Latest post 12-20-2007 3:23 PM by Keith Saunders. 30 replies.
Page 2 of 2 (31 items) < Previous 1 2
  • 12-19-2007 12:45 PM In reply to
    Re: Beocom 6000
    hi,
    all of my beocom 6000's are just that, not beocom 1's...
    they are all the early mk1's w/ the dot.
    they all work great except the one in question. it will not find the base. i noticed that using .70001 -that the software listed is quite different than any of the functioning units. w/ regards to the decal beneath the battery...
    1.) good: b&o decal stating 1070156
    2.) bad: (2) small round decals -1 w/ "40" -2 w/ "46"
    reg'ing the software...
    1.) good: 001-1.60 0103071019-2G4
    2.) bad: 032-1.20 9901261126
    ++++edit++++
    the supplied charger is usa -the phone charges fine, etc... -just can't find the base during registration.
    • B&o bottle opener
  • 12-20-2007 12:53 PM In reply to
    Re: Beocom 6000
    Based on everything you have said, I think you may have a faulty RF chip in the handset, it is quite common. If this is the case, then the only way to fix the phone is to upgrade it to a Mark II because the RF chip and module it is on are no longer made.
    Regards Keith....
  • 12-20-2007 3:02 PM In reply to
    Re: Beocom 6000
    yikes, what a "bummer" -i'll give my local dealer a shout! or look for the guts of a cosmetically tired one.
    thx again!
    ++++edit++++
    hmmm... but wonder why the software readout is so different on this one bad phone?
    (5) good 6000's all w/ similar software readings -and this (1) bad one w/ the odd readout?
    hmmm...
    • B&o bottle opener
  • 12-20-2007 3:14 PM In reply to
    Re: Beocom 6000
    You can purchase a B&O upgrade kit p/n 3455103 which has all the parts required to upgrade a Mark I Beocom 6000 to a Mark II and still use the Mark I charger. The kits cost around $70
    Regards Keith....
  • 12-20-2007 3:16 PM In reply to
    Re: Beocom 6000
    thx!
    please see my edit to previous post.
    • B&o bottle opener
  • 12-20-2007 3:23 PM In reply to
    Re: Beocom 6000
    It was the apparent software version of the bad Beocom 6000 is why I said what I did.
    Regards Keith....
