1st March February 2012
Latest post 07-24-2007 3:43 PM by Jandyt. 26 replies.
benkap
- Joined on 04-16-2007
- Oslo, Norway
- Posts 162
Re: How to preset motorised stand?
Thanks for the reply, Graham. Could you specify the sequence of buttons I need to press?
Maybe it's just me being thick but I definitely don't have the same options as the manual poses.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Do you use BL1000 or Beo4?
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
If you have beolink 1000, press picture when the TV is on and you should have stand displayed in the top left hand side of the screen. When stand is displayed then the arrow keys will change the orientation of the stand and press store twice when the tcv is facing in the correct direction.
benkap
- Oslo, Norway
- Posts 162
Sorry, I use a Beo4 - newest version.
I have tried exactly what you descibe, Graham, but it is like the TV doesn't remember the new setting.
Is there any reason this would only be possible with a Beolink 1000?
jooka
- Joined on 04-15-2007
- Posts 185
go to menu of your tv. there should be stand if it's correctly hooked up.
beo4life
- Ely
- Posts 64
jooka: go to menu of your tv. there should be stand if it's correctly hooked up.
Not always. It depnds on the age of the tv. On the older mx4000's the stand setting was not in the menu. Only in the later beo4 versions were the option to set the stand in the menu.
Regards Brett
benkap
- Oslo, Norway
- Posts 162
That's what I thought, too, but when I press MENU I only get 'Program list' and 'Setup'. Other than this preset thing the motor is functioning as it should.
beo4life
- Ely
- Posts 64
I'm i write in thinking you have a newish beo4, but your mx is an old version?
Regards Brett
benkap
- Oslo, Norway
- Posts 162
Yes, that's correct. I have the opportunity to borrow a Beolink 1000 from a friend if that would do me any good.
PL212
- Joined on 02-14-2007
- Moderator - Seattle
- Posts 318
Do you have P.STORE added to your Beo4 so that it shows up when you press LIST?
beo4life
- Ely
- Posts 64
i think thats the easiest solution. Its always handy to have a bl1000 around. Not that you cant do it with a beo4, its just no-one knows how to.
Regards Brett
benkap
- Oslo, Norway
- Posts 162
I've managed to save my favorite viewing position now doing as Graham stated. This is the exact same thing I did earlier when it didn't work. Is there also a way to save the position the stand will turn to when turning off the TV? Thanks for all your help, guys
benkap
- Oslo, Norway
- Posts 162
That's what I thought. On standby the stand goes back to a position slightly off center. I don't think I will be doing anything about it, though, as it is too little to correct it by mounting it differently. Thanks again, Ben
Christian
- Copenhagen, Denmark
- Posts 626
benkap: That's what I thought. On standby the stand goes back to a position slightly off center. I don't think I will be doing anything about it, though, as it is too little to correct it by mounting it differently. Thanks again, Ben
I had the same problem with centering in stand-by, but I solved the problem by mounting the tv a little off center, and it worked. Mine is an LX, and I am not sure how the MX is attached, but it might work for you.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
PL212
- Posts 318
Actually I think the service manual (for the stand) details how to correct centering problems at a hardware level.
Iconic-AV
- Birmingham UK
- Posts 902
can anyone direct me to the service manual for the mx wall motorstand, ive looked for ages through the manuals and just cant see it for looking, i do miss the old forums ease of product search ive just fitted my mx4000 on the wall in the bathroom (dont worry its not touching water, its way above the bath ) the off position on the stand goes all the way to the left , yet this thread suggests it should go to the center which would look much better that at present facing the adjoining wall, thanks jay
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Surely ' picture, store, 0, store' will set it in the standby position of your choice. Andy T.
Iconic-AV
- Birmingham UK
- Posts 902
jandyt: Surely ' picture, store, 0, store' will set it in the standby position of your choice. Andy T.
No , tryed it, the older mxs only have the choice of desired "on" position, its not 0,1 or 2 , its simply stand jay
joeyboygolf
- Posts 3,252
You must have the TV mounting plate in the wrong position! Put the TV in standby, disconnect and dismount the TV. Now remove the plate and re fix in the standby position which suits you. Remount the TV and all should be well. I am somewhat concerned by the fact that you have mounted a TV in what could be a steamy atmosphere. I would have thought that this could be dangerous from an electric shock point of view. Perhaps others more qualified would care to comment before we lose one of our gold members.
Iconic-AV
- Birmingham UK
- Posts 902
dont worry Graham ive always wanted to go with a "Bang" id tryed your suggestion , its not that changing the position of the plate would do the trick as its the motor that goes back to the far left on standby, maybe i have a faulty motor if i re-position the plate to counteract it, i then cant go left at all as it is already as far left as it can go , and due to the position of the mounting screws for the plate there are limited options to re-position that, the nearest better position ive found only lines up 3 of the 4 screws and where ive put it i really dont want yet another screw loose hard to explain really im quite a resourceful person and can make most things work with a little tinkering, but in this case i need it to go left and right and standby somewhere inbetween, and after reading in this thread that it should go back to center position just where i need it to be i was hoping i could do that hope this makes sense thanks jay
joeyboygolf
- Posts 3,252
Makes perfect sense Jay, seems like the motor has a problem 'cos it should definitely go to the centre at standby. Can you move it both ways manually when the system is on standby? Suggest you contact Nobby who I'm sure will have a replacement motor at a reasonable price.
