Latest post 05-13-2009 1:16 PM by BMGHB. 58 replies.
Page 3 of 3 (59 items) < Previous 1 2 3
  • 05-13-2009 7:34 AM In reply to
    Re: BV7-40 MKIV specs?
    The decoding of the HD-codecs, such as Dolby True HD and DTS-HD will be done in the player (not in the Beosystem 3). That means that the player will send the decoded sound as digital Multichannel PCM-stream to Beosystem 3.
    /Martin
    Beolab 5 with sw 3.0,  BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
  • 05-13-2009 8:03 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    @Martin01 : That's not what B&O said :
    This is an integrated player, so it's only a reader like those you can find in a PC. So the player itself doesn't decode anything!
    If you buy an external player, you can do that (decoding the DTS HDMA in your player and sending the decoded signal in PCM 5.1/7.1 to your B&O system.
    If you buy a BV7 blu ray, the DTS HDMA will be decoded only as DTS, because DTS HDMA is backward compatible. You will get a very good DTS sound, but not the real high definition soundtrack.
    So if you want the best sound possible, choose a BV7 40 Monitor and add an external player (PS3 for instance, you get the game bonus!)
  • 05-13-2009 8:09 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    And more important : DTS HD/DTS HDMA 7.1 will be converted to 5.1. So if you have a 7.1 setup, avoid the integrated player...
  • 05-13-2009 8:35 AM In reply to
    What about Dolby True HD, will that be converted to Dolby Digital just as the DTS-MA will be DTS?
    /Martin
  • 05-13-2009 10:14 AM In reply to
    what about the version without Blu-Ray? Does it also come with 100 Hz?
  • 05-13-2009 11:33 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    mbee:
    No, the PS3 is no better than the internal player. Also, I read that the PS3 is now fairly average compared to the most recent and modern Blu-ray players. ie. the picture quality is not regarded as the best on the market. Perhaps the internal player may be better than the PS3 for this reason.
  • 05-13-2009 11:34 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    raveny:
    Yes, absolutely. It will share the same LCD panel.
  • 05-13-2009 12:02 PM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    The PS3 can convert the DTS HD to PCM 7.1 via HDMI, allowing the user to play the 7.1 soundtrack on a Beovision...
    Concerning quality, I have not seen something better than a PS3 on a 2,5m large screen when choosing a player (in fact you almost cannot detect any difference in image quality between good players), so I must admit that I would be a bit surprised to see any visible difference between the BV7 and a PS3 on its 40" screen!
  • 05-13-2009 1:16 PM In reply to
    Taken from the BeoVision 7 - 40 MKIV:
    CTV
    Cabinet finish
    Black, Blue, Dark Grey, Red, Silver, White, Golden
    Mains voltage range
    100 - 127 V +10 / -15%  50-60 Hz
    200 - 240 V +10 / -15%  50-60 Hz
    Power consumption
    Typical: 140W / Standby 1.0W
    Diagonal picture size
    40" 16:9 TFT LCD
    Panel coating
    Glare
    Aspect ratio
    16:9
    Contrast ratio
    typ. 3000:1
    Resolution
    1920 x 1080 (Full HD)
    Refresh rate
    100/120 Hz
    Luminance of white (centre of screen)
    typ. 500 cd/m2
    Response time
    typ. 6 msec.
    Viewing angle
    typ. +/-89 degrees both vertical and horizontal
    Contrast screen
    Anti-reflex coated on both sides
    Formats
    Format 1: 16:9 Panorama - 15:9 Panorama - 4:3
    Format 2: Letterbox + Soft Scroll.
    Format 3: 16:9
    Automatic format optimisation via "Black Bar Detection"
    16:9 detection on all Scart connectors.
    Support of WSS (Wide Screen Signalling pulses) from broadcaster.
    VisionClear
    Adaptive black, Adaptive back light, Blue Stretch, Comb filter
    Digital Adaptive Dynamic Luminance Peaking
    Digital Adaptive Noise Reduction
    Digital Color Transient Improvement
    Film Mode, Vertical Peaking, Automatic Picture Control
    Source Quality Measurements, Dynamic Contrast
    Teletext
    Level 2.5 teletext, approx. 2048 pages
    9 memory pages per programme
    Closed Captioning
    US Market only
    Tuning
    USA/Korea: Cable TV 1-125, Off Air TV 2-69
    Japan: Channel 1-62 and Channel C13-C38
    EU/Other: 45 - 860 MHz: VHF, S-band, Hyper-band, UHF 99 programmes, auto tune, programme move and automatic naming
    Stereo decoders
    EU/other: A2+ Nicam Stereo
    US: BTSC Stereo, SAP
    Japan: EIA-J Stereo, AAC
    Korea: A2 Stereo
    Taiwan: BTSC Stereo, SAP
    Menu languages
    English, Danish, Dutch, Spanish, Swedish, German, French, Italian
    PIN-code protection
    Yes
    Loudspeakers:
    BeoLab 7-2
    For technical details see Tech. Spec. for BeoLab 7-2
    BeoLab 7-4
    For technical details see Tech. Spec. for BeoLab 7-4
    System modulator:
    Function
    System modulator output to link room (BeoLink Video Distribution)
    Frequency range
    471.71- 855.25 MHz (in 1MHz step) Dual side band
    Audio
    System G: 5.5MHz (System can be set in Service Menu)
    System I: 6MHz (System can be set in Service Menu)
    System M: 4.5MHz (System can be set in Service Menu)
    Connection
    1x 75 ohm aerial male
    Dolby® Digital Decoder:
    Input Formats
    PCM, multichannel PCM
    Dolby Digital, Dolby Digital EX,
    DTS, DTS ES.
