1st March February 2012
Latest post 06-26-2009 5:10 AM by johnnielse. 69 replies.
rayfenwick
- Joined on 04-28-2007
- Hull UK (again)
- Posts 693
Re: 103-inch BeoVision 4 introduced - with cool video
Karel Uyttendaele:
Can't make up my mind yet.. The pictures look good... But I'll have to see it in real life first :-)
I have... or at least the Panasonic that it's based on. They had one in Moscow's Domodedovo airport when I was there in January.
Picture is very good... from a distance. Close up it's a blocky mess. Still, it's bound to be at that size.
It follows that if you have 100k to spend on a TV, you have a big enough room to put it in
Here's a pic, to give you an idea of how big is big.
Ray
Я люблю Банг и Oлуфсен
MGBGTV8
- Joined on 12-22-2008
- Posts 82
it certainly looks stunning but there tagerting the super rich as usual
its a lot to spend when it will be obsolete
whats wrong with a good projector for large screen movies and normal say 40 inch for light watching
rayfenwick
- Hull UK (again)
- Posts 693
johnnielse:
Yes sorry, my webserver was down for an upgrade, and I forgot to check it had re-registered on the DDNS service.
Ray
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
MGBGTV8:
What an odd thing for a B&o enthusiast to say!
rayfenwick
- Hull UK (again)
- Posts 693
johnnielse:
Still can't see it
try refreshing the page. It's definitley there.... anyone else having probs seeing it?
Ray
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Yes. rayfenwick.dnsalias.org resolves to 192.168.0.3, which is probably an internal IP address for your server behind a NAT of some sort - in any case, unreachable from the outside world...
rayfenwick
- Hull UK (again)
- Posts 693
tournedos:
Ahem.. The router got confused and put my 2nd router inside the NAT and not in the DMZ. Should be working now..
Thanks for telling me... it all looked fine from inside, so i had no reason to suspect it had cocked up..
Ray
Luke
- Joined on 02-03-2009
- Switzerland
- Posts 286
It still doesn't work for me :-(
rayfenwick
- Hull UK (again)
- Posts 693
something is definitely odd.. the URL resolves to my external IP.... my fiancee in Russia has no problem seeing it....
very strange....
Ray
rayfenwick
- Hull UK (again)
- Posts 693
thank goodness for that!
Big, isn't it? :)
Ray
Alex
- Joined on 04-16-2007
- Bath & Cardiff, UK
- Posts 2,990
Bear in mind this isn't intended as an 'every dealer should sell two a year' thing, it's a statement product, similar to say, the Bugatti Veyron...
Weekly top artists:
Flappo The Grate
- Posts 703
so bno's mesage is ; here's a £100k out of date tv that weighs as much as a small elephant and is aboot as moveable that you could probably outperform with £5k's worth of projector and screen that just rolls up out of the way all inconspicuously like when the taxman comes round
i'm surprised it's not gold plated too
Dave
- Posts 2,328
well enjoy focussing on every possible negative of the concept, then sure! It's a cool product, a screen that rolls up out of the way is simply that, only B&O would make a huge screen as awestriking, individual and beautiful as this.
If i had the space and the dosh, i'd dive in head first and obtain one, i think it's utterly brilliant.
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
I'll never come even close to owning one but, in the interests of debate, what is the point of the stand lifting it 18" to watch and then lowering to the floor again when off, or am I missing something?
Puncher
- Posts 9,588
...........and that is really my point! The BS9000's exposed functionality is beautiful to look at - but It is functional, the movement isn't gratuitous. Other automation is similar....... the doors of the Ouverture, the measurement mic of the BL5's, the rotating stands of other TV's to suit your seating position etc. etc. They add something.
I don't see that in the BV103 stand.
Dave
- Posts 2,328
Puncher:
I certainly do! The glass doors on an ouverture are pointless from a function point of view - But they make it MAGIC to use and own. I foresee this being used in smaller screens, which is great. I think that once you see this screen in person, doing it's thing, you'll 'get it'.
Puncher
- Posts 9,588
Dave:
Puncher:
The glass doors on an Ouverture need to be opened - why not automatically! I'm pleased you "get" the rising stand.
Dave
- Posts 2,328
The stand needs to rise in order for the speaker to be used!!
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
I agree that there is something intangible about the automation of B and O products. There is something magical about watching a BV7 turn on, turn and tilt into position, and the DVD tray open. The doors opening on a Beosound or Beocenter 2, the antenna rising on the Beosound 1, speakers rising out of the dashboard of an Audi A8, they all add nothing to the actual performance of the product, with the exception of a Beovision tunring to a better viewing position. I think I read in here somewhere that a new set of speakers will be released in which the acoustic lens rises out of the top of the speaker when they are turned on. If I could afford a BV4 103 and had the proper room for it, I would be eagerly looking forward to seeing it perform and seeing a screen that size moving. I have our BV7 set to tilt backwards as far as it will when turned off and then tilt to vertical when it turns on just so I can see the "magic" of it every time I turn it on.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
