1st March February 2012
Latest post 02-28-2012 7:24 PM by Eugene. 523 replies.
Paul
- Joined on 10-07-2010
- The Netherlands
- Posts 103
Re: What Are You Working On Now ?
yachadm:
Can you post some close-up pics of the actual laser unit and its flexible PCB.
You may have to do some disassembly here.
I'll try and identify the replacement laser for you.
Menahem
Hi Menahem, here are some pics from the unit (I disasembled the PCB)
yachadm
- Joined on 06-24-2007
- Jerusalem, Israel
- Posts 687
Tomorrow, I'll go through my laser database, but in the meantime, you should check the ESR of all those SMD electrolytic capacitors. Perhaps the laser is fine, but it is not getting good power because of bad capacitor(s).
Do NOT touch that variable potentiometer between the capacitors - it has nothing to do with laser power!!!!!
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
Paul
- The Netherlands
- Posts 103
yachadm:
Hi Yachadm. Did you find someting? I saw on ebay a VAM1255 laser for sale. I searched on the internet for the difrence between a VAU en a VAM. I didnt find the answer. Do you know where i can buy the sprockets, i want to replace these as well becuase they look a bit worn
yachadm
- Jerusalem, Israel
- Posts 687
Hi Paul
I didn't forget you. I contacted my supplier in Taiwan for clarifiaction, but as yet, I have not received an answer.
I'll send you a PM if I get something.
Menahem
Step1
- Joined on 07-06-2008
- Manchester
- Posts 961
Anyone want to hazzard a guess as to why this servo motor was a tiny bit strained when running one way bit when rotating the other was fine?
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Step1: Anyone want to hazzard a guess as to why this
Wonderful photo!
Do I see part of the insulating(?) wrap around the winding flapping about?
Step1
- Manchester
- Posts 961
Well spotted Mika!
@Menahem this is a naked servo motor out of a 400x series...
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Away from home working on a 40 long tons printing m/c, want to go home a start on my BM 4000, parts from Martin arrived.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Rich
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
Søren Mexico:
Best of luck. Love my BM4000.
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
harrykym
- Joined on 08-04-2008
- Rossendale
- Posts 86
Hi did you find out? I need a vau1255/21 for my beosound 1, it's the same as the one pictured. Been following your updates for an answer!
BS-3, BS-1, BS-OVERTURE, AVANT-28"RF, AVANT-28" DVD, AVANT 32" RF, 3xBEO-4, LC-1, 4xBEOCOM-6000, BEOCOM-2, A9 KEYRING, DVD1, Beosystem 10, BEOCOM 3, BEOLAB 2500, BEOSOUND CENTURY, BEOLIT 707
yachadm
- Jerusalem, Israel
- Posts 687
Sorry, no answer on that one - maybe it's an unnecessary question, but did you try your local B&O dealer?
harrykym
- Rossendale
- Posts 86
My local dealer won't sell me parts!
Søren Mexico
- Mexico city
- Posts 1,621
Finally got to it, here
Sidi
- Joined on 10-06-2011
- Vienna, Austria
- Posts 3
Hi and a Happy New Year!
As it is my first post in this forum I'd like to share my good mood because of finishing my work on my "found in the rubbish for free" Beocenter 1800.
Turntable motor wasn't running, some small but easy to find broken wireing issues and finally a not working speed selector.
But as of this afternoon everything is fixed and tested. And after a friend of mine told me his parents wanted to get rid of their Penta 3s - it even sounds more than wonderful!
On the first step I thought everything should stay original, but I couldn't help pimping the wiring a bit: Additional to the DIN jack it now has stereo Chinch jacks IN and OUT - even they are working perfect.
Maybe for the next step I'll try to revive my Sony D-99 Discman ;-)
Greetings Sidi
Absolute Beginner in B&O things, but hey, everyone started once
Søren Mexico
- Mexico city
- Posts 1,621
Sidi:
Greetings Sidi
Good job Sidi, and a good looking Beocenter, if someone else contacts you about "getting rid of their Pentas", please contact me, I can help
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
My 3rd pair Penta's refurbished with new cloths and a selfmade perspex cover and stainless steel mirror panels (yes, again) for the amps.
For this I had to make something. Why not using a halogen lamp from a copy machine to do the bending of the perspex.
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Eugene
- Joined on 12-17-2008
- Posts 589
ingenious Leslie. Beats a heat gun
Leslie
- Netherlands
- Posts 2,201
Hi Eugen, long time
Søren Mexico
- Mexico city
- Posts 1,621
Good job Leslie, I use to heat an iron tube, shaft or flat iron, depending on the bend type, but your idea is exelent, must check in the shack, there must be an old copier somewhere.
Leslie
- Netherlands
- Posts 2,201
When you found your copier show us what the result is Soren
Todd
- Joined on 09-01-2009
- Columbus Ohio
- Posts 136
Leslie,
"The Cx50's & 100's & now your own creative use of a halogen lamp for The bending of a selfmade perspex for those formiddable looking blk & red Pentas!*Haay, 'You The Man"
Keep On Doin' your Thang!
You Do it wel!! My Friendl...One of these days soon I hope too learn even if I have too cross the pond & come knocking at your door'
