Gulp.
The plug should be a female.
This is an original cable:
The part of the housing that plugs into the socket on the Beocord is square with rounded
corners and apprx. 21mm x 12mm
The pins are flat and apprx 5mm wide and placed apprx 10mm apart (center to center).
Maybe a Beoworld member can recognize it ?
