Latest post 12-29-2009 5:07 AM by beoben. 114 replies.
Page 3 of 5 (115 items) < Previous 1 2 3 4 5 Next >
  • 11-29-2009 9:17 PM In reply to
    Re: Welcome BV7-55
    Can the 55 be ordered without the built in Blu-Ray player?
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 11-30-2009 2:50 AM In reply to
    • steph
    • Top 100 Contributor
    • Joined on 04-16-2007
    • France
    • Posts 612
    Re: Welcome BV7-55
    Yes,
    The Blu-Ray disc player is optional as on the 40" version.
  • 11-30-2009 7:57 AM In reply to
    Re: Welcome BV7-55
    Thanks!
  • 11-30-2009 1:12 PM In reply to
    Re: Welcome BV7-55
    What is the price difference between one with and one without the Blu-Ray player?
  • 12-01-2009 9:15 AM In reply to
    Re: Welcome BV7-55
    Given the size of the panel,how well,or otherwise,does the TV handle LCD's usual drawbacks of motion blur,and black level?
    Has anyone been able to compare the BV7-55's PQ against that of a BV4 or 9?
    If so,any thoughts?
  • 12-01-2009 6:21 PM In reply to
    • Russ
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Welcome BV7-55
    Razlaw:
    The difference is $1,800, just as on the 40".
    MSRP is either $11,000, or $12,800 (all prices are USD, and exclude any applicable sales taxes, for those of you from across the pond) for the BV-7 55, stands/brackets and speakers are also priced seperately, and are a bit more expensive than on the 40".
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 12-01-2009 6:26 PM In reply to
    Re: Welcome BV7-55
    thanks!
  • 12-01-2009 6:32 PM In reply to
    • Russ
    • Posts 641
    Re: Welcome BV7-55
    You're quite welcome!
    I imagine that some of the confusion on this point stems from the fact that all of the first production run were made in the natural aluminum, and equipped with the Blu-Ray.  So all of the photos show it that way.
    McLean, VA USA
  • 12-01-2009 10:22 PM In reply to
    • BeoNut1
    • Top 500 Contributor
    • Joined on 08-19-2007
    • Mobile, AL (USA)
    • Posts 226
    Re: Welcome BV7-55
    I never see any pics of the BV-7 sans drive.  Does it look much different?  I ask as it's tempting to consider the BV-7 with a separate component DVD/Blu-ray/Netflix player.  That way there'd be no drive within the panel to eventually need to replace.  Plus, it sounds like many of the third party Blu-ray players are better than B&O's when it comes to things like sound decoding (i.e. being able to do the HD stuff).  Also, it sounds like the Beo 4's control of the BV-7's Blu-ray player is awkward.
    Thoughts?  Anyone have any pics of a BV-7 40" or 55" sans DVD / Blu-ray?
    M
    Mark D
  • 12-02-2009 3:54 AM In reply to
    • steph
    • France
    • Posts 612
    Re: Welcome BV7-55
    Here is a pic of the BV7-32 monitor.
  • 12-02-2009 6:24 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: Welcome BV7-55
    "Has anyone been able to compare the BV7-55's PQ against that of a BV4 or 9?"
    Yes, and it is a different picture. The current BV4/9 plasma series have no major issues at all when it comes to showing moving pictures, power consumption, burn-in etc on the other hand... One thing I can't get used to on the 7-55 is the way the LED backlight works: try to watch a concert, and pay attention to the audience when cameras (the flash) goes off and note how a certain radius around "the flash"-point is lit, and then fades away. Weird. Also, the "dynamic" backlight turns parts of the screen from black to grey when turned on and this is very noticeable when you view the set from an angle - if you are used to the BV4/BV9 this will be very noticeable.
    Roger
  • 12-02-2009 6:38 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: Welcome BV7-55
    If I was planning to spend a staggering £15,000 on a TV (gawd knows how much it is in USD), I'd certainly go for the BV9 over and above the BV7-55. The picture isn't going to be any better than the BV7-40 and, indeed, could be worse (SD upscaled), has the same picture engine, same sound, same everything - just a 15" bigger screen for 50%+ more cash!
