Latest post 02-04-2012 11:00 AM by Evan. 131 replies.
Page 5 of 6 (132 items) « First ... < Previous 2 3 4 5 6 Next >
  • 12-29-2011 1:07 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Snap crackle pop! [:(]
    Todd:
    Hey Evan,
    "In any case would you mind doing a photo showing exactly what Chartz is suggesting?...especially the pre-amp section ot the 47k trimmers?
    *Oh and thanks for answering my previous questions on the Caps & why the use of the bubble plastic*
    Circled in red is the main 5000uF reservoir capacitor. Jacques recommends I change this because of potential failure. The failure of these three main capacitors give a distinct symptom to the sound output of the amplifier, a low 60Hz buzz (AC current).
    Circled in green are the trimmers on the main amp board. These are used to fine tune the amplifier and over time corrode, losing sound quality. There is also one in the upper right of the photograph, circled in yellow, on a different board that will be replaced.
    Finally here is the preamplifier board, with no less than 6 trimmers. These will be replaced also and for the same reasons.
    Evan
  • 12-29-2011 10:24 PM In reply to
    • Todd
    • Top 500 Contributor
    • Joined on 09-01-2009
    • Columbus Ohio
    • Posts 136
    • Gold Member
    Hey, Thanks for circuling out the trimmers and showing the preamp board! Yes, few more things I know and can follow nowBig Smile
    Todd
  • 01-06-2012 4:23 PM In reply to
    Evan:
    Hi Evan, I would like to change all the trimmers in my BM 4000, but as I only have a digital and an analog multimeter I dont know how to adjust them, or do I check the setting on the old ones, once out, and then set the new ones to the same value ???
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 01-06-2012 5:09 PM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Søren Mexico:
    Evan:
    Indeed my friend, indeed!
    Jacques
  • 01-06-2012 5:17 PM In reply to
    Thank you Jacques, will do.
  • 01-07-2012 12:07 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Hey Søren, sorry I could not reply in time, I have been busy. Good thing we have Jacques around, otherwise these projects would never get finished! Laughing
    Evan
  • 01-07-2012 12:28 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Embarrassed
    Well I'm no Martin or Peter but ta!
    Jacques
  • 01-21-2012 7:51 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Hi everybody, just thought I would post my current status. There it is - in a pile! Sitting down to sort out my cap shortage now and order a few things.
    Does anyone know exactly what the value of the trimmers are on the pre-amplifier board? The service manual says 50k ohm. Should I trust that figure? And also, are they all the same? There is only one trimmer listed in the parts list. I don't know how to shop for these - any size measurements? Help!
    Thx, E
    Evan
  • 01-21-2012 8:25 PM In reply to
    In my 4000 there are also 6 pcs. but they are all 100K R so 50 K for yours could be right.
  • 01-21-2012 8:32 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Alright. Many sources are saying 50k Ohm. Do you know how to size these things? Do I shop by lead spacing or what?
    Evan
  • 01-21-2012 8:48 PM In reply to
    Carbon and lead space I use these the pic is wrong just be sure you get top addjust, so yours should be PT10LV10 and 50K Ohm.
    I was lazy today doing absolutely nothing, just hanging on the forum.
  • 01-21-2012 9:11 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Søren Mexico:
    Ok, great - will look into this.
    Søren Mexico:
    I've definitely done that before!!! Yes -  thumbs up
    Evan
  • 01-21-2012 10:30 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Even though I am roughly 50% done with my overhaul, I decided I should test my 3000 and see whats up.
    I fastened in the pre-amplifier board and soldered in the respective ground wire. I didn't bother with putting the bottom or cover on, so I proceeded to plug it in.
    I grabbed a 3.5mm > RCA lead, my Form 2s and an iPod (only for testing Soren, not a permanent source Wink).
    I started my iPod playing my new Two Door Cinema album (Something Good Can Work) and flipped the switch.
    Sliding the volume up, I heard some brilliant, stereo, full range music! It was like walking into a party!!!!!  I applied the loudness and just kept the volume coming. At this point I was hovering around the 4-5 mark on the scale. I threw my trusty old list of demo songs at it and the 3K threw them right back!! WOW! Can't believe how amazing this machine is.
    I kept testing and stopped and thought to see if I had remembered my DIN2 cables - I did Surprise.
    I swiftly uncovered my S45-2s and plugged them in. Removed the Form 2s and engaged speakers 1. The 3000 got off to a rocky start, cutting in and out as I brought the volume on but stabilized in the range of 30 seconds or so. It's playing as if it never had a thing wrong with it!!! I can't believe I've let myself go without this sound - absolutely mind blowing!!!
    Having a proper celebratory jam here CoolSmileDrinks
    Evan
  • 01-21-2012 10:41 PM In reply to
    Evan:
    Celebrate Evan, what a wonderful feeling, it goes right to the heart and ones head starts spinning, on ones face a stupid smile, will brake out my best Rum and celebrate with you, congratsCakeDrinks
  • 01-21-2012 10:51 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Brilliant, Søren, absolutely BRILL! It was a great feeling and a yes, there was a ridiculous smile!! Cheers mate!
    Crank up your tunes and jam, let's party. Come on BeoWorld, everybody now - 'There's a spanner in the works you know-oh!'
    SmileSmileSmileSmileSmileSmileSmile
    Evan
  • 01-21-2012 11:06 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Switched to some live Phoenix to keep the party rolling!
    Evan
  • 01-21-2012 11:13 PM In reply to
    Well I just have to[:'(]
  • 01-21-2012 11:39 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Evan:
    If you are just tuning in to the fun -
    http://www.youtube.com/watch?v=Wxu02vp_Vm0
    Smile
    Evan
  • 01-21-2012 11:59 PM In reply to
    I took of Chuck Berry, and went for your link, from my PC speakers I will call it a nice little truttelut, but sure will sound better on a real thing.
    Back to Chuck, 3rd cuba party, life is playing
  • 01-22-2012 12:17 AM In reply to
    Got a little sentimental with all this joy, BMs working, BGs working, I put on Brenda Lee, if I put on Ray Conniff, tell me to go to bedLaughing
  • 01-22-2012 3:57 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Hi!
    Since I don't receive anything from Beoworld anymore (?) I had missed that one... Sorry!
    I used 47k trimmers by the way... Embarrassed
    Great job anyway!
    Jacques
  • 01-22-2012 8:42 AM In reply to
    Evan:
    Don't get too enthusiastic - someone will be really disappointed Stick out tongue
  • 01-22-2012 8:56 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    LaughingLaughingLaughing
    I'm sure the 4000 is only getting anxious Wink
    Evan
  • 01-22-2012 9:28 AM In reply to
    chartz:
    Hi!
    Great job anyway!
    Jacques, its time for a new server. I have some misses or time outs here too
  • 01-22-2012 9:30 AM In reply to
    hemenex:
    Forgot about that one, one more party coming up, Big Smile
