Latest post 12-21-2011 12:40 AM by Evan. 151 replies.
Page 3 of 7 (152 items) < Previous 1 2 3 4 5 Next > ... Last »
  • 09-19-2010 11:35 AM In reply to
    Re: BeoSystem 4500 Restoration
    I used silicone adhesive I bought at Ace to reaffix my glass panel it works and is not permanent
    Just dont use epoxy. you will be screwed ;ater down the road if you need to get inside for service or for a general recap project.
    I was thinking maybe doing up one of my cosmetically challenge pieces in white but using a laminate material in lieu of paint Or perhaps I could just paint that  mama pink.
  • 09-19-2010 12:32 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Eugene:
    Permanence is what I'm afraid of. I don't like adhesives Laughing
    I was standing in my spray paint aisle and just thinking to myself what if I painted it lime green or even bright orange?!
    Evan
  • 09-19-2010 10:18 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1197.jpg picture by evman140
    I gave the lid its third spray, and the BeoMaster itself received three sprayings this morning before work. They were left on the outside table to dry.
    Evan
  • 09-19-2010 10:22 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Unwrapped, on the kitchen table is the lid, completed and simply amazing!
    Evan
  • 09-19-2010 10:28 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1202.jpg picture by evman140
    So not to lose the screws that hold the lid in place, I temporarily put them back in their places until the parts were ready to be put back together.
    Once out, drop in the panel and relace the five screws.
    Do not forget the little radio antenna connector, it must be reattached.
    Evan
  • 09-19-2010 10:32 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Presto change-o!
    DSCN1204.jpg picture by evman140
    Today is the day the BeoMaster 4500 became white! ....Completely that is. Laughing
    Evan
  • 09-19-2010 10:40 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1205.jpg picture by evman140
    For comparison, here is a picture of the fresh white BeoMaster next to the original BeoGram. I think I much prefer the white! Definitely makes this feel much newer and more modern.
    Evan
  • 09-20-2010 1:06 AM In reply to
    I agree = it looks really great
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 09-20-2010 4:03 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Not only does it look quite nice ATM it also looks very professional well done :)
    Can't wait to see it complete :)
    Olly.
  • 09-20-2010 1:41 PM In reply to
    • BenSA
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Well done!! Very nice indeed.......It will look even nicer once the glass panel has been replaced!!
    Durban South Africa
  • 09-20-2010 1:48 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Thank you, all.
    Status Update:
    The BeoMaster has been moved to a shelf, it will be picked up later on.
    In the meanetime, I will start on the BeoGram.
    Evan
  • 09-20-2010 3:17 PM In reply to
    Looks cool! Cool
  • 09-20-2010 4:24 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Thanks Beek!
    DSCN1212.jpg picture by evman140
    This picture doesn't do the damage justice. There is a series of small inward deformations along the crease of the lid.
    Evan
  • 09-20-2010 4:29 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1215.jpg picture by evman140
    This unit does have one thing going for it, the glass and bezel parts are still intact. Which ultimately means no damaged paint to fix! Not to mention the time I will save by not having to remount the operation panel.
    Anyhow...
    Just like on the BeoMaster, the operation panel slides to the left when released by the internal catch. I used an ice pick to depress the part.
    Evan
  • 09-20-2010 4:33 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1214.jpg picture by evman140
    On the BeoGram it is easier to remove the wire harness at the point on the PCB of the Gram, rather than on the operation panel. This is the only way to remove it since the glass is blocking the access to the connections at the other end.
    Before you remove the operation panel completely, open the lid under power. The lid comes off by sliding upwards once the tabs on the hinges are pulled away. The lid may then be closed so the unit can be wrapped for paint.
    Evan
  • 09-20-2010 4:38 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    What pray tell, are you doing with an ice pick in your house?????  Geeked
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 09-20-2010 4:46 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1217.jpg picture by evman140
    A quick look underneath just to check around.
    Evan
  • 09-20-2010 4:47 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Rich:
    LaughingLaughingLaughing
    Oh relax, its from an automotive pick set.
    Evan
  • 09-20-2010 4:49 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1222.jpg picture by evman140
    All I can see worth doing is applying some new lithium grease to the gears for the hinge motor. Belt is fine.
    Evan
  • 09-20-2010 4:52 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1225.jpg picture by evman140
    Just like I did on the Master, lightly rough up the surface with some 400 grit paper.
    Evan
  • 09-20-2010 4:54 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1224.jpg picture by evman140
    Such an easy masking! Just the sides and back to wrap, no grill or complex tabs to work around!
    Evan
  • 09-20-2010 5:02 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1226.jpg picture by evman140
    There is an odd feeling that comes with knowing that there are pieces of B&O out in your yard. Indifferent
    Evan
  • 09-20-2010 8:48 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    DSCN1229.jpg picture by evman140
    We have arrived at the end of a day's hard work. The lid is nearly completed and the Gram is ready to go, both are scheduled for final paint tomorrow AM!
    Evan
  • 09-21-2010 2:40 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    You have a PM Evan Smile
    Looking good BTW Cool
    Chris.
  • 09-22-2010 12:27 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Okay all,
    As the final coats of paint dry on the BeoGram, this thread will start to slow. I am starting back at school tomorrow.
    Also, Chris is sending me some tape for the glass panels so there may be a short hiatus.
    Stay tuned!
    Evan
