Latest post 01-09-2011 8:45 AM by stefan. 67 replies.
Page 3 of 3 (68 items) < Previous 1 2 3
  • 01-07-2011 5:52 AM In reply to
    • Electrified
    • Top 150 Contributor
    • Joined on 10-05-2009
    • Greater Copenhagen, Denmark
    • Posts 404
    Re: Updated 4 jan 2011
    I use lossless on my portable stuff too. I do that because it's easier to use whatever I have, and since my Cowon D2 uses SDHC cards up to 32GB it's pretty easy to have a lot of stuff with me on a couple of cards -  Enough, anyway.
  • 01-07-2011 7:12 AM In reply to
    A minor gripe:
    B&O now needs to replace the Twonky multi-colored "T" logo with its own B&O logo when the BM5 server shows up on network devices.
  • 01-07-2011 2:46 PM In reply to
    Carolpa:
    Read the update in the FAQ (BS5 faq - site B&o) carefully. You have to go to the service menu's. This option is normally NOT shown
    Read the FAQ, but my BM5 still gives the same service menu topics.
    I think that the menu you've mentioned will only be visible at the BS5.
    I've seen just quick second the service desktop from the BM5. And I saw new folder "MLGW" on the desktop. 100% sure it wasn't there before.
    Haven't had the time to attach a mouse to investigate. (Voices of Holland at the moment Ick!)
  • 01-07-2011 7:14 PM In reply to
    I use sometimes lossless, however Itunes can convert on the fly into 128kbs which is a little weak. I am hoping they give a flexible option there in future.
    I do not want to deal with Flac or multiple libraries so I will keep waiting until this is sorted. By this I mean, either gapless AAC compressed or gapless Apple Lossless.
  • 01-08-2011 2:49 AM In reply to
    It is explained for the BS5. I didn't look for the BM5
    I looked at the menus on the BM5, and your right it can NOT be switched ON !?!
    Maybe at the service menu? Will investicate this later
  • 01-08-2011 3:43 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    My BS5 is updated and I got my Beo6 today. The user guide says I can activate the "wireless" - wifi- function in the setup menu.
    But I can`t find a "wireless" button (as described). My Beo6 was configured with CT 4.11.  Any ideas?
    Stefan
  • 01-08-2011 5:19 PM In reply to
    • gysse2004
    • Not Ranked
    • Joined on 05-19-2009
    • Copenhagen North
    • Posts 42
    Hi Stefan
    This feature, will not be possible until there is a new software-version later this month, or beginning of Febuary..
    Peter
  • 01-09-2011 2:32 AM In reply to
    • stefan
    • Posts 1,733
    gysse2004:
    Hi Stefan
    Peter
    I hope you are talking about 2011...
    A new SW version of BS5 or CT 4.11 ?
    Tak.
    Stefan
  • 01-09-2011 4:44 AM In reply to
    • gysse2004
    • Not Ranked
    • Copenhagen North
    • Posts 42
    Hi Stefan
    According to my B&O dealer, yes 2011 - I think both BS5 and Beo6. I am running the same setup, and
    can't wait to see navigation and coverflow on Beo6, this is what i have been missing all along.
    Best regards
    PeterSmile
  • 01-09-2011 5:41 AM In reply to
    stefan:
    CT 4.11
    With 3.87 one can not program the Beo6
  • 01-09-2011 5:55 AM In reply to
    • gysse2004
    • Not Ranked
    • Copenhagen North
    • Posts 42
    Correct you need 4.11
  • 01-09-2011 5:57 AM In reply to
    Is 4.11 already floating on the internet?
  • 01-09-2011 6:30 AM In reply to
    not to my knowledge. I got it from my dealer
  • 01-09-2011 7:58 AM In reply to
    • stefan
    • Posts 1,733
    Carolpa:
    stefan:
    CT 4.11
    Sorry. What I meant was: Will BS5 be updated from 6.02 to 6.0X , or must CT 4.11 be updated to 4.12?
    I can`t find a "wifi" configuration in CT 4.11, so I assume there will be a new version for the config. tool....?
    Stefan
  • 01-09-2011 8:26 AM In reply to
    It is on the remote itself that you'll have to configure Wifi.
  • 01-09-2011 8:28 AM In reply to
    stefan:
    Carolpa:
    stefan:
    CT 4.11
    Stefan
    Presumably the CT has to be updated. As you wrote WiFi can't be programmed with this version.  My dealer told me this feature will come this spring.
  • 01-09-2011 8:37 AM In reply to
    • stefan
    • Posts 1,733
    Yes, I think so too - thanks.
    Stefan
  • 01-09-2011 8:45 AM In reply to
    • stefan
    • Posts 1,733
    PhilLondon:
    Yes, I know. But there simply is no button in the SETUP menu to configure wifi. So there must be a wifi configuration in the (new) CT 4.1X...
    It`s also said somewhere in the Beo6 user guide. The Help menu of CT 4.11 is just talking about Beo5, they never mention Beo6.
    But configuring Beo5 and Beo6 with CT 4.11 works without problems - excluding wifi...
    Stefan
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
