Latest post 02-28-2012 7:24 PM by Eugene. 523 replies.
Page 3 of 21 (524 items) < Previous 1 2 3 4 5 Next > ... Last »
  • 12-19-2010 9:16 AM In reply to
    Re: What Are You Working On Now ?
    By the way, talking about these frames, I am missing 3 parts!
    Display panel, middel section, lower part
    Touch panel, middle section, upper part
    Touch panel, right part.
    Gave the last part away to a Beoworld member and now you see I need it for myselfSad
    Please PM if you have these for sale (or free)!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 12-19-2010 10:34 AM In reply to
    Step1:
    Leslie:
    Super AngryAngry
    tournedos:
    Leslie:
    Make sure to align the glaspanels properly the first time (with this tape) or else you have to do it all over againSuper Angry. This is really good stuff!
    ...and remove ALL of the old tape from both surfaces first, or the end result will be too thick, and... you have to do it all over again Super Angry Laughing
    And make sure you have fitted the right frames on the glaspanels (theAngrySleepy're not all the same) or else you ....againSuper AngryIck!Confused
    And don't forget - ends on first, then very carefully space the middle sections (use card) for the right gaps to match doors, or it will look wrong, and you will.... Super AngryLightningSad
    Have another one, do not forget to put in the nut first, in the left upper and lower frame or elseStick out tongueSuper Angry
  • 12-19-2010 4:32 PM In reply to
    • jl13
    • Not Ranked
    • Joined on 10-17-2010
    • Posts 8
    Good evening everybody,
    nice set
    jean louis
  • 12-19-2010 6:46 PM In reply to
    Soren Mexico made me do it.
    Been sitting on a defective 2400 purchased on the cheap last summer. Finally got around to tearing it open and fixing it. Had to canabalize a donor unit for an LDR and the tone control/balace sliders wre intermittant in provideing good contact. Probably fixable but I was lazy and just harvested that whole board as well.
    Testing at low volume levels on FM5 dialed into NPR. Sounds wonderful.
  • 12-19-2010 6:58 PM In reply to
    Fix your sliders and keep in stock, I may need some later on WinkBig Smile, I play my BM 2400 with my BG 2404 every day now, but my S45s needs new surrounds and are getting worse for wear now. Your working space looks like mine, I use Tupperware for the screws and odd pieces, then I can put a lid on them for storage.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 12-21-2010 2:43 PM In reply to
    • weber
    • Not Ranked
    • Joined on 09-08-2010
    • netherlands
    • Posts 4
    thanks,  I just ordered a roll. there will be certainly some left though (4 meter) but others might  find it usefulll too.
    marino
  • 12-22-2010 10:16 AM In reply to
    Rearranging and got my S45s on stands I made earlier this year.
  • 12-22-2010 12:13 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    So simple and beautiful!
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 12-28-2010 8:24 PM In reply to
    Listening to my rebuilt Beomaster 2400. My favorite of the flats. just a really nice smooth reciever. I have 2 that I have recapped and relamped in the last 6 months with one more to go.
    At the rate I am going I will have as many as Burantek once had in a few years.
    Pictured below is one of my favorite setups a BM 2400 BG 1700 BG CDX with a 3 input rca switchbox connected to the tape socket
     while I was listening to this I was busy putting together all this.
    I have a lot of work to do
  • 01-08-2011 7:16 PM In reply to
    Fighting a BG 6500, servo motor problems, the motor and its PCB OK, something else is wrong and I just dont get it, 2 days now.
  • 01-09-2011 2:43 AM In reply to
    Søren Mexico:
    Fighting a BM 6500, servo motor problems, the motor and its PVB OK, something else is wrong and I just dont get it, 2 days now.
    Never knew that a BM6500 (Beomaster 6500?) has a motor inside and what's a PVB?
  • 01-10-2011 8:50 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Finished the Arcam CD72 - sounds great!
    Finished the cap upgrade on the BC9300, now stuck on no audio AC output on the preamp PCB - see my other post.
    Hanging in there!
    Menahem
  • 01-10-2011 9:41 AM In reply to
    Leslie:
    Søren Mexico:
    Sorry, edited
  • 01-14-2011 12:03 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Søren Mexico:
    Got to my BM 2400
    On the bottom left corner, is that a toroidal power supply?
    Evan
  • 01-14-2011 4:05 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    A toroidal transformer Evan, yes! Common in quite a bit of B&O stuff - I am sure more for it's dimensions than stability & regulation - strong points if you are wondering!.
    Olly.
  • 01-14-2011 4:26 PM In reply to
    Step1:
    A toroidal transformer also has a much smaller stray magnetic field than a regular E core (dunno if that name is used in English). This could've been an issue in many B&O devices simply because they are so cramped - look at the 3000-4000 series Beomasters for example, they have the conventional transformer inside a separate metal enclosure. But I'm sure the deciding factor has simply been the physical size.
    Sorry for the sacrilege but I find this a good occasion to post this pic of my old Pioneer A-9 amp (1982 or so) I sold some years ago. With a max intake power of 820W, can you imagine how big and heavy it would've been with a regular transformer Smile
    -mika
  • 01-14-2011 4:34 PM In reply to
    Søren Mexico:
    Leslie:
    Søren Mexico:
    Sorry, edited
    BeoMaster 6500 has a motor inside for the cooling fan for the amplifierboard.
  • 01-14-2011 4:41 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Step1:
    I have never seen one in B&O before! I have one toroidal amp at home (Niles). All the people at my local hifi store say toroid is the bomb.
    Yes -  thumbs up
    Evan
  • 01-14-2011 4:46 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    tournedos:
    Step1:
    Thats a doosey!! I am about to go install a cooling fan on my new Niles SI-275. Maybe I'll be able to snap a pic with the tin off Smile Its not exactly close to that Pioneer you have but still big!
    Evan
  • 01-14-2011 5:09 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Good points tournedos. That is a heck of a beefy toroidal there!
    Oh I like the phrase E core - I think we normally just refer to them as transformers, laminated transformers if you want to sound knowledgeable :)
    BTW, I have always wondered how they make toroidal transformers... I am sure there is a simple way maybe like seamless shirts but it is one of those things that remain unanswered!!!
    Olly.
  • 01-15-2011 12:06 PM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    My BeoMaster 3400 also has a toroidal transformer - I think that it's something to do with more oomph per cubic centimeter, than anything else.
    And the flattish top-accessible units are squeezed for internal space, so a toroidal makes more sense.
    Menahem
  • 01-15-2011 12:49 PM In reply to
  • 01-15-2011 8:43 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    My first toroid, a Niles SI-275 amp Big Smile
    This guy is responsible for moving the Conas.
    Evan
  • 01-15-2011 8:54 PM In reply to
    BM4500? What about my FB review of the SI-275?
    • B&o bottle opener
  • 01-15-2011 11:30 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    burantek:
    The SI-275 is downwind of the BM4500 via Powerlink and an adaptation from Steve @ Sounds Heavenly.
    Jeff, I figured by now you would have gotten yours all hooked up, have you? This amp is working hard for me, pushing 10 drivers with total ease. I'll get a review together asap!!
    Evan