    Decoding capabilities
    Dolby Digital 5.1/6.1 EX, Dolby 7.1 EX, Dolby Pro-Logic
    ll/llx, DTS 5.1. DTS ES 6.1, DTS Neo:6,
    Sound modes (Speaker 1 - 5)
    Mode 1: Stereo centre speakers (Subwoofer muted)
    Mode 2: Stereo in L/R speakers, Subwoofer is active
    Mode 3: Dolby® 3 stereo
    Mode 4: Dual stereo, stereo in L/R front & rear speakers, Subwoofer is active
    Mode 5: Dolby® digital, Dolby® Pro-logic, DTS, Dolby 7.1
    Connections :
    - Digital audio input
    - External BeoLab speakers
    5 x SPDIF(Coax), 4 x HDMI
    (2x HDMI if DVB-HD and Blu-ray player is mounted)
    7 x PowerLink
    HDMI Inputs
    Formats
    480i, 576i, 1080i, 480p, 576p, 600p, 768p, 720p, 1080p
    Frequency
    50Hz, 60Hz and 24Hz 1080p24
    Further info
    See PDF: Video Inputs
    IR CONTROL OUTPUTS (PUC):
    Supported boxes
    See list in IR-Table Generator via ServiceTool MK II.
    Connection
    7 x Mini jack
    Optional features/accessories
    Product name:
    Blu-ray player
    Type no.
    4651
    Playback of the following
    BD-ROM, BD-R/RE, DVD-ROM, Audio CD, CD-R/RW,(CD-DA only), DVD-R/RW
    Audio decoding format
    Dolby Digital 5.1/EX 6.1/EX 7.1
    DTS 5.1/ES 6.1
    MPEG audio L1, L2
    LPCM, 7.1ch multi channel PCM
    DVD region
    1, 2, 3, 4, 5, 6
    Blu-ray region
    A, B, C
    BD-LIVE
    Yes, BD-Live Profile 2.0
    BD-JAVA
    Yes
    Internal memory
    2 GB
    Product name:
    DVB T/S Module
    Type no.
    EU 4383
    UK 4384
    Terrestrial
    Plug
    IEC 169-2 coax connector 75 ohm
    Frequency range
    174 MHz to 862 MHz (Band 3, 4, 5)
    IF Bandwidth
    7 & 8 MHz
    Control for active antenna
    5 V / 50 mA Power supply can be activated via setup menu
    COFDM (Orthogonal frequency division modulation) Spectrum
    2K & 8K, hierarchical and non-hierarchical
    Modulation
    QPSK, 16QAM, 64QAM
    Code rate
    1/2, 2/3, 3/4, 5/6, 7/8
    Guard interval
    1/32, 1/16, 1/8, 1/4
    Symbol rate
    5 - 45 Msymb/sec
    Compliance
    Nordig Unified and IEC62216-1
    Satellite
    Plug
    ICE 169-24 F-female connector 75 ohm
    Frequency range
    950 MHz to 2150 MHz
    IF Bandwidth
    45 MHz
    ODU control
    DiSEqC level 1.1 (digital satellite equipment control)
    DC For switching between H/V polarizations
    13.5 Volt +/- 5% max 450 mA
    18.5 Volt +/- 5% max 450 mA
    Tone Control for low or high band selection
    22KHz / 0.65Vpp +/- 0.25V duty cycle 50% +/- 10%
    Modulation
    QPSK
    Symbol rate
    5 - 45 Msymb/sec
    Decoder
    Video
    MPEG2, MP@ML
    Audio
    MPEG1, 2-channel audio decoder, layer 1& 2
    MPEG2, 2-channel audio decoder, layer 2
    AC3 to S/Pdif loop-through
    Product name:
    DVB-HD Module
    Terrestrial and Cable
    Type no.
