1st March February 2012
Latest post 05-13-2009 1:16 PM by BMGHB. 58 replies.
martin01
- Joined on 04-17-2007
- Sweden
- Posts 207
The decoding of the HD-codecs, such as Dolby True HD and DTS-HD will be done in the player (not in the Beosystem 3). That means that the player will send the decoded sound as digital Multichannel PCM-stream to Beosystem 3.
/Martin
Beolab 5 with sw 3.0, BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
mbee
- Joined on 04-18-2007
- Paris, France
- Posts 1,133
@Martin01 : That's not what B&O said :
This is an integrated player, so it's only a reader like those you can find in a PC. So the player itself doesn't decode anything!
If you buy an external player, you can do that (decoding the DTS HDMA in your player and sending the decoded signal in PCM 5.1/7.1 to your B&O system.
If you buy a BV7 blu ray, the DTS HDMA will be decoded only as DTS, because DTS HDMA is backward compatible. You will get a very good DTS sound, but not the real high definition soundtrack.
So if you want the best sound possible, choose a BV7 40 Monitor and add an external player (PS3 for instance, you get the game bonus!)
martin01
- Sweden
- Posts 207
What about Dolby True HD, will that be converted to Dolby Digital just as the DTS-MA will be DTS?
/Martin
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
mbee:
No, the PS3 is no better than the internal player. Also, I read that the PS3 is now fairly average compared to the most recent and modern Blu-ray players. ie. the picture quality is not regarded as the best on the market. Perhaps the internal player may be better than the PS3 for this reason.
moxxey
- South West, UK
- Posts 2,360
raveny:
what about the version without Blu-Ray? Does it also come with 100 Hz?
Yes, absolutely. It will share the same LCD panel.
mbee
- Paris, France
- Posts 1,133
The PS3 can convert the DTS HD to PCM 7.1 via HDMI, allowing the user to play the 7.1 soundtrack on a Beovision...
Concerning quality, I have not seen something better than a PS3 on a 2,5m large screen when choosing a player (in fact you almost cannot detect any difference in image quality between good players), so I must admit that I would be a bit surprised to see any visible difference between the BV7 and a PS3 on its 40" screen!
BMGHB
- Joined on 05-12-2007
- Posts 219
Taken from the BeoVision 7 - 40 MKIV:
CTV
Cabinet finish
Black, Blue, Dark Grey, Red, Silver,
White, Golden
Mains voltage range
100 - 127 V +10 / -15% 50-60
Hz
200 - 240 V +10 / -15% 50-60
Hz
Power consumption
Typical: 140W / Standby
1.0W
Diagonal picture size
40" 16:9 TFT LCD
Panel coating
Glare
Aspect ratio
16:9
Contrast ratio
typ.
3000:1
Resolution
1920 x 1080 (Full
HD)
Refresh
rate
100/120
Hz
Luminance of white (centre of
screen)
typ. 500 cd/m2
Response time
typ. 6 msec.
Viewing angle
typ. +/-89 degrees both vertical and
horizontal
Contrast screen
Anti-reflex coated on both
sides
Formats
Format 1: 16:9 Panorama - 15:9 Panorama
- 4:3 Format 2: Letterbox + Soft Scroll. Format 3: 16:9 Automatic
format optimisation via "Black Bar Detection" 16:9 detection on all Scart
connectors. Support of WSS (Wide Screen Signalling pulses) from
broadcaster.
VisionClear
Adaptive black, Adaptive back light,
Blue Stretch, Comb filter
Digital Adaptive Dynamic Luminance
Peaking
Digital Adaptive Noise Reduction
Digital Color Transient Improvement
Film Mode, Vertical Peaking, Automatic
Picture Control
Source Quality Measurements, Dynamic
Contrast
Teletext
Level 2.5 teletext, approx. 2048 pages
9 memory pages per
programme
Closed Captioning
US Market only
Tuning
USA/Korea: Cable TV 1-125, Off Air TV
2-69 Japan: Channel 1-62 and Channel C13-C38 EU/Other: 45 - 860 MHz: VHF,
S-band, Hyper-band, UHF 99 programmes, auto tune, programme move and automatic
naming
Stereo decoders
EU/other: A2+ Nicam Stereo
US: BTSC Stereo, SAP
Japan: EIA-J Stereo, AAC
Korea: A2 Stereo
Taiwan: BTSC Stereo,
SAP
Menu languages
English, Danish, Dutch, Spanish,
Swedish, German, French, Italian
PIN-code protection
Yes
Loudspeakers:
BeoLab 7-2
For technical details see Tech. Spec.
for BeoLab 7-2
BeoLab 7-4
for BeoLab 7-4
System modulator:
Function
System modulator output to link room
(BeoLink Video Distribution)
Frequency range
471.71- 855.25 MHz (in 1MHz step) Dual
side band
Audio
System G: 5.5MHz (System can be set in
Service Menu) System I: 6MHz (System can be set in Service Menu) System M:
4.5MHz (System can be set in Service Menu)
Connection
1x 75 ohm aerial
male
Dolby®
Digital Decoder:
Input Formats
PCM, multichannel PCM
Dolby Digital, Dolby Digital EX,
DTS, DTS ES.
