13
    • Gold Member
    Beo6 Config Tool
    Can anyone send me a link for the new Beo5 Config Tool 4.11?
    I have the new Beo6, but my dealer didn`t give the the software...really too bad.
    thanks in advance
  • 01-27-2011 4:20 PM In reply to
    Re: Beo6 Config Tool
    A piece of advice for the potential buyers of a Beo6... negociate the software BEFORE you buy. If they want your money, they'll do a little effort.
  • 01-28-2011 2:41 PM In reply to
    Hi There,
    I have recently downloaded the 4.11 Configuration Tool at this location:
    http://webcache.googleusercontent.com/search?q=cache:0-M3ajZnHSYJ:www.beoforum.dk/viewtopic.php%3Ff%3D37%26t%3D337+Beo5/6CTSetup+4.11.exe&cd=1&hl=en&ct=clnk&gl=uk&source=www.google.co.uk
    Simply select the download link next to where it says 'CTSetup_4.11.exe'
    I've used it with my Beo5 and it's upgraded the firmware fixing a really irritating battery drain issues.
    Please let me know how you get on.
    Many Thanks
    Graham
  • 01-28-2011 5:09 PM In reply to
    Great, thanks!
    There is something about B&O.....
  • 01-29-2011 2:06 AM In reply to
    • Dobbs
    • Not Ranked
    • Belgium
    • Posts 13
    • Gold Member
    Also THANKS ...
  • 01-29-2011 5:44 AM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Brilliant!
    Thanks.
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 01-29-2011 6:48 AM In reply to
  • 01-29-2011 7:12 AM In reply to
    Super!
  • 01-29-2011 7:46 AM In reply to
    • dueno
    • Top 500 Contributor
    • Joined on 04-29-2007
    • bordeaux
    • Posts 147
    problem when running 4.11 config tool!!!
    this message happen:
    The OCX is missing or corupt, please reinstall the Configuration tool !
    PLEASE HELP ME!!!!!!
    never explain never complain
  • 01-31-2011 12:15 PM In reply to
    dueno:
    This means that the runtime library is missing or cannot access it from the C:\Windows\system32 directory
    Regards Keith....
  • 01-31-2011 3:00 PM In reply to
    Keith it is still not possible to mix b&o with 3:d party in a macro?? why does not b&o solve this????
  • 01-31-2011 3:51 PM In reply to
    You are correct within the Configuration Tool, its an area where the developers appear to still be having a lot of problems getting right. A couple of versions ago they almost got it right.
    However, the solution which I always use is to build the macro's into the 3rd party XML file, so that it is just drag-n-drop within the configuration tool. Doing it that way means the Configuration Tool does not have to build the linkages, so there is never a problem.
    I also build in all the hardkey and digit assignments into the 3rd party XML file as well for the same reason, in fact I wrote a Windows based program to do it automatically.
    Regards Keith....
  • 02-01-2011 7:41 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Keith, could you explain a little bit more how to make the 3rd party macros possible?
    P.S.: Do you work secretly for software companies like Microsoft etc.? Big Smile You seem to be a real genius.
  • 02-01-2011 8:26 AM In reply to
    • adro
    • Not Ranked
    • Joined on 08-26-2009
    • Posts 23
    • Gold Member
    Would it be possible to have copy of one of your xml files with hardkeys, so I can have a look and see if I get something out of it.
    I have no clue on how to program the hardkeys, or macros.
    Regards
    AtleSmile
  • 02-01-2011 10:35 AM In reply to
    Atle,
    Yes it would be possible. All XML files I provide to members always have the Hard Keys and digits (where applicable) pre-assigned within the XML file. I am rather surprised that B&O do not do this themselves, then several of the Configuration Tool outstanding issues would become non issues.
    I have attached a typical example for Apple TV, save it and then open it with either an XML editor or Windows Notepad
    Regards Keith....
  • 02-01-2011 10:39 AM In reply to
    TWG:
    Thank you for your very kind comments, genius, well no, fairly experienced, I guess so..
    It sounds like we need an "XML Macros" training Thread on how to make an XML file with macros already built in without using the Beo5/Beo6 Configuration Tool. Is that the general view ?
    Regards Keith....
  • 02-01-2011 10:41 AM In reply to
    Keith, If you have a button with a 3:d party ir, and then change the name on the button, it stop working. The code is gone!! So therefore I can not make a macro with B&O keys. So how do you do it?
  • 02-01-2011 10:44 AM In reply to
    Keith Saunders:
    TWG:
    YES we neeeeeed;-)
  • 02-01-2011 1:50 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Keith Saunders:
    TWG:
    Yes! We need that :-)
  • 02-01-2011 5:25 PM In reply to
    • Matthew
    • Joined on 06-01-2009
    • Melbourne, Australia
    • Posts 99
    Keith Saunders:
    Yes please. That would be extremely useful.
  • 02-01-2011 6:06 PM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Add me to the list for the XML macro training
    Side note : I also thank Keith for his skills. He may not be a genius, but he is surely excellent. And he has done more to the Beo5 than anyone at B&O ever did. If a lot of people here use a Beo5 on a daily basis, there's usually something from Keith behind that.
    People with Beo5 and no contact with Keith tend to place this remote on a box and only use Beo4, when they don't directly sold it on eBay...
  • 02-02-2011 12:15 AM In reply to
    • Matthew
    • Posts 99
    mbee: I would echo those sentiments exactly.
    Without Keith, and others on this forum, I would not have even bothered to buy one. Thanks to them I am able to fully program it to control pretty much whatever I like in the way that I like, which makes it a very powerful remote indeed.
    I agree - the only reason people would have it either in a box or gathering dust is because they have yet to go down the self programming route to discover it's potential.
  • 02-02-2011 4:25 AM In reply to
    PLease count me in too!
  • 02-02-2011 5:11 AM In reply to
    PLease add me to !
    BeoVision 4 - 50 HD -  Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .
  • 02-02-2011 6:02 AM In reply to
    • YannChris
    • Posts 276
    Hello Keith,
    Count me in!
    Kind regards,
    Yann.
