Hi forum ,
How can i connect an "sensor" to my beomaster 7000
It is part number 8087018 ir sensor .
description ;
Sensor
BeoMaster 7000:
8087018
Sensor cable:
6250266
Length - 50 m (3 x 0.14 mm
2
with screen). The length
between Sensor and BeoMaster must not exceed 15 m.
IR receiver/transmitter for BeoMaster, fitted with a 5 m
long cable with a 6-pin DIN plug. For connection to the
sensor socket on the BeoMaster.
For use e.g. when the BeoMaster is placed in a glass
cabinet or out of the remote control range.
The connection is not clear to me , any help ..............................
nitro2
