Latest post 01-30-2009 3:58 AM by koning. 87 replies.
Page 4 of 4 (88 items) < Previous 1 2 3 4
  • 01-25-2009 11:38 AM In reply to
    • hebo
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Sweden
    • Posts 305
    Re: BV7-40 price drop??
    Is it the same panel in the BV7-32 Monitor, as in the one with dvd?
    And what about the connection panels? Any news? Any spec???
     BV10
  • 01-27-2009 4:04 PM In reply to
    • hebo
    • Sweden
    • Posts 305
    Anyone knows how many times they changed panel in BV7-32 since the first one?
    Are there any Hdmi-connections on the BV7-32 Monitor version????
    Would like to see the spec on the one without dvd.
     BV10
  • 01-27-2009 4:11 PM In reply to
    • Robert
    • Top 150 Contributor
    • Joined on 06-13-2007
    • Northern Ireland
    • Posts 362
    • Gold Member
    My dealer told me that the monitor version still has the same connections as the existing 7-32 DVD. Therefore I believe no HDMI, still DVI. Although it has been said here that the BV7-32 will get the new chassis to be featured in the BV8-40...
  • 01-27-2009 5:17 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    That would be crazy. The same picture processing engine from the MKI, first produced in 2004?
    I think someone said on here that the MKV BV7-32 was due in May/June, but why would B&O release such a major update soon after the launch of the 'monitor' version?
  • 01-27-2009 5:28 PM In reply to
    I was wondering the same a while back. Only explanation for me is the BV7 32 was available to hotels without a DVD if I recall correct. So they had it all along, just not available for the normal consumer. Or it is much easier to just rip out the DVD drive then we all think.
    JK
  • 01-28-2009 11:06 AM In reply to
    oki doki..
    Enjoy ;)
    CTV
    Cabinet finish
    Glass, aluminium and soft touch lacquer paint
    Colour variants
    Black, Blue, Dark grey, Red, Silver
    Mains voltage range
    220-240VAC +10/-15%
    Power consumption
    Typically 152 watt/Stand-by 1 watt
    Terminal
    Beo4 (to be ordered separately)
    Diagonal picture size
    32”
    Aspect ratio
    16:9
    Contrast ratio
    Typically 2000:1
    Resolution
    1366 x 768 (WXGA)
    Display colours
    16,7 million
    VisionClear
    Adaptive black
    Digital Adaptive Dynamic Luminance Peaking
    Digital Adaptive Noise Reduction
    Blue Stretch
    Digital Colour Transient Improvement
    Motion Compensated Film Mode
    Comb Filter
    Vertical Peaking
    Automatic Picture Control
    Luminance of white
    Typically 500 cd/m2
    Response time
    Typically 8 msec
    Viewing angle
    Typically +/-89 degrees both vertical and horizontal
    Contrast screen
    Anti-reflex coated
    HD-ready
    Yes
    Formats
    Format 1 :
    16:9 Panorama + soft scroll
    15:9 Panorama + soft scroll
    4:3 (only active via setup in service menu)
    Format 2 :
    Letterbox + Soft Scroll
    Format 3 :
    16:9
    Misc
    Automatic format optimization via “Black Bar Detection”
    16:9 detection on all Scart connectors
    Support of WSS (Wide Screen Signalling Pulses) from broadcaster
    VisionClear
    Adaptive black
    Digital Adaptive Noise Mode
    Blue Stretch
    Comb Filter
    Vertical Peaking
    Teletext
    Level 2.5
    Wide Screen Signalling (WSS)
    Video Programming by Teletext (VPT)
    9 memory pages per programme
    17 teletext languages in 7 groups
    Group 0
    English, German, Swedish, Italian, French, Spanish/Portuguese, Czech/Slovak
    Group 1
    Polish, German, Swedish, Italian, French, Serbo-Croatian, Czech/Slovak, Romanian
    Group 2
    English, German, Swedish, Italian, French, Spanish/Portuguese, Turkish
    Group 3 (Russian)
    English, Russian, Estonian, Czech/Slovak, German, Lithuanian/Lettish, Ukrainian
    Group 4 (Greece)
    English, German, Swedish, Italian, French, Spanish/Portuguese, Turkish, Greek
    Group 5 (Arabic)
    English, Arabic, French
    Group 6 (Hebrew)
    English, Hebrew, Arabic
    Options
    1, 2, 3, 4, 5, 6
    Tuning
    99 programmes, autotune, programme move and automatic naming
    Tuner range
    45-860 MHz
    Tv programmes
    99
    Stereo decoders
    A2 + Nicam
    Menu languages
    English
    Danish
    Dutch
    Spanish
    Italian
    German
    French
    Swedish
    PIN-code protection
    Yes
    Loudspeakers:
    Optional
    Types
    BeoLab 7-1 (Type 6210/6212) depending on market
    BeoLab 7-4 (Type 6215/6216) depending on market
    For more technical details see Tech.Spec. for BeoLab 7-1 and Beolab 7-4
    System modulator:
    Frequency range
    471,25-855,25MHz (in 1MHz step)
    Dual side band
    Audio
    Mono
    FM sound system G : 5,5MHz (depending on setup)
    FM sound system I : 6MHz (depending on setup)
    Connection
    1 x 75 ohms aerial male
    Dolby® Digital Decoder:
    Standard (always mounted)
    Decoding capabilities
    Dolby Digital 5.1 channel decoding
    DTS 5.1 channel decoding
    Sound modes (Speaker)
    1, 2, 3, 4, 5
    Connections :
    5 x Power link
    Set-top Box Controller:
    Controlling boxes with Beo4
    Supported boxes : See list at Bang & Olufsen Retail System (via internet).