Decoding capabilities
Dolby Digital 5.1/6.1 EX, Dolby 7.1 EX,
Dolby Pro-Logic
ll/llx, DTS 5.1. DTS ES 6.1, DTS
Neo:6,
Sound modes (Speaker 1 -
5)
Mode 1: Stereo centre speakers
(Subwoofer muted)
Mode 2: Stereo in L/R speakers,
Subwoofer is active
Mode 3: Dolby® 3 stereo
Mode 4: Dual stereo, stereo in L/R
front & rear speakers, Subwoofer is active
Mode 5: Dolby® digital, Dolby®
Pro-logic, DTS, Dolby 7.1
Connections :
- Digital audio input
- External BeoLab
speakers
5 x SPDIF(Coax),
4 x HDMI (2x HDMI if DVB-HD and Blu-ray player is
mounted)
7 x
PowerLink
HDMI Inputs
Formats
480i, 576i, 1080i, 480p, 576p, 600p, 768p, 720p,
1080p
Frequency
50Hz, 60Hz and 24Hz 1080p24
Further info
IR CONTROL OUTPUTS (PUC):
Supported boxes
See list in IR-Table Generator via
ServiceTool MK II.
Connection
7 x Mini jack
Optional features/accessories
Product name:
Blu-ray
player
Type no.
4651
Playback of the
following
BD-ROM, BD-R/RE, DVD-ROM, Audio CD,
CD-R/RW,(CD-DA only), DVD-R/RW
Audio decoding format
Dolby Digital 5.1/EX 6.1/EX
7.1
DTS 5.1/ES 6.1
MPEG audio L1, L2
LPCM, 7.1ch multi channel
PCM
DVD region
1, 2, 3, 4, 5, 6
Blu-ray region
A, B, C
BD-LIVE
Yes, BD-Live Profile
2.0
BD-JAVA
Yes
Internal memory
2 GB
Product name:
DVB T/S
Module
Type no.
EU 4383 UK
4384
Terrestrial
Plug
IEC 169-2 coax connector 75
ohm
Frequency range
174 MHz to 862 MHz (Band 3, 4,
5)
IF Bandwidth
7 & 8 MHz
Control for active
antenna
5 V / 50 mA Power supply can be
activated via setup menu
COFDM (Orthogonal frequency division
modulation) Spectrum
2K & 8K, hierarchical and
non-hierarchical
Modulation
QPSK, 16QAM,
64QAM
Code rate
1/2, 2/3, 3/4, 5/6,
7/8
Guard interval
1/32, 1/16, 1/8,
1/4
Symbol rate
5 - 45 Msymb/sec
Compliance
Nordig Unified and
IEC62216-1
Satellite
Plug
ICE 169-24 F-female connector 75
ohm
Frequency range
950 MHz to 2150
MHz
IF Bandwidth
45 MHz
ODU control
DiSEqC level 1.1 (digital satellite
equipment control)
DC For switching between H/V
polarizations 13.5 Volt +/- 5% max 450 mA 18.5 Volt +/- 5% max 450 mA
Tone Control for low or high band selection 22KHz / 0.65Vpp +/- 0.25V
duty cycle 50% +/- 10%
Modulation
QPSK
Symbol rate
5 - 45 Msymb/sec
Decoder
Video
MPEG2, MP@ML
Audio
MPEG1, 2-channel audio decoder, layer
1& 2 MPEG2, 2-channel audio decoder, layer 2 AC3 to S/Pdif
loop-through
Product name:
DVB-HD Module
Terrestrial and Cable
no.
