1st March February 2012
Latest post 01-16-2012 5:12 PM by Chris. 40 replies.
01-27-2011 4:14 PM
Dobbs
- Joined on 05-01-2010
- Belgium
- Posts 13
Can anyone send me a link for the new Beo5 Config Tool 4.11?
I have the new Beo6, but my dealer didn`t give the the software...really too bad.
thanks in advance
greztaylor
- Joined on 06-02-2009
- Posts 18
Hi There,
I have recently downloaded the 4.11 Configuration Tool at this location:
http://webcache.googleusercontent.com/search?q=cache:0-M3ajZnHSYJ:www.beoforum.dk/viewtopic.php%3Ff%3D37%26t%3D337+Beo5/6CTSetup+4.11.exe&cd=1&hl=en&ct=clnk&gl=uk&source=www.google.co.uk
Simply select the download link next to where it says 'CTSetup_4.11.exe'
I've used it with my Beo5 and it's upgraded the firmware fixing a really irritating battery drain issues.
Please let me know how you get on.
Many Thanks
Graham
Dobbs
- Belgium
- Posts 13
dueno
- Joined on 04-29-2007
- bordeaux
- Posts 147
problem when running 4.11 config tool!!!
this message happen:
The OCX is missing or corupt, please reinstall the Configuration tool !
PLEASE HELP ME!!!!!!
never explain never complain
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
dueno:
This means that the runtime library is missing or cannot access it from the C:\Windows\system32 directory
Keith Saunders
- Posts 3,810
You are correct within the Configuration Tool, its an area where the developers appear to still be having a lot of problems getting right. A couple of versions ago they almost got it right.
However, the solution which I always use is to build the macro's into the 3rd party XML file, so that it is just drag-n-drop within the configuration tool. Doing it that way means the Configuration Tool does not have to build the linkages, so there is never a problem.
I also build in all the hardkey and digit assignments into the 3rd party XML file as well for the same reason, in fact I wrote a Windows based program to do it automatically.
adro
- Joined on 08-26-2009
- Posts 23
Would it be possible to have copy of one of your xml files with hardkeys, so I can have a look and see if I get something out of it.
I have no clue on how to program the hardkeys, or macros.
Regards
Atle
Keith Saunders
- Posts 3,810
Atle,
Yes it would be possible. All XML files I provide to members always have the Hard Keys and digits (where applicable) pre-assigned within the XML file. I am rather surprised that B&O do not do this themselves, then several of the Configuration Tool outstanding issues would become non issues.
I have attached a typical example for Apple TV, save it and then open it with either an XML editor or Windows Notepad
Keith Saunders
- Posts 3,810
TWG:
Keith, could you explain a little bit more how to make the 3rd party macros possible?
P.S.: Do you work secretly for software companies like Microsoft etc.? You seem to be a real genius.
Thank you for your very kind comments, genius, well no, fairly experienced, I guess so..
It sounds like we need an "XML Macros" training Thread on how to make an XML file with macros already built in without using the Beo5/Beo6 Configuration Tool. Is that the general view ?
mr_anders_son
- Joined on 03-27-2007
- sweden
- Posts 1,032
Keith Saunders: TWG:
YES we neeeeeed;-)
TWG
- Joined on 04-17-2007
- Germany
- Posts 950
Keith Saunders:
TWG:
Yes! We need that :-)
Matthew
- Joined on 06-01-2009
- Melbourne, Australia
- Posts 99
Keith Saunders:
Yes please. That would be extremely useful.
mbee
- Joined on 04-18-2007
- Paris, France
- Posts 1,133
Add me to the list for the XML macro training
Side note : I also thank Keith for his skills. He may not be a genius, but he is surely excellent. And he has done more to the Beo5 than anyone at B&O ever did. If a lot of people here use a Beo5 on a daily basis, there's usually something from Keith behind that.
People with Beo5 and no contact with Keith tend to place this remote on a box and only use Beo4, when they don't directly sold it on eBay...
Matthew
- Posts 99
mbee: I would echo those sentiments exactly.
Without Keith, and others on this forum, I would not have even bothered to buy one. Thanks to them I am able to fully program it to control pretty much whatever I like in the way that I like, which makes it a very powerful remote indeed.
I agree - the only reason people would have it either in a box or gathering dust is because they have yet to go down the self programming route to discover it's potential.
YannChris
- Larmor-Plage, France
- Posts 276
Hello Keith,
Count me in!
Kind regards,
Yann.
Ne pas s'en faire et boire frais!
Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