    Connection (STB)
    4 x 3,5 mm jack
    Connections
    TV Input
    1 x 75 ohms aerial female
    Output Modulator
    Scart
    AV1
    CVBS in/out, RGB in, Y/C in (automatic Y/C detect, automatic 16:9 sense (pin 8), B&O AVL (2 way))
    AV2
    CVBS in/out, RGB in, Y/C in (automatic Y/C detect, automatic 16:9 sense (pin 8), B&O AVL (1 way))
    AV3
    CVBS in, RGB in, (automatic 16:9 sense (pin 8), B&O AVL (1 way))
    PC input
    DVI-I connector female
    HDCP is supported if used as HD input
    Camcorder/Auxiliary
    1 x phono video in
    1 x phono audio right in
    1 x phono audio left in
    Auto detection on video signal
    S-Video (S-VHS)
    Headphone
    1 x 3,5 mm jack
    Dolby® Digital
    - External BeoLab speakers
    - Digital audio input
    5 x Power link
    Satellite module (DVB-S) (optional)
    1 x F-connector female
    1 x DSUB 9 female (only for DVB module software update)
    STB-Controller output
    4 x 3,5mm jack
    System Modulator
    Digital audio inputs
    4 x phono
    BeoLink®
    1 x Master link connector
    BeoLink® video distribution
    Motorised stand operation
    1 x 5 pole DIN connector
    Projector output
    1 x DSUB 15 pin female VGA
    1650 x 750p @ 50Hz
    (active: 1280x720);  (720p 50Hz)
    Pixel clock
    74.25 MHz
    Line frequency
    37500 Hz
    H-sync polarization
    negative
    H-sync length
    128 pixels
    V-sync. polarization
    negative
    V-sync. length
    5 lines
    Used standards
    SMPTE 296M-1997 converted to 50Hz VESA CVT
    1650 x 750p @ 60Hz
    (active: 1280x720);  (720p 60Hz)
    Pixel clock
    74.25 MHz
    Line frequency
    45000Hz
    H-sync polarization
    negative
    H-sync length
    128 pixels
    negative
    V-sync. length
    5 lines
    Used standards
    SMPTE 296M-1997 VESA CVT
    External IR receiver
    1 x 3,5 mm jack
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 01-28-2009 3:58 PM In reply to
    • Alex
    • Bath & Cardiff, UK
    • Posts 2,990
    Those are the specifications for the current BeoVision 7-32.
     Weekly top artists:
  • 01-29-2009 4:33 PM In reply to
    Is there anyone who knows  specifications for the up-coming BV8-40Cool
  • 01-29-2009 4:43 PM In reply to
    Are they?
    Then the specs are excactly the same as the BV7-32 w. DVD because these specs are taken from the officisal specs for BV7-32 w/o. DVD..
    But isnt there a new BV7-32 coming with HDMI sockets soon..
  • 01-29-2009 4:44 PM In reply to
    I think only the developers at this stage...:)
  • 01-30-2009 3:25 AM In reply to
    Developers would you be so kind to give us the specs!LaughingStick out tongue
    (lol)
  • 01-30-2009 3:49 AM In reply to
    Where are the Sheep when you need them :-) Or.. have they been served ? Hmm
    The race for quality has no finish line- so technically, it's more like a death march.
  • 01-30-2009 3:58 AM In reply to
    Big Smile
