Latest post 06-20-2009 4:28 PM by soundproof. 7 replies.
Page 1 of 1 (8 items)
  • 06-20-2009 9:07 AM
    Beosystem 7000 (or 6500)
    Hello All,
    Does anyone know the answer to this slightly odd-ball question...
    What happens if u connect a 2nd CD unit (a beogram cd 7000) to the Beomaster using the Tape 2 socket (or the phono socket)..?
    I'm basically fed up with only having 1 cd capacity - but yet have the option of adding a 2nd tape deck to my system - cassettes tapes being virtually extict nowadays....
    would plugging in a cd unit to a socket intended for a tape 2 deck destroy the whole system/not work/blow up the beomaster etc...?
    cheers,
    Michael
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
  • 06-20-2009 9:18 AM In reply to
    Re: Beosystem 7000 (or 6500)
    No problems except that remote control won't work for the second CD player - the CD expects to be referred to as a Beogram, not a Beocord. All sources to the Beomaster 7000 use line level.
  • 06-20-2009 9:24 AM In reply to
    Cheers Peter,
    When u say the remote wont work - do you mean that you need to press the Tape 2 button (as if it were a 2nd cassette deck) - or u mean it wont work at all..? If not at all - how do u go about actually playing the '2nd' cd unit.. ?
    Cheers, Michael
    Michael
    BS 7000, BS 5500
  • 06-20-2009 11:45 AM In reply to
    You will be able to use the remote to switch between sources - CD, TAPE, RADIO, etc. - but you won't be able to control the second CD-player with the remote, and will have to manually operate the panel on the player.
  • 06-20-2009 11:57 AM In reply to
    If you are not using a record player, then attach the Beogram CD to that input. It should work though you will only get basic functions as it will behave like a Beogram, I think! I'll go and try!
  • 06-20-2009 12:06 PM In reply to
    It works! And I was wrong - all the remote functions seem to work as well.
  • 06-20-2009 12:41 PM In reply to
    Fantastic! cheers Peter,
    Thank you
    Michael
    BS 7000, BS 5500
  • 06-20-2009 4:28 PM In reply to
    With B&O we learn something new every day! Big Smile
