Latest post 09-28-2009 9:58 AM by beobloomsbury. 2 replies.
Page 1 of 1 (3 items)
  • 09-28-2009 9:15 AM
    beovision avant broken remote control
    hi, my first post so apologies if i am posting in the wrong forum.
    i bought an old beovision avant with integrated vhs about 3 weeks ago. i really like this old-timer, but stupidly dropped the remote control (about 5 feet onto a carpeted floor). there is no cosmetic damage, but it just died. i had a little look inside and could not see anything obvious, so i am not going to investigate further.
    also, when i turn the tv on there seems to be 5 minutes where the picture switches between ok to loud fuzzy with no reception in short bursts. there is a bit of ghosting to the right. can this be sorted with the tracking setting?
    i live near tottenham court road in central london. i only spent £150 on the tv. if i take the remote to tottenham court road they are going to assume i have money to burn because its b&o, which i don't how can i get this fixed. is there anyone local i can get to come and take a look at it. do mobile tv repair men exist anymore?
    thanks
    dan
  • 09-28-2009 9:37 AM In reply to
    Re: beovision avant broken remote control
    Whatever you spend on this TV is going to be wasted and the repair charge could easily be many times your original investment.
    £150 should get you a fully working 32in Avant. With the headlong rush to buy cheap and cheerful flat screens people can't give them away nowadays.
    Regards Graham
  • 09-28-2009 9:58 AM In reply to
    thats pretty much what i thought. i would like to get the remote sorted out at least though. nothing else is really a problem.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
