1st March February 2012
Latest post 01-30-2009 3:58 AM by koning. 87 replies.
hebo
- Joined on 04-16-2007
- Sweden
- Posts 305
Is it the same panel in the BV7-32 Monitor, as in the one with dvd?
And what about the connection panels? Any news? Any spec???
hebo
- Sweden
- Posts 305
Anyone knows how many times they changed panel in BV7-32 since the first one?
Are there any Hdmi-connections on the BV7-32 Monitor version????
Would like to see the spec on the one without dvd.
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
That would be crazy. The same picture processing engine from the MKI, first produced in 2004?
I think someone said on here that the MKV BV7-32 was due in May/June, but why would B&O release such a major update soon after the launch of the 'monitor' version?
jk1002
- Boston USA
- Posts 1,620
I was wondering the same a while back. Only explanation for me is the BV7 32 was available to hotels without a DVD if I recall correct. So they had it all along, just not available for the normal consumer. Or it is much easier to just rip out the DVD drive then we all think.
JK
BMGHB
- Joined on 05-12-2007
- Posts 219
oki doki..
Enjoy ;)
CTV
Cabinet finish
Glass, aluminium and soft touch lacquer paint
Colour variants
Black, Blue, Dark grey, Red, Silver
Mains voltage range
220-240VAC +10/-15%
Power consumption
Typically 152 watt/Stand-by 1 watt
Terminal
Beo4 (to be ordered separately)
Diagonal picture size
32”
Aspect ratio
16:9
Contrast ratio
Typically 2000:1
Resolution
1366 x 768 (WXGA)
Display colours
16,7 million
VisionClear
Adaptive black
Digital Adaptive Dynamic Luminance Peaking Digital Adaptive Noise Reduction Blue Stretch Digital Colour Transient Improvement Motion Compensated Film Mode Comb Filter Vertical Peaking Automatic Picture Control
Luminance of white
Typically 500 cd/m2
Response time
Typically 8 msec
Viewing angle
Typically +/-89 degrees both vertical and horizontal
Contrast screen
Anti-reflex coated
HD-ready
Yes
Formats
Format 1 :
16:9 Panorama + soft scroll
15:9 Panorama + soft scroll
4:3 (only active via setup in service menu)
Format 2 :
Letterbox + Soft Scroll
Format 3 :
16:9
Misc
Automatic format optimization via “Black Bar Detection”
16:9 detection on all Scart connectors
Support of WSS (Wide Screen Signalling Pulses) from broadcaster
VisionClear
Adaptive black
Digital Adaptive Noise Mode
Blue Stretch
Comb Filter
Vertical Peaking
Teletext
Level 2.5
Wide Screen Signalling (WSS)
Video Programming by Teletext (VPT)
9 memory pages per programme
17 teletext languages in 7 groups
Group 0
English, German, Swedish, Italian, French, Spanish/Portuguese, Czech/Slovak
Group 1
Polish, German, Swedish, Italian, French, Serbo-Croatian, Czech/Slovak, Romanian
Group 2
English, German, Swedish, Italian, French, Spanish/Portuguese, Turkish
Group 3 (Russian)
English, Russian, Estonian, Czech/Slovak, German, Lithuanian/Lettish, Ukrainian
Group 4 (Greece)
English, German, Swedish, Italian, French, Spanish/Portuguese, Turkish, Greek
Group 5 (Arabic)
English, Arabic, French
Group 6 (Hebrew)
English, Hebrew, Arabic
Options
1, 2, 3, 4, 5, 6
Tuning
99 programmes, autotune, programme move and automatic naming
Tuner range
45-860 MHz
Tv programmes
99
Stereo decoders
A2 + Nicam
Menu languages
English
Danish
Dutch
Spanish
Italian
German
French Swedish
PIN-code protection
Yes
Loudspeakers:
Optional
Types
BeoLab 7-1 (Type 6210/6212) depending on market
BeoLab 7-4 (Type 6215/6216) depending on market
For more technical details see Tech.Spec. for BeoLab 7-1 and Beolab 7-4
System modulator:
Frequency range
471,25-855,25MHz (in 1MHz step)
Dual side band
Audio
Mono
FM sound system G : 5,5MHz (depending on setup)
FM sound system I : 6MHz (depending on setup)
Connection
1 x 75 ohms aerial male
Dolby® Digital Decoder:
Standard (always mounted)
Decoding capabilities
Dolby Digital 5.1 channel decoding
DTS 5.1 channel decoding
Sound modes (Speaker)
1, 2, 3, 4, 5
Connections :
5 x Power link
Set-top Box Controller:
Controlling boxes with Beo4
Supported boxes : See list at Bang & Olufsen Retail System (via internet).
Connection (STB)
4 x 3,5 mm jack
Connections
TV Input
1 x 75 ohms aerial female
Output Modulator
Scart
AV1
CVBS in/out, RGB in, Y/C in (automatic Y/C detect, automatic 16:9 sense (pin 8), B&O AVL (2 way))
AV2
CVBS in/out, RGB in, Y/C in (automatic Y/C detect, automatic 16:9 sense (pin 8), B&O AVL (1 way))
AV3
CVBS in, RGB in, (automatic 16:9 sense (pin 8), B&O AVL (1 way))
PC input
DVI-I connector female
HDCP is supported if used as HD input
Camcorder/Auxiliary
1 x phono video in
1 x phono audio right in
1 x phono audio left in
Auto detection on video signal
S-Video (S-VHS)
Headphone
1 x 3,5 mm jack
Dolby® Digital
- External BeoLab speakers
- Digital audio input
5 x Power link
Satellite module (DVB-S) (optional)
1 x F-connector female
1 x DSUB 9 female (only for DVB module software update)
STB-Controller output
4 x 3,5mm jack
System Modulator
Digital audio inputs
4 x phono
BeoLink®
1 x Master link connector
BeoLink® video distribution
Motorised stand operation
1 x 5 pole DIN connector
Projector output
1 x DSUB 15 pin female VGA
1650 x 750p @ 50Hz (active: 1280x720); (720p 50Hz)
Pixel clock
74.25 MHz
Line frequency
37500 Hz
H-sync polarization
negative
H-sync length
128 pixels
V-sync. polarization
negative
V-sync. length
5 lines
Used standards
SMPTE 296M-1997 converted to 50Hz VESA CVT
1650 x 750p @ 60Hz (active: 1280x720); (720p 60Hz)
Pixel clock
74.25 MHz
Line frequency
45000Hz
H-sync polarization
negative
H-sync length
128 pixels
negative
V-sync. length
5 lines
Used standards
SMPTE 296M-1997 VESA CVT
External IR receiver
1 x 3,5 mm jack
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
BMGHB
- Posts 219
Are they?
Then the specs are excactly the same as the BV7-32 w. DVD because these specs are taken from the officisal specs for BV7-32 w/o. DVD..
But isnt there a new BV7-32 coming with HDMI sockets soon..
BMGHB
- Posts 219
I think only the developers at this stage...:)
