Latest post 02-02-2010 2:15 PM by nitro2. 9 replies.
Page 1 of 1 (10 items)
  • 01-16-2010 8:42 AM
    • nitro2
    • Top 500 Contributor
    • Joined on 10-08-2008
    • belgium
    • Posts 84
    "SENSOR" for Beomaster 7000 , how to connect
    Hi forum ,
    How can i connect an "sensor" to my beomaster 7000
    It is part number 8087018 ir sensor .
    description ;
    Sensor
    BeoMaster 7000:
    8087018
    Sensor cable:
    6250266
    Length - 50 m (3 x 0.14 mm
    2
    with screen). The length
    between Sensor and BeoMaster must not exceed 15 m.
    IR receiver/transmitter for BeoMaster, fitted with a 5 m
    long cable with a 6-pin DIN plug. For connection to the
    sensor socket on the BeoMaster.
    For use e.g. when the BeoMaster is placed in a glass
    cabinet or out of the remote control range.
    The connection is not clear to me , any help ..............................
    nitro2
  • 01-16-2010 10:20 AM In reply to
    Re: "SENSOR" for Beomaster 7000 , how to connect
    Not surprised! The Beomaster 7000 does not have a sensor socket - it was deleted from the Beomaster 5500. You will need to hard wire it in - I am afraid I cannot find the instructions for this.
  • 01-16-2010 2:14 PM In reply to
    • nitro2
    • belgium
    • Posts 84
    Aha ,
    that's why .................Sad
    peter, thanks for your reply .
    If one of the readers could help me onm this problem ,.............please Smile
  • 01-17-2010 12:08 AM In reply to
    Although this an old thread, let me respond. I just bought a Beomaster 7000, and I was puzzled with a DIN socket coming out from inside the unit. It is connected to the "P89" connector section on PC board 4 inside the unit. It appears to be a factory option that has a B&O connector on the end that plugs into the PC board. There must have been an IR sensor kit with a DIN plug that would go into the socket.
  • 01-17-2010 6:55 AM In reply to
    • nitro2
    • belgium
    • Posts 84
    i have taken out print 4 ( cpu unit ) but could not find the connector p89
    can you please help me any futher......................
  • 01-17-2010 9:53 AM In reply to
    • nitro2
    • belgium
    • Posts 84
    this is the connector i would like to attach. to my beomaster 7000 the ir extension.
  • 01-17-2010 11:42 AM In reply to
    When facing the front of the 7000, the connector is a 4 pin connector on the far left end of board 4 at the top. I was in error, the connector is P98, not P89. The DIN connector you have on your unit looks identical to mine. The Service manual for the Beomaster 6500 has diagrams in the back for the Beomaster 7000 that shows the circuit connection.
  • 01-17-2010 11:49 AM In reply to
    Nitro2 - on your other reply to me on the voltage conversion, I see you have the manual. The card layout is shown on page 11-5. Look on the far right top of the picture to see the pins for the connector socket. The connection of the pins to the circuit is shown on the bottom left page of 11-3 in the service manual.
  • 01-21-2010 2:55 PM In reply to
    • nitro2
    • belgium
    • Posts 84
    Thanks for all info ,
    the sensor will arrive next weekend.
    if someone in europe has this cable , please let me know.
    Gregg , thank you for all answers.
    nitro2
  • 02-02-2010 2:15 PM In reply to
    • nitro2
    • belgium
    • Posts 84
    Hi forum ,
    for anyone interested , here are the pictures of the connector , and the inside of the "sensor "
    maybe for future reference ................................