4480
Terrestrial
Plug
IEC 169-2 coax connector 75 ohm
USB 2.0 only for software
update
Frequency
range
110 MHz to 862 MHz (Band 3, 4,
5)
Auto tuning 174-230 MHz and 470-858
MHz
IF
Bandwidth
6, 7 & 8 MHz
Raster
Special requirements for France, Italy, Taiwan and
Australia
Control for
active antenna
5 V / 50 mA power supply can be activated via setup
menu
COFDM
(Orthogonal frequency division modulation) Spectrum
non-hierarchical
Modulation
QPSK, 16QAM, 64QAM
Code
rate
1/2, 2/3, 3/4, 5/6,
7/8
Guard
interval
1/32, 1/16, 1/8, 1/4
Symbol
rate
2 - 45 Msymb/sec
Cable
Frequency range
110 MHz to 862 MHz (Band 3, 4, 5)
IF Bandwidth
6, 7 and 8 MHz
selectable
QAM
4, 16, 64, 128, 256 QAM
Symbol rate
4.0 - 7.0 Msymb/sec
Decoder
Video
MPEG2: MP@ML, MP@HL
H264: MPEG4 AVC, main and high profile
level 4
Audio
MPEG1, 2-channel audio decoder, layer 1 & 2 MPEG2, 2-channel audio decoder, layer 2
AAC, AAC+ AC3
decoding and down mix
Conditional
access
Implemented as
Common Interface according to EN50221
Number of slots
1x PCMCIA (Common Interface
only)
Embedded CA
Conax (without Cip and Card
paring)
SmartCard interface
Connector for 1 SmartCard
slot
CI support for
All CA Systems available as common
interface
CA power supply
5 Volt 500 mA max.
Video format
Format
PAL/50 Hz 625 lines 4:3 & 16:9, letterbox down
sampling at CVBS
Video
output
Analogue Video output
CVBS (link distribution and background recording
mode)
Digital Video output
1080i/720p
Analogue copy protection
MacroVision, if demanded
WSS (Wide Screen
Signalling)
Data to report the aspect
ratio
Teletext
Teletext data inserted in CVBS VBI
lines
Subtitles
DVB and Teletext subtitles
supported
Analogue resolution
720 pixels x 576 lines
Digital resolution
Reception: 480i, 576i, 576p,
720p,1080i
Output: 720p
Product name:
ATSC (USA,
Korea)
Terrestrial
Type no.
Standard
Tuning range
54 MHz to 806
MHz
IF Bandwidth
6 MHz
Modulation
8VSB
Symbol rate
19,4 Mbit/sec
Compliance
ATSC A/53 rev.c,
A/74
Cable
Tuning range
54 MHz to 864
MHz
IF Bandwidth
6 MHz
Modulation
64 QAM & 256
QAM
Symbol rate
5057 Msps (Mode 1) or 5361Msps (Mode
2)
Decoder
Video
MPEG2, MP@ML (480p), MP@HL (720p,
1080i) Video formats all 18 according to ATSC A54a
Audio
(ATSC A52a) AC3 stereo
downmix Multichannel mode AC3 to S/Pdif loop-through
Product name:
RF link
amplifier
Type no.
4052
Dimensions W x H x D
14.6 x 8.6 x 7.2
cm
Weight
0.72 kg
Power consumption
(typical)
4W
Working Temperature
Range
0° to 40° C
Frequency range
40 - 860 MHz
Gain (from aerial IN to
TAP1-4)
min. 7 dB +/-1.5
dB
Gain (from Modulator IN to
TAP1-4)
min. 4 dB +/-1.5
dB
Aerial Attenuator *1)
0/5/10 db
Modulator Attenuator
*2)
0/3/6 db
Recommended minimum RF input (Aerial
IN)
60 dB/uV
Maximum RF input (Aerial
IN)
86 dB/uV
Maximum output
(IMA-60dB).
100 dB/uV (40 - 860
MHz)
*1) Attenuate if aerial IN is too high
and interference is seen on the link frequency in the link room. *2)
Attenuate if the aerial/cable network signal is low and the modulator signal
therefore causes interference in the TV picture.
Product name:
RF link amplifier with return
path
Type no.
4053
14.6 x 8.6 x 7.2
cm
Weight
0.72 kg
Power consumption
(typical)
4 watts
Working Temperature
Range
0° to 40° C
Frequency range
87 - 860 MHz Note! Frequencies in Band I will not be looped
through (used for return path)
TAP1-4)
min. 7 dB +/-1.5
dB
TAP1-4)
min. 4 dB +/-1.5
dB
0/5/10 db
*2)
0/3/6 db
IN)
60 dB/uV
IN)
86 dB/uV
Maximum output
(IMA-60dB).
100 dB/uV (40 - 860
MHz)
Return path
Return path on TAP 1-4 (return
communication to e.g. Cable Network company)
Frequency range for return
path
5 - 65 MHz
Product name:
STB Cover,
silver
Type no./dimensions
2189 (large/41x35x10 cm), 2190
(small/36x29x8 cm)
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
