Latest post 06-04-2010 4:32 PM by Craig. 8 replies.
Page 1 of 1 (9 items)
  • 06-02-2010 4:59 AM
    What remote control do I need for a BeoVision?
    I've got a BeoVision Avant and a MX4002, and one of the Beo4 remote controls has died - kids & coffee :-(  So I need to get a replacement for one or other of the tellys - do I need to just get another straight-forward replacement Beo4, or are there alternatives that can be used? And are there any compatibility issues that I need to be aware of? Does anybody have any suggestions as to what I should be looking for?
    Thanks.
  • 06-02-2010 5:08 AM In reply to
    Re: What remote control do I need for a MX4002?
    You can use a Beolink 1000, usually half the price used compared to used Beo4.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 06-02-2010 5:41 AM In reply to
    I agree though a Beo5 would be another option if you want a new toy for the Avant. Useful if you use satellite and have an audio system as well though it does take a little getting used to. The Beolink 1000 is excellent and is also child proof! Some functions will need learning though and if you have a linked VCR to the 4002 some of the controls may not be quite as easy as the Beo4 that you are used to.
  • 06-02-2010 8:25 AM In reply to
    I agree with Peter, the Beo 5 does take some getting used to, I still reach for the 4 to be honest!!
  • 06-04-2010 2:29 AM In reply to
    Thanks for the suggestion - I hadn't considered the Beolink 1000 as an option.
  • 06-04-2010 2:30 AM In reply to
    Thanks for the reply - the Beo5 might be too much for what I need right now, so the Beolink 1000 or a Beo4 will probably be my choice.
  • 06-04-2010 2:33 AM In reply to
    That confirms Peter's view, many thanks - so it's a choice between a straight Beo4 replacement or a Beolink 1000.
  • 06-04-2010 4:03 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Do be aware, that the Beo4 your kids killed, may well be repapirable!
    Andy T.
    Poor me, never win owt!
  • 06-04-2010 4:32 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Where are you as I have a Beolink 1000 for slae at the moment?
    CraigSmile
