Latest post 12-05-2010 1:21 AM by clifft. 130 replies.
Page 1 of 6 (131 items) 1 2 3 4 5 Next > ... Last »
  • 11-10-2010 5:38 AM
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    The BeoSound 8 - Live Review!!!
    Well, here we are. It’s Wednesday 10th November 2010 and BeoWorld is here at the swanky St Martins Place Hotel, London WC2 for the launch of the long awaited Beosound 8 iPod Dock along with tech journalists from all over, erm.. the interwebnet and Fleet Street?!
    Anyway – we digress.  You may well want to know what the BeoSound 8 is actually like – so here goes. Forgive me if I skip around as there's a lot to say in a short space of time – I’ll try and keep this review as orderly as possible.
    Well, the BeoSound 8 looks very B&O in its design.  No external styling cues from any other manufacturer  (perhaps 'Gossard' or 'Victorias Secret' from some angles but we digress again), so this is a very unique and individual design – exactly what you’d expect (and indeed demand) from B&O.  It’s all about sound here though, and the two huge round speaker covers help remind you that there’s some serious noise just waiting to be unleashed right behind them.
    The rear of the unit itself is covered in the ‘soft touch’ coating we see on the more recent B&O products such as the BeoLab 3 and Serenata etc - and the main two colours available ‘off the shelf’ will be Black (with Black covers) and White (with White covers).  B&O are also producing a range of replacement covers to personalize the unit further in various pastel effect colours such as Lemon, Light Purple, Light Blue and Green. These should retail at around £40 per pair.
    The central section of the unit (called 'the bridge') is finished in brushed aluminium (what else?!) with a standby/active light within what you expect to be a scroll wheel in the centre.  However, try and scroll (the natural thing to do for most Apple and B&O users – of which I am one) and you’ll find it’s actually fixed.  You can click the top to increase volume, down to decrease – plus click left and right to skip tracks – but that’s your lot.  Somewhat disappointing as it would surely have made more sense to have a scroll wheel for volume control on a rocker for track selection, then a central button for source change.  Even the universally unloved Serenata had that !!!
    Still, you get a natty little remote control thrown in for free – which although a bit odd in its design is nicely finished in brushed Aluminium to the front and sits at an angle on a flat surface thanks to a ridge on the rear.  Again, it would have been nice if the remote somehow integrated or attached to the dock to save it getting lost – but if you’ve just paid circa £895 for the system you’re probably going to be very careful with it!
    Two little peg feet (similar to those found on the TV table stands) protrude from the rear at an angle to allow a neat table placement angle.  These are of course removable should you wish to use the wall mount. A nice little touch is that although the unit appears to have the bottom of the circular driver housings touching the surface of the table/desk – it actually clears it by around 1-2mm.  Impress your friends by magically sliding a piece of paper under them and telling them the unit actually floats. That may justify the price tag to the uninitiated.. LOL
    At the rear, we have a removable panel which exposes the connections..  The first thing we see is a position switch similar to the Active Loudspeaker range which allows three placement settings, those being ‘Corner’, ‘Wall’ and ‘Free’ to achieve maximum sound reproduction.  A fairly impressive feature for an iPod Dock you must agree!  The unit comes with a rudimentary wall bracket included in the price too, but as opposed to a long bar to hang the unit on we have two individual pieces to line up badly as we struggle with our black and decker drill in one hand and a spirit level in the other!  I’m no handyman though, so it might not be that difficult.. (he says).
    Connections..  Well, you’ve got direct Line Level Stereo Phono inputs (imagine plugging a BeoGram 4500 straight into it – how cool?!!) as well as a USB port to pluck music from your Mac/PC etc, then Bluetooth, then of course the actual iPod Dock itself.  It has clearance enough to hold an iPad as well as all generations of iPhone and iPods, with a circular support disc which manually winds in and out on a screw thread to adjust for the various thicknesses of product docked upon it.
     Once docked (and charging of course), you can skip through tracks using the remote provided, or use your Beo4 / Beo5 / B&O Telephone / BeoTime Alarm Clock or manually press the button on the dock itself.  Bang & Olufsen are providing a free App in the App Store called 'Beoplayer' which gives 20 free radio stations (subscription can get you thousands more though) and a BeoCom 5 style clock display for your iPod/Pad/Phone which looks incredibly pretty. Nice touch..