    I had the option of buying a 2009-model 1080P BV9 the other day, for 20% off RRP (so, £12,000) and turned it down. However, if you were looking, perhaps a recent BV9 is a better option, with a discount?
  • 12-02-2009 7:34 PM In reply to
    Re: Welcome BV7-55
    If my math and figures are correct, in the US the BV7-55 is much better deal than the BV9. Price for a BV9 is $21,900, compared to $11000 for the BV7-55 without Blue-Ray. Add in a center channel speaker for around $4,000 plus a motorized stand which I am guessing around $1500 and the BV7-55 is $16,500, a savings of over $5,000 and a bigger screen with the ability to tilt forwards and back, not just side to side.
    Obviously if one prefers plasma to LCD then the price difference become less important.
  • 12-03-2009 2:56 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Re: Welcome BV7-55
    Razlaw:
    Wow, that can't be right? Over here it's £15,500....which is $26,000 inc the stand and 7.6. Are you sure that price is right? I can't believe B&O would sell the same TV with a $10,000 price difference between the UK and USA? Weird.
    Can any States-based dealer confirm and also explain the huge difference in price?
    The BV9 is about the same price as the BV7-55 over here - only a few hundred pounds more expensive. However, there are a few appearing second hand (in mint condition), making it better value.
  • 12-03-2009 3:09 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: Welcome BV7-55
    moxxey:
    I'm in no way defending the 50% difference, but the screens are not the same.
    XL: 55” 1920 x 1080 (Full HD), 16:9 TFT LCD direct-type LED backlight , local dimming, scanning backlight, glare surface
    L: 47'' ?
    M: 40” 1920 x 1080 (Full HD), 16:9 TFT LCD, glare surface
    S: 32” 1366 x 768 (HD-ready), 16:9 TFT LCD, glare surface
    (from B&O web page)
  • 12-03-2009 3:12 AM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Re: Welcome BV7-55
    moxxey:
    Razlaw:
    In Sweden, BV9 costs over 200k SEK. Don't know exactly but i guess somewhere 210k-230k SEK.
    BV7-55 with BD costs 180k SEK.
    Divide with 9 to get it in €.
  • 12-03-2009 7:43 AM In reply to
    Re: Welcome BV7-55
    moxxey:
    Razlaw:
    For the BV7-55 prices I used figures quoted by a US dealer in a post, about 8 posts before yours in this thread. For the BV9 and BV7-40 I used prices from Abt Electronics webpage, dealer we have purchased many of our items from.
  • 12-03-2009 7:57 AM In reply to
    Re: Welcome BV7-55
    Razlaw is correct with his price estimate. In the States, the BV7-55 is much less expensive than the BV9. The 9  is $21,900 vs $18,000 for a BV7-55 with BluRay,  BeoLab 7-6,  low floor stand, and Beo 5.
    Personally I think the price difference comes from the costs of material and labor to build the cabinet of the BV9 and possible a higher cost of the plasma panel.
    Also, while the BV9 is still a current product, we are no longer required to show it in the stores. The BV9 concept just never really took off in the States and it is on it's way out. Take a look at the pre-owned section on the B&O website and you'll see nearly every store selling their floor models. Maybe a chance to get a good deal.  (not an advertisment as I've already sold mine Wink
    Dixon
  • 12-03-2009 8:01 AM In reply to
    Re: Welcome BV7-55
    Without Blu-Ray would it then be $16,200?  What is the price of the tall stand?  We are interested in the 7-55, already have a 7-4 we would use and do not want the built in Blu-Ray. So price would be $11,000 + stand?
  • 12-03-2009 8:18 AM In reply to
    Re: Welcome BV7-55
    Razlaw:
    The tall stand is $1,500 and would work with your current BeoLab 7-4. The non-bluray BV7-55 is $11,000 so you'd be at $12,500 all in.
