Latest post 02-28-2012 7:24 PM by Eugene. 523 replies.
Page 9 of 21 (524 items) « First ... < Previous 7 8 9 10 11 Next > ... Last »
  • 03-10-2011 10:40 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: What Are You Working On Now ?
    Beocord 8002, check (or simply replace) the record/playback relay near the tapehead cable socket.
    If it has a dolby switching relay too, replace that one as well.
  • 03-10-2011 4:54 PM In reply to
    Finally got around to opening up my very first piece of Beocrack that I won at auction a few years back. It has never been a problem, so for sentimental reasons I had always just left it alone.
    and found a little surprise inside
    I guess I opened her up for the refurb in the nick of time. Probably wasnt going to work a whole lot longer heating up like that.
    This here refurb has been brought to you by Fujicon !!! Maker of low cost, high temp, low ESR general purpose radial capacitors.
  • 03-18-2011 8:53 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Sorted out 3 Beomaster 6000's over last 4 weeks and the last one was great until the last check, when an led segment seemed to have dissapeared!
    Knew it was not drys as I had checked and sorted these, so the next most likely culprit was the display :(
    So, stripped it down and then decided to take some pics as I went along!
    Pretty small you can see the led's are mounted directly to the board, common anode. The 'whisker' seems to be intact here so I place my meter probe directly on the chip itself and it certainly was dead.
    Prepared the surface as abiove then tinned ready to accept an SMD LED....
    Soldered the new chip in place. At this point I am worried about it being too bright, compared to its 30 year old cousins, and sure enough, it was!!!
    A little masking helped here, better than messing with resistors!
    Quite happy with the result!
    Olly.
  • 03-18-2011 9:00 PM In reply to
    Brilliant pics, Olly!
    Would make a killer framed set of prints!
    • B&o bottle opener
  • 03-18-2011 9:01 PM In reply to
    Amazing macro there, Olly Yes -  thumbs up
    -mika
  • 03-18-2011 9:04 PM In reply to
    SNAP! ...again, Mika! Laughing
    • B&o bottle opener
  • 03-18-2011 9:46 PM In reply to
    Idea A 'eureka !' moment for me. Thanks Olly and good work.
    Fugicon caps explode when mounted backwards. Made a hell of a mess inside and didint find  the casing until Sunday. It was blown straight up and must have ricochetted off the cieling and into the closet behind the work table.
    amazingly the Beomaster never lost power and was actually still playing music when it happen about a minute into low volume sound tests. Knew something wasnt right cause the set was emitting a foul oder when I was powering up for function test with no load on the system.
    Replaced the cap, correctly this time and the 3000 plays just fine.
  • 03-18-2011 9:59 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Eugene:
    At least they're small, unlike these:
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 03-18-2011 10:18 PM In reply to
    I used solen to recap a set of RL60's. Barely fit. i was concerned I would not be able to get the back speaker housing to mount back on they took up so much space.
    Here is a cross I did last summer for a set of S-80.2. Again barely fits the board with clearance becoming a big concern. But it did fit. Barely.
  • 03-18-2011 10:59 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Ta, not sure if the wife would agree with the above replacing pics of the kids though Laughing I guess I could go back and take some more arty versions and pop them up a bit - the displays with guides, but without filter looked quite amazing with a twinkle effect but I could not capture that on camera... For quick pics which required lots of Dof like this my Nikon 8700 ruled and I do miss it, despite having an SLR! It was a very nice but a challanging and awkward camera!
    Olly.
  • 03-19-2011 12:47 AM In reply to
    This thread is my favorite, Thanks Olly, thanks Eugene, amazing pics amazing stories, love it
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 03-19-2011 3:35 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    I've got a BeoMaster 2400 open here, with a bad Balance slide-potentiometer.
    I usually disassemble and rebuild these, but this one is beyond repair.
    The Treble and Bass pots are NOT suitable substuitutes - completely different taper, as well as the wrong resistance.
    Does anyone have a spare one? - it could be from a BM1900 also.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 03-19-2011 4:24 PM In reply to
    Just a tip, you can also use the potentiometer of a BeoMaster 2200/BeoCenter 3300/4000!
  • 03-19-2011 7:49 PM In reply to
    Making support plates for RL 140s for floor and wall mounting, Martin needs them, so its a must do Smile
  • 03-19-2011 8:15 PM In reply to
    Waiting for glue to dry
  • 03-19-2011 9:39 PM In reply to
    Eugene:
    And you love it, put on some good music, mix a drink and enjoyWink
  • 03-20-2011 1:13 AM In reply to
    Søren Mexico:
    Eugene:
    I wish. Instead I updated and organizes my B&O files on my Flickr site and am reclothing the "frets" on a few speakers.
    http://www.flickr.com/photos/outland1/
  • 03-20-2011 1:39 AM In reply to
    Thats some nice pics there, may I go there and go through them slowly, or are you going to password them
  • 03-20-2011 2:06 AM In reply to
    no password so have at it.
  • 03-20-2011 6:10 PM In reply to
    Just made a RL 140 plate for Martin, waiting for his OK to make the next one, the right one is original
  • 03-20-2011 6:14 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    That is amazing :)
    Olly.
  • 03-20-2011 7:27 PM In reply to
    Dos thumbs up!
    • B&o bottle opener
  • 03-21-2011 3:16 AM In reply to
    burantek:
    Dos thumbs up!
    Love your SpanglishSmile
  • 03-21-2011 6:00 PM In reply to
    Finished the 2nd plate for RL 140s, it was a back to basics work where I had to remember what I learned as a pupil back in 1968-72, cutting, marking, bending, filing to exact measure, checking all angles and drill all holes. All done with the help of a good bench vise, colum drill, hack saw, files, hammer and some cubas. I enjoyed it, today mecanics only change spareparts and forget the art of working with head and hands.
    As I run out of black paint, I stripped the black one and gave both a primer, so Martin will have to spray in the color he prefere.
  • 03-21-2011 6:09 PM In reply to
    Maybe I should hire you to make me a set of Redline 60 floor stands Soren Mexico.
