1st March February 2012
Latest post 06-20-2009 4:28 PM by soundproof. 7 replies.
06-20-2009 9:07 AM
Bentleyman
- Joined on 12-29-2008
- Rochdale
- Posts 367
Hello All,
Does anyone know the answer to this slightly odd-ball question...
What happens if u connect a 2nd CD unit (a beogram cd 7000) to the Beomaster using the Tape 2 socket (or the phono socket)..?
I'm basically fed up with only having 1 cd capacity - but yet have the option of adding a 2nd tape deck to my system - cassettes tapes being virtually extict nowadays....
would plugging in a cd unit to a socket intended for a tape 2 deck destroy the whole system/not work/blow up the beomaster etc...?
cheers,
Michael
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Beosystem 7000 (or 6500)
No problems except that remote control won't work for the second CD player - the CD expects to be referred to as a Beogram, not a Beocord. All sources to the Beomaster 7000 use line level.
Bentleyman
- Rochdale
- Posts 367
Cheers Peter,
When u say the remote wont work - do you mean that you need to press the Tape 2 button (as if it were a 2nd cassette deck) - or u mean it wont work at all..? If not at all - how do u go about actually playing the '2nd' cd unit.. ?
Cheers, Michael
Michael
BS 7000, BS 5500
soundproof
- Joined on 04-16-2007
- Posts 2,340
You will be able to use the remote to switch between sources - CD, TAPE, RADIO, etc. - but you won't be able to control the second CD-player with the remote, and will have to manually operate the panel on the player.
Peter
- Posts 9,572
If you are not using a record player, then attach the Beogram CD to that input. It should work though you will only get basic functions as it will behave like a Beogram, I think! I'll go and try!
Peter
- Posts 9,572
It works! And I was wrong - all the remote functions seem to work as well.
Bentleyman
- Rochdale
- Posts 367
Fantastic! cheers Peter,
Thank you
Michael
BS 7000, BS 5500
Page 1 of 1 (8 items)