    Connections wise though – it seems a bit of a jumble if I’m honest.  If you’ve got your iPod/Pad/Phone on there, it takes preference and will play automatically. If you have your computer connected via USB, that takes second preference, then bringing up the rear is Bluetooth in third.  However, what if your iPod is charging and your computer is connected – but you want to connect and play a device using Bluetooth?  Well, you have to disconnect the USB and remove your phone!!  No source choice function at all.  Confusing and disappointing, especially as it could have all been on the scroll wheel (which isn’t there..)
     Now – the bit you may all have been wondering about..  What does it sound like?
     Throw away your Zeppelins.  Ebay your e-docks.  Bring your Bose to the jumble sale – the BeoSound 8 is here !!!
    Yes, it’s up to several times the price of many of it’s competitors – but boy, do you get what you pay for.  I can only describe the top frequencies to be akin to BeoLab 3’s – pin sharp, tight and precise. You’d swear it had an acoustic lens in there when listening to a high quality Mp3 track – I was truly astonished.  A pair of active 2 way speakers means four individual amplifiers for your listening pleasure, Sir..
    Bass.  Yes, it has it in spadefuls – and I really cant understand where it all comes from!  Again, I’d say with the right track it’s somewhere between a pair of BeoLab 6000 and a pair of BeoLab 8000.  Punchy, tight – and really booms when the track requires it.  This Dock is immense when it comes to what matters.
    I was a little disappointed with a standard ‘lossy’ Mp3 track though, which sounded muddy and confused – but after actually thinking about it for a moment, it was the quality of the BeoSound 8 that was ruthlessly exposing the poor recording.  Not the docks fault at all, and if you’re lucky enough to own a pair of BeoLab 5 you’ll know that they too will crucify anything less than a very high quality master or Mp3.  Such is the price to pay for high quality reproduction - you can only work with what you're given, and if the BeoSound 8 could speak it would say that right to your face!
    Would I buy one?  Yes, absolutely – but I’m a B&O ‘nut’ so I may be biased.   These will sell by the lorry load to the B&O faithful and will hopefully provide an ‘entry level’ Bang & Olufsen product to impress ‘non believers’ and get them into the brand.  £895 for an iPod Dock is not to be sniffed at, and although the Zeppelin is less than half the price – the BS8 isn’t twice as good..  I’d say around 50-75% better than the B&W (I own a Zeppelin myself), but if you want the best you pay the price - that's life.
    Afterthoughts?  Well, apart from B&O missing the boat on the controller, I’d say they may have missed an opportunity to make this a fantastic Link Room Speaker.  A small, one line display perhaps, and a MasterLink Socket?  It thrashes the ageing BeoLab 3500 as far as sound quality, it beats it on price, and can indeed be wall mounted.  You could even have taken a few cues from the BeoSound 5 Encore and had it connecting wirelessly to a BeoMaster 5?  Maybe for the future….
    B&O really needed a product like this - and in my opinion they haven't disappointed.  People said the BeoSound 1 was ugly upon release compared to the century - and i'm sure people will say the BeoSound 8 is ugly compared to the BeoSound 1.  New things take time to get used to - but to me this is a winner from the start.  Not sure about the 'Pastel' covers - they are certainly fashionable if you look at the colour trends of the last few years, but if you want to keep right up to date it may be an idea to do bold patterns and perhaps climb into bed with companies such as Paul Smith, Laura Ashley and other high end designers?  Limited Edition covers will get people into dealerships, and also provide a talking point for their latest new B&O addition?  Only a thought...
    Over to you guys....
  • 11-10-2010 6:17 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Re: The BeoSound 8 - Reviewed - Live at the launch!
    A couple more hurried images - better ones to follow...
  • 11-10-2010 6:19 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    The coloured frets. Mellow!!
  • 11-10-2010 6:20 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Around the side..
  • 11-10-2010 6:39 AM In reply to
    Thanks for that Lee and I think the Bs 8 looks great Big Smile The scroll wheel would have been a nice touch on the unit and a connection  for a link speaker as wellSad But I think another winner over all.
    Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
  • 11-10-2010 6:49 AM In reply to
    I hope there will be a second version soon with Apple's Airplay built-in.
    The Zeppelin will have this update very soon.
  • 11-10-2010 8:14 AM In reply to
    Good to see the new B&O mgt finally embracing the opportunities in Apple's solutions -- the clique pushing for B&O MP3 in various versions never got their act together. (SD-card, flash memory, harddisk ...)
