        1st March February 2012
	    Latest post 02-11-2009 2:59 AM by Puncher . 25 replies.
								    |  02-08-2009 2:58 PM |  |
									                 PierreRJoined on 08-05-2007Posts 41 |
										    When the new BV7 - 40" mk IV arraive in april with blu ray, does any one know if it can play all new HD sound formats incl DTS Master. Will it be a profile 2,0 so its can be opdatet over internet. I know that it will be Full HD, 100Hz panel, but will it be 24p?  What can you all tell me about the new BV7.......... |  |
									                 TripEnglish
 Joined on 10-27-2007AmericaPosts 1,595 |
										    Re: BeoVision 7 - 40" MK IV
										    Based on recent history, I don't think you want an open door for Bang & Olufsen software to find a way onto your TV! There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin |  |
									                 koning
 Joined on 04-16-2007NetherlandsPosts 2,670 |
										    does any one know if it can play all new HD sound formats incl DTS Master.  very good question anyone?? |  |
									                 Puncher
 Joined on 03-27-2007Nr. Durham, NE England.Posts 9,588 |
										     koning:
   No one dare comment for fear of sparking the BS3/BV7/HD audio argument again! Generally speaking, you aren't learning much if your lips are moving. |  |
									                 Roger
 Joined on 03-28-2007NorwayPosts 870 |
										     TripEnglish:
 B&O have decided that future (high-end only?) BeoVision's shall be able to connect to the internet to receive S/W updates.  DTS-HD: BS3 works fine today as long as you have a bluray player that will decode the DTS-HD signal and pass it on as multi-channel PCM. Based on the spec's I've seen they haven't included TrueHD or DTS-HD among the BS3 sound formats, so I do hope that the new internal bluray will do the decoding and pass it on as PCM to the BS3 - anything else would be embarrassing for B&O.  Roger |  |
									                 Flappo The Grate
 Joined on 04-16-2007Posts 703 |
										    wireless sw updates ? now that IS impressive this tv looks like it might be the new avant ! |  |
									                 Karel Uyttendaele
 Joined on 05-19-2007Aalst, BelgiumPosts 682 |
										     Flappo The Grate:
 Flappo... no one mentioned wireless...  The race for quality has no finish line- so technically, it's more like a death march. |  |
									                 Karel Uyttendaele
										     ed7:
Is still a samsung panel??!
 So? The Avant was a Philips-made tube! The race for quality has no finish line- so technically, it's more like a death march. |  |
									                 moxxeyJoined on 04-14-2007South West, UKPosts 2,360 |
										     Roger:
 Oh god, good point. As I'm assuming the existing drive is merely a drive with a scart-type cable to the main motherboard, I seriously doubt they are going to get a chip capable of decoding the audio then passing it to the BS3, in the new Blu-ray internal drive. Surely the drive would merely be a drive mechanism update? Why? Well, it's a drive mechanism replacement for the existing BV7-40 MKIII (and only £400, which is 'cheap' for B&O), so there's no way you are going get True HD decoding built-in to a £400 internal player. |  |
										    B&O are gonne kill them self if they dont start making up to date produkt  Im not gonna spent about 12-13.000 euro on a outdatet produkt, and i dont think im the only one    |  |
									                 ClakkeJoined on 02-01-2009SwedenPosts 108 |
										     PierreR:
 You are not alone. I just bought a Loewe  B R Clakke |  |
									                 takktakk
 Joined on 08-11-2008NorwayPosts 88 |
										    From what I heard they're switching to Sharp panels. I have this from what I would say is a somewhat good source. Meaning not always right, but more often so than wrong :-)
BV 7-55, BL 7-4, BL 9's, BL 4's, BL 3's, BC 2300, Beo5, Beo4   |  |
									                 The_Beonic_Man
 Joined on 12-22-2008Bath, UKPosts 479 |
										     Clakke:
 PierreR:
 You are definitly not alone. I just bought a BV7-40! Simon. |  |
									                 BeolabJoined on 05-18-2007Sweden Posts 535 |
										    24p = Yes Mk III and MK IV got 24p support. And moxxey it´s not a scart cable between the dvd drive and the motherboard. They use computer IDE Ultra ATA cabling..  And they are going to use Sharp panels in the new BV8-40 and the new Bv7-55, but the Bv7-40 MkIV they still use Samsung, but the new 2-4ms 120Hz Ultra Glare panel. Samsung are far ahead Sharp in LCD technology, so i don´t think you should be disappointed because of that.. Regards   |  |
										    BV7 mk III does not have 24p. Do you know when the new 55" BV7 are arriving? |  |
									                 koning
										    The dealers have they already seen this new BV7-40 MKIV Are the improvements huge? |  |
									                 imacJoined on 04-16-2007Posts 9 |
										    The MKIII does have 24p, you just need the newest software update. From what my dealer told me, the BV7-52" was put on hold due quality issues with the 52" panel. Regards imac   |  |
										     Beolab:
 I think you miss my point entirely. I have no idea what cable is used from the mechanism to the motherboard, but I do assume that there is no audio decoding done on the mechanism side (and that's the point). So, if they insert a Blu-ray mechanism, then this is unlikely to decode the HD audio before passing to the TV motherboard. It will have to be done by the BS3. Unless I'm wrong - and I hope I'll be wrong - this would mean that the internal Blu-ray drive wouldn't decode the audio to the level of, say, the Playstation 3. |  |
									                 AlexJoined on 04-16-2007Bath & Cardiff, UKPosts 2,990 |
										     Beolab:
 No, they simply use a ribbon cable. IDE Ultra ATA is merely a method of parallel data transfer, which doesn't mean it's similar in any way to the way the data is carried from the DVD mech to the BeoVision 7-40 chassis.  Weekly top artists:
										     Moxxey i understand you perfectly, but i just hanged up on the "scart cable - sound issue" sentence you wrote. The dvd player is only a transport, and only read the information on the disc and then the motherbord´s onboard software and audio / video processor´s (DAC´s) decodes the picture and the soundstream. And yes Alex it is a ribbon data cable, but not as wide as an IDE cable.  I just wrote IDE so people here understand what sort of cable i menth, but they look the same but thinner.  Regards |  |