    4480
    Terrestrial
    Plug
    USB 2.0 only for software update
    Frequency range
    110 MHz to 862 MHz (Band 3, 4, 5)
    Auto tuning 174-230 MHz and 470-858 MHz
    IF Bandwidth
    6, 7 & 8 MHz
    Raster
    Special requirements for France, Italy, Taiwan and Australia
    5 V / 50 mA power supply can be activated via setup menu
    Modulation
    QPSK, 16QAM, 64QAM
    Code rate
    Guard interval
    Symbol rate
    2 - 45 Msymb/sec
    Cable
    Frequency range
    IF Bandwidth
    6, 7 and 8 MHz selectable
    QAM
    4, 16, 64, 128, 256 QAM
    Symbol rate
    4.0 - 7.0 Msymb/sec
    Decoder
    Video
    MPEG2: MP@ML, MP@HL
    H264: MPEG4 AVC, main and high profile level 4
    Audio
    MPEG1, 2-channel audio decoder, layer 1 & 2
    AAC, AAC+ AC3 decoding and down mix
    Conditional access
    Implemented as
    Common Interface according to EN50221
    Number of slots
    1x PCMCIA (Common Interface only)
    Embedded CA
    Conax (without Cip and Card paring)
    SmartCard interface
    Connector for 1 SmartCard slot
    CI support for
    All CA Systems available as common interface
    CA power supply
    5 Volt 500 mA max.
    Video format
    Format
    PAL/50 Hz 625 lines 4:3 & 16:9, letterbox down sampling at CVBS
    Video output
    Analogue Video output
    CVBS (link distribution and background recording mode)
    Digital Video output
    1080i/720p
    Analogue copy protection
    MacroVision, if demanded
    WSS (Wide Screen Signalling)
    Data to report the aspect ratio
    Teletext
    Teletext data inserted in CVBS VBI lines
    Subtitles
    DVB and Teletext subtitles supported
    Analogue resolution
    720 pixels x 576 lines
    Digital resolution
    Reception: 480i, 576i, 576p, 720p,1080i
    Output: 720p
    Product name:
    ATSC (USA, Korea)
    Terrestrial
    Type no.
    Standard
    Tuning range
    54 MHz to 806 MHz
    IF Bandwidth
    6 MHz
    Modulation
    8VSB
    Symbol rate
    19,4 Mbit/sec
    Compliance
    ATSC A/53 rev.c, A/74
    Cable
    Tuning range
    54 MHz to 864 MHz
    IF Bandwidth
    6 MHz
    Modulation
    64 QAM & 256 QAM
    Symbol rate
    5057 Msps (Mode 1) or 5361Msps (Mode 2)
    Decoder
    Video
    MPEG2, MP@ML (480p), MP@HL (720p, 1080i)
    Video formats all 18 according to ATSC A54a
    Audio
    (ATSC A52a) AC3 stereo downmix
    Multichannel mode AC3 to S/Pdif loop-through
    Product name:
    RF link amplifier
    Type no.
    4052
    Dimensions W x H x D
    14.6 x 8.6 x 7.2 cm
    Weight
    0.72 kg
    Power consumption (typical)
    4W
    Working Temperature Range
    0° to 40° C
    Frequency range
    40 - 860 MHz
    Gain (from aerial IN to TAP1-4)
    min. 7 dB +/-1.5 dB
    Gain (from Modulator IN to TAP1-4)
    min. 4 dB +/-1.5 dB
    Aerial Attenuator *1)
    0/5/10 db
    Modulator Attenuator *2)
    0/3/6 db
    Recommended minimum RF input (Aerial IN)
    60 dB/uV
    Maximum RF input (Aerial IN)
    86 dB/uV
    Maximum output (IMA-60dB).
    100 dB/uV (40 - 860 MHz)
    *1) Attenuate if aerial IN is too high and interference is seen on the link frequency in the link room.
    *2) Attenuate if the aerial/cable network signal is low and the modulator signal therefore causes interference in the TV picture.
    Product name:
    RF link amplifier with return path
    Type no.
    4053
    14.6 x 8.6 x 7.2 cm
    Weight
    0.72 kg
    4 watts
    0° to 40° C
    Frequency range
    87 - 860 MHz
    Note! Frequencies in Band I will not be looped through (used for return path)
    min. 7 dB +/-1.5 dB
    min. 4 dB +/-1.5 dB
    0/5/10 db
    0/3/6 db
    60 dB/uV
    86 dB/uV
    Return path
    Return path on TAP 1-4 (return communication to e.g. Cable Network company)
    Frequency range for return path
    5 - 65 MHz
    Product name:
    STB Cover, silver
    Type no./dimensions
    2189 (large/41x35x10 cm), 2190 (small/36x29x8 cm)
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