  • 12-03-2009 9:15 AM In reply to
    Re: Welcome BV7-55
    Daniel:
    moxxey:
    (from B&O web page)
    Is B & O using a Samsung panel in the BV7-55?
    The reason I ask is that,as far as I am aware,Samsung's 2009 LED TVs embody edge lit LED arrays,and do not feature local dimming.
  • 12-03-2009 10:52 AM In reply to
    Super Angry [8o|] Re: Welcome BV7-55
    I love ABT electronics.
    The prices do not include VAT.  Each state is sovereign when it comes to sales tax.  The federal government does not impose any sales tax.  Although the Feds are able to tax us in many other ways.
    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
  • 12-03-2009 11:15 AM In reply to
    • KMA
    • Joined on 08-13-2007
    • Posts 101
    • Silver Member
    Re: Welcome BV7-55
    Peter :
    If you order the 7-55 in the UK now, you should get it before Christmas. But you had better be quick! I don't think the 10 will arrive till after.
    I hope this isn't the case for BV10 in Scandinavia. I ordered mine when it was introduced a few weeks ago, and was quoted week 49 (this week) or 50 for delivery. It would be somewhat disappointing to get it as late as after Xmas (although there's nothing disappointing at getting a BV10 ;).
    If B&O cannot deliver BV10 before the holidays, they shouldn't promote BV10 on their web site's front page as one of the perfect Xmas gifts...
    I hope my dealer can confirm the schedule for BV10 soon.
    KMA
    Current setup: BeoVision 10-46 (grey speaker cover, AR, motorized stand) with Apple TV 2 (FireCore), Sony BDP-S780, Mac Mini, BeoLab 11 (silver), Beo5, BeoSound 8 (red speaker covers). Accessories: A8 Earphones, wine bottle coasters.
    B&O product history, in chronological order since 1990, after the onset of the treaded BeoVirus (I tend to upgrade/change my setup "infrequently"): BeoSystem 2500 (with blue speaker covers), BeoLink 5000, BeoSystem 7000 (complete; silver/black), BeoLink 7000, RedLine 60.2, BeoVox Penta, BeoVision MX4000 (black, motorized floor stand), BeoCord VX5000 (black), BeoSystem 4500 (complete), BeoCenter 9500, BeoLab 8000, BeoLab 6000, BeoVision Avant (original, 28" AR, VHS, green), BeoCenter 2300, BeoVision 3-32 (grey speaker frame, AR, motorised cabinet), DVD1 (grey), BeoCord V8000 (grey), Beo4, BeoSound Ouverture (w/ floor cabinet stand), BeoVision Avant RF (grey, 32", AR, VHS), BeoSound 9000, BeoCenter AV5 (blue), BeoVision 1 (yellow, motorized floor stand), Beo1, BeoSound Century (yellow), BeoCenter 1 (blue, AR, motorized floor stand), BeoSound 1 (silver, floor stand), BeoVision Avant RF DVD (grey, 32", AR), BeoVision 7-32 MkI (AR, motorized floor stand), BeoLab 3 (black), BeoSound 2, BeoVision 10-40 (grey speaker cover, AR, motorized stand).
  • 12-03-2009 11:21 AM In reply to
    Re: Welcome BV7-55
    My dealer informed me of the same  - BV10 will not be available before beginning of the new year.
    Another good argument to buy the BV7-55 Big Smile
    On Monday I will get my BV7-55 installed, and I can not say how much I am looking forward to that No I only wait for the BS5/BM5, which because of motherboard problems have no delivery time currently Angry
  • 12-03-2009 11:41 AM In reply to
    Re: Welcome BV7-55
    Trolle:
    Congrats ! It looks like a great set! Hope you post pictures and your thoughts on it when it is installed.
    Newbie! So far: BeoVision 7 40´ Mark V Blu-ray, BeoLab 7-4, BeoLab 9, BeoSound 5,  Beo4, Beo5,  BeoCom 2, BeoTime and A8 Earphones
