Latest post 01-08-2010 3:24 PM by ds719. 3 replies.
Page 1 of 1 (4 items)
  • 11-03-2009 3:38 PM
    • John
    • Not Ranked
    • Joined on 04-30-2008
    • Toronto,Canada
    • Posts 4
    Beocom 6000 battery will not fully charge....
    I have a Beocom 6000 MK1 and installed a new battery (Sanyo Ni-MH model number 3HR-AAAU). All features of the phone are functioning properly. The only problem is that the battery doesn't seem to fully charge. Other than simply placing the handset in the base, is there something else that should be done?
    Any help will be greatly appreciated.
  • 11-04-2009 11:01 AM In reply to
    Re: Beocom 6000 battery will not fully charge....
    Try...
    9#9#9*655 OK
    • B&o bottle opener
  • 11-07-2009 2:40 AM In reply to
    • John
    • Not Ranked
    • Toronto,Canada
    • Posts 4
    Thanks. I have tried this, but it didn't help.
  • 01-08-2010 3:24 PM In reply to
    • ds719
    • Not Ranked
    • Joined on 01-08-2010
    • Posts 7
    just a note, when he wrote OK he meant press the middle button in the wheel.  Not sure if you got that.  If that is not working then it will probably need some sort of repair.  That code usually tells the phone that a new battery is in it and it needs to charge longer than the old  battery.
