Latest post 07-14-2010 4:13 PM by 9 LEE. 7 replies.
Page 1 of 1 (8 items)
  • 07-14-2010 11:56 AM
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Help with power lead?
    Product - Beocord 1500 Reel to Reel
    Problem - Someone has emailed me (UK Based) who has lost the power lead for his product as listed above.
    Never seen this connection before - where can he get one?
  • 07-14-2010 12:11 PM In reply to
    • Dillen
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Help with power lead?
    There were some japanese receivers that used the same power plug.
    I don't remember exactly if it was Technics, Panasonic or JVC.
    1980's or late 1970's, I think.
    I believe it was a standard mains plug somewhere in the world. Something like the
    one on the lower left here:
    http://www.asia.ru/images/target/photo/50381359/Power_Cord_With_Plug.jpg
  • 07-14-2010 12:44 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Trying to assist further...
    Based on Martin's response they are available on Ebay but in packs of 10. Maybe CPC or Maplins might be better.
    This is presuming Martin's correct.......if the guy buys them and they turn out not to be right it's all Martin's faultBig Smile
    If you think nobody cares, try missing a couple of payments.
  • 07-14-2010 1:35 PM In reply to
    • Dillen
    • Posts 5,008
    Gulp.  Surprise
    The plug should be a female.
    This is an original cable:
    The part of the housing that plugs into the socket on the Beocord is square with rounded
    corners and apprx. 21mm x 12mm
    The pins are flat and apprx 5mm wide and placed apprx 10mm apart (center to center).
    Maybe a Beoworld member can recognize it ?
  • 07-14-2010 1:50 PM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Oops,
    Ignore my input - I thought the picture Lee posted showed a female socket.
  • 07-14-2010 3:34 PM In reply to
    If you do a search in EBAY but for a Revox power lead, you'll find what you need
  • 07-14-2010 3:38 PM In reply to
    • Dillen
    • Posts 5,008
    So you do !
    I never noticed that.
    Yes -  thumbs up
  • 07-14-2010 4:13 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Bingo!  Thanks everyone!!  I'm sure you've made someone very happy - just emailed the chap the findings..
    Big Smile
