1st March February 2012
07-02-2007 6:53 AM
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Tony, You answer means that you have a Mark I phone and I also assume that you have unplugged the base from the power and re-connected it given your following answer. If you have done this and just need to re-register the phones then your handset properly says NOT REGISTERED in the display. When you take your handset off the base press the centre button between the two brass lugs down for 3 seconds with a small pointed tool, then light on the base will start flashing. Now press the handset key on the right of the dial and the display will say REGISTER BASE ? then press OK (centre of dial) It will now search and when it finds a base it will come back with an address in the format 36-000077XXXXXX then press OK again and it will say registering. If it comes back and says ENTER PIN then put the default 1111 followed by OK
Keith Saunders
- Posts 3,810
Tony, If your handset says NO SIGNAL then the radio signal between the base and the handset is lost. I am assuming that you are in range of the base station, so the problem will be the RF chip on the PCB in the phone. This means the pcb would need to be replaced. Are you a technical person who (with instruction) could do basic board replacement ? Are you located in the UK ?
mattT
- Joined on 11-25-2007
- Posts 4
Keith, Hi i've got a Beocom 6000 Mark 1 with one base and two handsets one of the handsets has started to show No Signal and when you can get a signal there is interference. Reading the Thread above it sounds like the RF Chip may need to be replaced, do you happen to know how easy this is to do and if it is difficult is there somebody I could send the handset to ? Many thanks for your help Matt
Keith Saunders
- Posts 3,810
Matt, Welcome to Beoworld.. You can no longer obtain the RF chips for the Mark I Beocom 6000, however a Mark I Beocom 6000 can be upgraded to a Mark II except the upgraded version does not have the earset socket, and still works on a Mark I charger. The kit to do the upgrade is about £50 per phone. Let me know if you want to have your phones upgraded and I will give you more details.
mattT
- Posts 4
Hi Keith, Thanks for this, if you think the upgrade kit will fix the problem with the handset not picking up a signal then yes I would like to hear more details, I assume the upgraded handset will still work with my Mark 1 base ? Is the kit easy to fit or is it best to get a specialist to do it ? tks Matt
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
Not difficult at all. Just screws and a few leads to plug in. Most difficult bit is getting the case apart!!! Keith can give instruction on this as he did for me. Worked a treat.
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
joeyboygolf: Most difficult bit is getting the case apart!!!
Four strips of a cut up defunct credit card works for me. Andy T.
joeyboygolf
- Posts 3,252
jandyt: joeyboygolf: Most difficult bit is getting the case apart!!!
Good Idea!!
mattT
- Posts 4
Cheers, I wait with interest to get the instructions of where I can get the new chip from and how to replace it. Matt
Keith Saunders
- Posts 3,810
Matt, Assuming that you are happy to take the Beocom 6000 phones apart, then you can purchase an upgrade kit part number 3455103 which consists of a new board and display, new front panel and two connecting pieces. Most dealers do not know about these kits, hence why you will need the part number. In fact everything you can see below is in teh kit:-
You will also need a tool to open the unit, but with considerable care it can be opened with other tools. There are NO instructions with the kit except for a message to say that all parts must be used. The reason it says this is because some people may not used the two items in the plastic bags which look like a piece of cut off black and white plastic, but they are actually made of rubber with metal conductors inside and MUST replace the existing ones. If you feel you cannot perform this upgrade and you are in teh UK then please PM me.
mattT
- Posts 4
Thanks i'll talk with my dealer tomorrow to see if they can get the upgrade kit, if so i'll order it and give it a go if I run into trouble i'll ping you a PM to see if you could help me. cheers for the advice. Matt
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
hi, could you expand on the "technique" for opening the 6000 case? (i.e.) after screws are out... where is best place to slide the cards, what to avoid, etc... any pics? thanks in advance,
burantek
- SE USA
- Posts 6,214
keith, thx for the expedient answer. i will try this evening. on another note, (i posted this elsewhere) i believe i ended up w/ a "european" 6000 in an ebay transaction. is there a difference between euro phones and usa phones? can i make this a usa phone w/ a software change? -or are there any "mechanical" differences prohibiting this? again, thanks!
Keith Saunders
- Posts 3,810
When I talk about the Beocom 6000, it is not the same as what is sold in the US. The US & Canadian versions are called Beocom 1 and are basically the same from a user viewpoint, but the software and base power supply etc are different. To determine the version you have, I would look at the label underneath the battery, in particular the 4 digit "Type" number. A US Beocom 1 is type number "0842" and there is a different type number for almost ever European country because of Language, phone line type and power etc. You may already know this information because of the Power plug type on the associated charger because European, US and British power plugs are all different.
