        1st March February 2012
	    Latest post 01-09-2011 8:45 AM by  stefan. 67 replies.
									        Electrified
								                - Joined on 10-05-2009
								                - Greater Copenhagen, Denmark
								                - Posts 404
										    I use lossless on my portable stuff too. I do that because it's easier to use whatever I have, and since my Cowon D2 uses SDHC cards up to 32GB it's pretty easy to have a lot of stuff with me on a couple of cards -  Enough, anyway.
									        beojeff
								                - Joined on 11-29-2007
								                - Posts 543
										    A minor gripe:
B&O now needs to replace the Twonky multi-colored "T" logo with its own B&O logo when the BM5 server shows up on network devices.
									        Beobuddy
								                - Joined on 04-18-2007
								                - Posts 1,582
										      Carolpa:
Read the update in the FAQ (BS5 faq - site B&o) carefully. You have to go to the service menu's. This option is normally NOT shown
Read the FAQ, but my BM5 still gives the same service menu topics.
I think that the menu you've mentioned will only be visible at the BS5.
I've seen just quick second the service desktop from the BM5. And I saw new folder "MLGW" on the desktop. 100% sure it wasn't there before.
Haven't had the time to attach a mouse to investigate. (Voices of Holland at the moment  )
									        jk1002
								                - Joined on 04-16-2007
								                - Boston USA
								                - Posts 1,620
										    I use sometimes lossless, however Itunes can convert on the fly into 128kbs which is a little weak. I am hoping they give a flexible option there in future.
I do not want to deal with Flac or multiple libraries so I will keep waiting until this is sorted. By this I mean, either gapless AAC compressed or gapless Apple Lossless.
									        stefan
								                - 200 miles from Struer
								                - Posts 1,733
										    My BS5 is updated and I got my Beo6 today. The user guide says I can activate the "wireless" - wifi- function in the setup menu.
But I can`t find a "wireless" button (as described). My Beo6 was configured with CT 4.11.  Any ideas?
Stefan
									        gysse2004
								                - Joined on 05-19-2009
								                - Copenhagen North
								                - Posts 42
										    Hi Stefan
This feature, will not be possible until there is a new software-version later this month, or beginning of Febuary..
Peter
									        stefan
								                - Posts 1,733
										      gysse2004:
Hi Stefan
Peter
I hope you are talking about 2011...
A new SW version of BS5 or CT 4.11 ?
Tak.
Stefan
									        gysse2004
								                - Copenhagen North
								                - Posts 42
										    Hi Stefan
According to my B&O dealer, yes 2011 - I think both BS5 and Beo6. I am running the same setup, and
can't wait to see navigation and coverflow on Beo6, this is what i have been missing all along.
Best regards
Peter
									        Carolpa
								                - Joined on 08-15-2008
								                - Posts 440
										      stefan:A new SW version of BS5 or CT 4.11 ?
CT 4.11
With 3.87 one can not program the Beo6
									        gysse2004
								                - Copenhagen North
								                - Posts 42
									        stefan
								                - Posts 1,733
										      Carolpa:
CT 4.11
Sorry. What I meant was: Will BS5 be updated from 6.02 to 6.0X , or must CT 4.11 be updated to 4.12?
I can`t find a "wifi" configuration in CT 4.11, so I assume there will be a new version for the config. tool....?
Stefan
									        Carolpa
								                - Posts 440
										      stefan:
  Carolpa:
CT 4.11
Stefan
Presumably the CT has to be updated. As you wrote WiFi can't be programmed with this version.  My dealer told me this feature will come this spring.
									        stefan
								                - Posts 1,733
										      PhilLondon:
It is on the remote itself that you'll have to configure Wifi.
Yes, I know. But there simply is no button in the SETUP menu to configure wifi. So there must be a wifi configuration in the (new) CT 4.1X...
It`s also said somewhere in the Beo6 user guide. The Help menu of CT 4.11 is just talking about Beo5, they never mention Beo6.
But configuring Beo5 and Beo6 with CT 4.11 works without problems - excluding wifi...
Stefan
