1st March February 2012
Latest post 10-15-2009 11:10 AM by Beobuddy. 14 replies.
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
I can confirm that you CAN have two STB's connected to a Beovision 3 as shown below:-
In order to enable remote control operation of your set-top box with the Beo4 remote control you must connect the enclosed low-power IR transmitter:
- Connect the IR transmitter to the IR OUTPUT socket on BeoVision 3.
- Fasten the IR transmitter to the IR receiver of the set-top box.
To connect two set-top boxes you need an IR Y-adaptor (part number 6174171) to connect two set-top boxes to your BeoVision 3.
- Connect your primary and secondary set-top boxes to the AV and DECODER sockets on BeoVision 3 (or the DECODER and V.TAPE sockets if you have connected equipment to the AV socket)
- Connect the IR Y-adaptor to the IR OUTPUT socket on BeoVision 3
- Connect the IR transmitter for your primary set-top box to the chrome socket on the IR Y-adaptor, and fasten the other end to the IR receiver on your primary set-top box
- Connect the IR transmitter for your secondary set-top box to the gold socket on the IR Y-adaptor, and fasten the other end to the IR receiver on your secondary set-top box
- Register your primary set-top box in the Connections menu as STB(SAT) and your secondary set-top box as STB(V.AUX)
vikinger
- Joined on 04-16-2008
- Vestri Kirkjubyr, UK
- Posts 2,839
Keith,
Can the same be done with an Avant?
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
Keith Saunders
- Posts 3,810
Graham,
You can do exactly the same on the AVANT
To add a second STB you need a IR Y-adaptor part # 6174171 and one more IR-blaster part #8330352
hebo
- Sweden
- Posts 305
I can just confirm, works perfect.
I control both DVT and AppleTV with my Beo4/Avant,
but you must, as Keith says, have a IR Y-adaptor and one more IR-blaster from B&O
Beobuddy
- Joined on 04-18-2007
- Posts 1,582
Just keep in mind that the best picturequality will be obtained through the AV-VTape socket.
These will support RGB/composite and the Decoder only composite.
At my BV5 I have 2 Dreamboxes 7025+ at the same time. So I can watch/control simultaniously in the livingroom and kitchen.
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
A note to all BeoVision3 owners, this is only possible on the 32" version as it is the same chassis as an Avant.
The 28" BeoVision3 can only use one STBc emitter as it uses a different chassis even though it just looks like a smaller set.
Opman
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Opman:
Ahh! I always wondered but was afraid to ask what the talk on the 32" being the "real thing" was...
What's in a 28" then? BV1 chassis with some quick'n'dirty 16:9 changes, or what...?
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
I think we've missed the point in the original posters question ~ his issue is that the STB-C is sending an IR signal to both the samsung and apple unit when he's only wanting to control one at a time.
To my knowlegde there is nothing you can do about that, my BV3 does the same thing with my two strong set top boxes, unless anybody else can shed light on this?
hebo
- Sweden
- Posts 305
Dave:
Myself missed to read about the orginal Y-adaptor when I was installing my setup. But it works with an orginal B&O adapter.
This is taken from an earlier post from Gerd;
The IR-output socket has 3 pins where only pin 1 is common to both IR-transmitters. By using an ordinary adaptor you will probably short-circuit one of the outputs.
The original adaptor has a chrome- and a gold-coloured socket for a primary (STB-SAT) and a secondary (STB-V.AUX) set top box.
I hope this clear things up
vikinger
- Posts 2,839
Dave:
Yes, that's the way I've read it. The same signal hits both boxes at the same time, so unless the boxes are differenrt/ use different codes, they will both respond. But if the boxes are different then one box will not be affected by the signal intended for the other. Is that right?
Beobuddy
- Posts 1,582
The BV3-32 has the same STB-C controller as the Avant 32 RF DVD and BV5 I own.
This STB-C can control 2 identical boxes independent at the same time.
Normaly the ir-eye has a 3,5mm mono jacket. The splitter has a 3,5 mm stereo jacket with the ground at the bottom, Vaux in the middle an DTV/Sat at the end.
It is rather easy to make one for yourself.
Kokomo
- Joined on 08-21-2007
- Spain
- Posts 618
In simple & basic terms for my benefit please!
Leaving aside the splitter, do I understand that it is possible to access the STB menu for one scart connection, select a particular make of STB, then access the menu for another scart connection and set this one for a different make of box altogether?
Or is it the case as has been mentioned (and what I thought) that the 2 boxes have to be identical, therefore receiving the same IR signal at the same time?
Beobuddy
- Posts 1,582
Example:
If you select : STB (DTV/SAT) for the AV socket and STB (Vaux) for the decodersocket, then the BV will automatically ask you first to choose the right make/model for DTV and secondly asks you to enter the same for the STB Vaux.
It can either be the same or different model.
If have expericienced this for 2 Topfield boxes, 2 Dreamboxes and a topfield and a dreambox together.
This could also work for i.e. a ps3 and a settopbox for cable,satelite or whatever is on the list of the table.
Page 1 of 1 (15 items)