    Apple is not a competitor, it delivers a source, which can be integrated to work at its best through B&O front-ends, speakers and screens. And discerning customers who like what both brands can offer will find an excellent synergy just waiting for them, through B&O's active speakers. Win-win for all involved.
    Nice.
  • 11-10-2010 8:42 AM In reply to
    Looks great.
    £695,maybe £750 as an absolute ceiling...with AIRPLAY and I'd buy one.
  • 11-10-2010 9:30 AM In reply to
    soundproof:
    Very well put.
    What has been lost in the build-up to launch is: here we are w/ an Apple-centric B&o product -just what "most" of us have been screaming for. Is it perfect? Is it late to market? Who cares! It is a milestone with B&o ...realizing the way forward accommodating Apple as a source -if even just with a simple dock.
    I am excited to see the product develop and especially look forward to the App that will be offered.
    I think this may be the start of a beautiful relationship. Smile
    • B&o bottle opener
  • 11-10-2010 9:55 AM In reply to
    • steph
    • Top 100 Contributor
    • Joined on 04-16-2007
    • France
    • Posts 612
    The speakers apparently are really big !
    The sound must be great ! Yes -  thumbs up
  • 11-10-2010 10:26 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Thank you for the great coverage Lee! Yes -  thumbs up
    Definitely starting to get excited about this now!
    Evan
  • 11-10-2010 11:57 AM In reply to
    • Fulgore
    • Not Ranked
    • Joined on 04-17-2007
    • Germany
    • Posts 63
    Re: The BeoSound 8 - Live Review!!!
    Hi Lee,
    thanks 4 the review.
    Can*t wait until I can have a look on the real thing.
    Sascha
  • 11-10-2010 1:06 PM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    OMG it looks ridiculous. In fact I'm slightly embarrassed.
  • 11-10-2010 1:16 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    You really need to hear it. Honestly.
    To be honest, the Zeppelin looks ridiculous if i'm brutally honest - and the Bose sound dock looks bland and unimaginitive. Most docks do actually..
    However - please do go and listen to it.  You'll want one.  Promise.
    Lee
  • 11-10-2010 1:22 PM In reply to
    • UK
    • Posts 970
    9 LEE:
    Lee
    I'm very sure I wouldn't.
  • 11-10-2010 1:27 PM In reply to
    Nice review! Shame about the lack of ML as you are quite correct - it would be a super link room set.
  • 11-10-2010 1:29 PM In reply to
    • Seanie_230
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    I am going to see it this evening at my local as they are having an event this evening Going to take my iPad and give it a whirl
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 11-10-2010 1:47 PM In reply to
    It is exactly what it is.... an ipod dock, and by reading the review, a very good sounding one at that.
    I am sure it will satisfy most people interested in this kind of thing.
    It's got a very specific design ... like it or not, but still shows that B&O has a leading edge in design and audio quality over many other manufacturers.
    As with all the good old B&O units, it's a very simple to use no frills but capable unit that will be appreciated by most user who have no need for super connectivity, Exactly what a good ipod dock is meant to be....
    If anybody wants a better integrated kind of system, there are other solutions (BS5 light?) or other suppliers for that.
  • 11-10-2010 1:59 PM In reply to
    Great review Lee!
    I'm a little disappointed as I really wanted something more dinky the size of the Zepplin MINI or BOSE? However, I'll check it out - but i do think it's too large!
    Pastel colours definately not cool! Wish they'd bring out the colours available on the BeoVision 10 grilles especially the orange!
    Was going to buy one but really think it's too large for a docking station :(
  • 11-10-2010 2:19 PM In reply to
    • Jandyt
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Totally disagree Richard!    It looks gorgeous!
    Cheers Lee!
    Poor me, never win owt!
  • 11-10-2010 2:26 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    I'm going to give you some cropped and sharpened images now. The lighting wasn't much good in the venue - certainly not condusive to an iPhone4 Camera, but you'll get the idea..
    First up, a better shot of the dock in its entirety
  • 11-10-2010 2:28 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    The little remote, 'face on' - an exact replica of the controls on the unit itself...
  • 11-10-2010 2:32 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    The remote has a little triangular ridge to the centre rear, allowing it to sit upright but at a slight angle on a surface..
  • 11-10-2010 2:35 PM In reply to
    • BenSA
    • Durban, South Africa
    • Posts 808
    • Gold Member
    I like the remote....give it the thumbs up!
    Durban South Africa
  • 11-10-2010 2:38 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    The adjustable section to hold different thicknesses of ipod/pad etc..  Screws out manually on a thread.
